Hello,
Is there anyone here who has any experience with the following radiator?
http://shop.aquacomputer.de/product_...oducts_id=2725
I'm thinking of purchasing two, for a dual loop system. It's a bit bigger than what I'm looking for (a 140.5 would have been ideal), but I've been unable to find any of those.
My main concerns are mounting and flow restriciton. I've heard that these rads are highly restrictive, would a single Laing D5 pump be enough to cope with something like this, in a loop with an average restriction CPU or GPU block?
With regards to mounting, any ideas on how to position them? Obviously they'd have to be external to any case, but I can't think of any way to fix them to keep them stable...
Alternatively, if anyone knows of any 700mm radiators that would be ideal!
Odai.
EDIT: I'm aware of the option to simply stick a 420 and a 280 AMS radiator together, but this would be quite a bit more expensive!
