So I'm really thinking about plunging and buying 2 Opteron Interlagos 16 cores...
But considering the price, I was thinking of buying lower clocks and then I could overclock them...
Has this ever been done before or is there just no way?
Two ways that it can be done that i know of:
1. Unlocked ES Samples will allow the multiplier to be changed to a higher setting allowing overclocking.
2. Find a dual socket G34 motherboard that supports overclocking via the baseclock.
The odds of getting ES chips is pretty low so you probably will have to look for a board that supports overclocking the baseclock. I think Supermicro or Asus either has boards that do that or are developing them currently. I remember a few years ago
s7e9h3n? had an unlocked ES Opteron 12 Core Magny-Cours that he overclocked via multiplier to over 3ghz if remember right. Hope that helps.
don't get interlago's get Abu Dhabi.
I've only seen up to 225HTT on sever boards.
Overclocking?
Unheard of, but Turbo mode does it for you and takes all fun/hassle in the process
