What would be the problems if one used fluorinert as the coolant for their liquid cooled system? For example:
What kind of tubing would you have to use? Would norprene be adequate?
What would be the issues with evaporation? How quickly would you have to get it into the tubing before it evaporated?
What kind of protective gear would you have to wear? What would happen if you did inhale it or get it on yourself?
Thanks in advance!
