ATX 24pin to PCI slot riser card!Need help!
It's been more than a year that i had started this project mini itx into my broken commodore 64 case yet by mistake i have lost this pci to ATX bracket.Could you tell me where i could find such a riser or if it would be safe to mode a pci riser cable by cutting the cables and soldering them directly to the psu.Would it safer to buy an old SBC computer and power it throuht the pci socket?
thank you
http://www.insomnia.gr/index.php?app...ttach_id=32256
Could you post the manufacturer of the board? Thanks!
that would be Asus and Pegatron.It has a label IMXMV-RJ.
- You may not post replies
- You may not edit your posts
Forum Rules
