Palit GTX 460 Sonic Platinum - After Market Cooling suggestions
Hi all,
I would like to ask for some suggestions from experts here. I have 2 Palit GTX460s in SLI, and I love these little beasties as they can still keep up with anything I throw at them.
Right now I am using some beast 120x120 fans on the stock heatsink however the functionality is not optimal and the result is very loud. I get slightly better results than the crappy stock cooler but still not acceptable. I am keeping the GPUS at 870mhz core, 2050 mems and on full load they reach 90+ degrees and may crash.
Is there any good aftermarket heatsink you would recommend,
1)that allows SLI
2)does not need modifications
3)fan can be plugged on GPU and controlled by the GPU (this last one is not mandatory as I could attempt to modify the fan to adapt it)
By researching I found 4 possible options however I am not sure whether the performance will be acceptable. These are:
1)Accelero L2 Plus
2)Zalman VF2000
3)Scythe Setsugen 2
4)Arctic Accelero Mono Plus - Can anyone confirm if this would be compatible with the layout of my board?
Would you recommend any of the above or any other better alternative?
I hope I am not asking too much!
To close I would like to thank in advance anyone who tries to help with my query.
GIGABYTE Z97X Gaming 3
Intel i7-4790K Devil's Canyon @ 4.5ghz
NXZT 340S
Corsair H110i & Corsair Link
2x8GB Corsair Dominator Platinum DDR3-2133
ASUS Strix GTX1080Ti OC
Storage:
- 2xSamsung 850 Pro 250GB SSD
- Samsung 860 Pro 250GB SSD
- Samsung 970 Evo M.2 250GB SSD
- WD Caviar SATAII 1TB 32 mb cache
- Seagate SATAII 320GB 16mb cache
- Samsung 2.5" SATAII 320GB 8mb cache
- HGST(PS4) 2.5" SATAII 500GB 8mb cache
- Maxtor SATAI 120GB 8mb cache
Corsair AX1200i PSU
Windows 10 Pro 64bit
ASUS ROG Swift PG279Q
I am Xtreme
Personally I would look at the Gelid Icy Vision. I have the AMD version for my HD7950 and the cooler just has phenomenal performance at extremely low noise levels. The MSI TwinFrozr cooler running Warhead benchmark @ enthusiast DX10 1680*1050, HD7950 @ 1105 / 1675 1.15v hit a astronomical 90c even with the fans @ 100%. The Icy Vision: 58c.
Thanks ket..i suppose its verified to be compatible with the non ref palit 460? I think it doesn't due to the stacked dvi slots
Sent from my GT-9100@MIUI 2.11.30+Siyah kernel v5.0.1 CPU@1600 GPU@520
NXZT 340S
Storage:
Corsair AX1200i PSU
I am Xtreme
YOu would have to look at the cooler. Unless the spacing holes to mount a cooler over the GPU are different I don't see any reason why the Icy Vision for nvidia cards wouldn't fit.
- You may not post replies
- You may not edit your posts
Forum Rules
