Results 1 to 8 of 8
Thread: Video Card Cooling Mod
    Sep 2006
    Chicago
    I was wondering if anyone has ever removed their video card cooler and tried cutting out an aluminum plate and then attaching a 120mm high CFM fan to it. I'm wondering if that would work better than the current GPU shrouds.
    | NZXT H630 (White) | ASUS Maximus VI Hero | Intel i5 4760K | CORSAIR Dominator GT 8GB @2000MHz Memory | MSI Gaming Twin Force GTX 770 2GB @ Power Limit + %185 | ASUS Xonar HDAV 1.3 Deluxe Audio Card | Philips amBX Premium Kit | Nvidia 3D Vision 2 |
    Dec 2012
    Buenos Aires
    Removing the cooler wouldn't be a good idea...It has some form of radiator inside the shroud, so you would lose on surface area.
    There are things like Arctic Cooling or Thermalright Shaman coolers which rely on heatpipes+radiators+bigger fans like conventional cpu coolers and work quite good.
    Dec 2007
    Earth
    Quote Originally Posted by Bad213Boy View Post
    It may or may not.
    If the heatsink itself is up to snuff it might help.
    For example a I have gtx460 that uses a cheapy aluminum heatsink. I removed the 80mm stock fan and strapped a 120mm to the heatsink made no real difference in temps.
    I tried shrouding it with cardboard (just to test) did not help.
    Now on the other hand I tried somthing similar on a msi twin frozr and it worked well.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Sep 2005
    DFW
    I wonder if perhaps you could remove the plastic cover on the card and then form a custom shroud for it, this would leave the radiator intact but you could potentially mount other fans onto the thing. I may look into this in the coming days.
    The issue is going to be that it may weigh down the card wayyyyyy too much and make it lean....
    ^_^ time to dust off my CAD
    Quote Originally Posted by freecableguy
    I'll come blow on your heatsink for a dollar. Thats pretty ghetto
    Quote Originally Posted by Xeon th MG Pony
    sorry to sound harsh but so would you if some one asked if nitroglycerin was a good coolant for his car!
    Check out my forum: http://www.anarchyst-it.com
    Aug 2009
    Somewhere
    I got a 5830 that had a busted fan, so I pulled off the plastic cover and zip-tied a 120mm(yate medium speed) fan to it. It doesn't weigh the card down too much, and it cools pretty well (82c at 100% in my room which is pretty warm as well).
    Desktop (and Cruncher #1):AMD Phenom II x6 1090T @ 4.03Ghz | Gigabyte MA790FXT-UD5P (F8n) | G.Skill Ripjaws 2x4GB @ 9-9-9-24-1T 1680MHz | Radeon HD 5850 & 5830 | Silverstone ST75F 750W | 60GB OCZ Vertex 2 3x1TB WD RE3 (Raid 5) | Lian Li PC-A70B
    Cruncher (#2): Intel Core I7 920 (stock) | EVGA X58 SLI | G.Skill Pi 3x2GB | 2x Radeon HD 6870 | Corsair HX850 | Some Janky HDD | LanCool PC-K7
    Cruncher (#3): Intel Core I7 2600k (stock) | BioStar TH67+ | G.Skill Ripjaws 2x4GB | Antec Basiq550 | Some Janky HDD | Antec 300
    Server: Intel Atom | 2x2GB DDR3 | ThermalRight TR2-430 | Some Less Janky Laptop HDD | Fractal Core-1000
    Mobile: Lenovo X120e
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    I've done similar things to CPU stock coolers before. Removed the crummy 70mm-ish fan and slapped a 80mm high CFM fan. Generally works pretty well. For GPUs though your better off buying a 3rd party cooler.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    Sep 2010
    US, MI
    In the past I would replace the heatsink with a cpu one, usually an old alu a64 heatsink, old fx ones I think...
    Big ones...
    Zip ties generally don't work to well, it could be unbalanced or not tight enough.
    I once snapped off some smd mem caps off a 4600ti (quadro 900xgl hard modded), I had to clock it's mem from 700+mhz down to 200-250mhz to keep it stable in windows, not stable in dos or the bios lol.
    All that over a snapped zip tie ^^.
    Epoxy tim I don't recommend either.
    Did that to my 8600gt and my gt240.
    The 8600gt, overheated and died within 30mins(installed windows and it died after the next post) when I placed it in a normal case where the heatsink faces down.
    It was running fanless, never had a single issue until then.
    The 240gt, worked fine until I put it in a normal case yet again lol.
    After a few weeks of being in that case, little use, my cousin was staying over for a week.
    He was playing skyrim on it.
    After a few hours of playing it, it started crashing.
    Even the bios was crashing.
    I thought maybe the pwm was going out on the dfi, it was the 790fx-m2r board.
    I had fans on both the pwm and the card it's self, both 120mm fans.
    I put that pc away, a month ago I went to put it together and sell it to that same cousin of mine, and noticed what happened...
    The heatsink fell off the card, it was never at sub zero temps either.
    The stress of being a large heatsink on an upside down card (normal), even though it was an epoxy, didn't work for very long.
    Supposedly the thing to do these days is get yourself a bracket for your card to fit a water cooler on it.
    Like the corsair's or nzxt's.
    To put it simply, the things I've learned are:
    No zip ties (It's ok to use to hold a fan in place though, but not a heatsink)
    No tim epoxy (maybe it's ok for pwm's and mem..., sticky tape tim doesn't cut it for either of those - restricts heat transfer).
    Apr 2004
    United Kingdom
    When in a bind, epoxy is also great for fixing DIY VRM botch-ups
    "Prowler"
    Cooling:
