Results 1 to 23 of 23
Thread: K.3nny's TopNotch Phantom 820 Casemod
    Jan 2010
    K.3nny's TopNotch Phantom 820 Casemod getting allong.....
    New build new changes
    Thnks to NZXT HQ for this case: NZXT Phantom 820 Gunmetal.
    Gonna strip it down, tear it up and design and build a better one in my style.
    Originally
    Stock, It isnt my style, to futuristic, Gonna flip it all over,go the clean route and Do my thing.
    Flipped motherboard I/O is on the upper now.
    I need a clean top panel now, gonna leave only the mesh part stock, the rest will be cleaned
    See u with the next update
    Casemodding Addict.
    Xtreme Enthusiast miptzi's Avatar
    Feb 2008
    Not sure if...
    hardcore stuff...
    nice.
    keeping my eye here
    Raidmax ATOMIC - Core i7 3770s + Corsair H70 // Gigabyte H77N WIFI // Corsair Vengeance 2x4GB 2133mhz // EVGA GTX1060 ACX2.0// Kingston SUV400 480Gb // Sharkoon SFX500L
    Jan 2010
    Thnks, Il try to do the best i can
    Casemodding Addict.
    Jan 2010
    Update
    Cutted the top
    Created a sheat of alu to be the new top plate
    Mounting holes
    More holes :P
    Fits like a glove *thats flush !
    Time to mark al the holes and cut-outs
    See u at the next update !
    Casemodding Addict.
    Jan 2010
    Parvum commin to an end almost (or not ) but progress was needed!
    Did some things today
    2x Gtx 470 incl all EK assecoires, littlte older then people wanna see in buildlogs, but hey, Low budget = me
    I will make Custom tops for the blocks
    Did also some work on the case, finished the top (the big works) and pop rivited the whole chassis!
    Gonna create my own feet and gonna remake the back panel, also goin to remake the whole inside!
    Casemodding Addict.
    Jan 2010
    Update
    Few days back i had allot of scrap plexi, (thanks to father in law ) normally would take 1.5mm alu, but hey, some quality plexi is also a good thing !
    Need to wait on some rads who are still in production soon i wil buy 6pumps/tops: http://www.highflow.nl/pompen/andere...ion-13154.html + http://www.highflow.nl/pompen/andere...top-13136.html . (dual loop)
    Because i can u know :P just some crazy ass loops!
    2loops
    Loop1: RES-3xPUMP-360(backpanel )-GPU-GPU-RES.
    Loop2: RES-3xPUMP-360(frontpanel )-CPU-MEM-RES.
    Casemodding Addict.
    Jan 2010
    Update !!
    Custom front door, Gonna weld the grill into the door
    Also gonna weld this under airfilter handle thing into the front:
    The front will be made in one piece, i am going to weld the door also, Clean as a Muttertrucker
    Also did mounted all the plexi panels because one of these days my rads will come with the mail i needed to be sure it would fit the 8CM!(yes 8!) thick rads
    Hardware test fit, so i cant make a mistake with the rads
    see u on the next one.
    Casemodding Addict.
    Jan 2010
    Update!
    Did allot today, alle the panels are done! (exclusive the rad cut-outs)
    NOTE! some pics are edited, Some parts i cant show! (secret stuff )
    Starting with the hardware AGAIN in the case, so everything get the fit as is should!
    Mounted and drilled everything for the panel support and connection.
    Rad support 1
    Rad support 2
    Midspeed triebs <3
    getting everything lined up and test mounting it!
    also i figured out how to connect the first line of 3 pumps, so i could make the support and the connection tabs
    See u soon on the next update
    Casemodding Addict.
    Jan 2010
    Update!
    Finished the pump connection plates
    3 little pumps !
    scrollsawed the radiator holes, and a notch here and there
    All sawed panels
    See u guys at the next update
    Casemodding Addict.
    Jan 2010
    Update
    Played a little with the pumps, Think this is is the final outcome, i got plenty of room so thats not the point, but i dont want to hide them, i know its cleaner (always when you hide stuff)
    First Panel is done ! realy glad with the results.
    Gonna be alllrighty
    Casemodding Addict.
    Jan 2010
    update !
    Finally i can tell about this haha !
    Thnks to Freddy (Highflow.eu) that gave the opertunety to work together with martin (The Feser Company) Jeej :thumb::rock:
    picss:
    Fittings displayed
    3/8th hose Uv green
    HF admiral sidepanels
    First pumps connected and test loop thingy
    first loop
    other 3pumps waiting
    both loops done.
    *note, loopscan be changed
    See u on the next one !
    Casemodding Addict.
    Nov 2010
    Wow...looks superb
    I'm very curious about the results of the flow
    so unusual pump system.
    Nov 2010
    How this admiral rad works? are what they promised?
    Jan 2010
    After a week hard work, the inside is almost done, i can focus more on the outside now
    Picsss
    1 uv led <3 just for fun
    I like this picture allot haha !.
    Custom door, i welded the 2 pieces toghether.
    Window.
    leds on 12 volt, gonna be 7 volt finally
    Casemodding Addict.
    Jun 2009
    Central Massachusetts, US
    Absolutely sick - I wish i had time and patience to do these kind of projects!
    2600k @ 4815mhz
    Z68XP-UD4
    Sapphire 6950 (unlocked to 6970 bios, 950/1400)
    Corsair Vengeance 8gb DDR3 1600mhz
    Corsair 850TX
    Corsair Obsidian 800d
    MCR320 . MCP355/XSPC Top . ApogeeXT . Z-Multi rez . EK VGA Supreme HF . Primochill LRT UV blue tubing
    Jan 2010
    thnks mate just take the time
    Casemodding Addict.
    Jan 2010
    4 days to go for the deadline,
    need to buy the paint and even paint the case itself, aii That stress haha!
    top and front are done, will look good when painted!
    Weight (kilo)
    lightning
    Irl the pumps are not that bright!
    Casemodding Addict.
  18. #18
    May 2009
    very clean work mate
  19. #19
    Jan 2010
    Thnks !
    Casemodding Addict.
  20. #20
    Mar 2013
    Sweden
    Really love how you managed your tubes and those pumps. Good job Kenny!
    Scratchbuilds | CURV3D | Cold Winter |
    Casemods | F4DE |
    Check out my website Minimalistic PC where you can find all my projects aswell as reviews and other tech related stuff.
  21. #21
    Jan 2010
    Thnks thnks ! still not done
    Casemodding Addict.
  22. #22
    Jan 2010
    Full custom parts, RVS tubing unique style.
    A little bit unique isnit
    There are all loose pieces, and cutted from a RVS pipe, the diameter is 13mmID
    Using is pretty simple, Full hoses, or only the sight, maybe even only tagging it with an emblem, no problem! will let you guys know more soon!
    Casemodding Addict.
  23. #23
    Feb 2007
    Turkey
    That is a whole new level in tubing. Well done.
    vuuuu
