Page 2 of 7 FirstFirst 12345 ... LastLast
Results 26 to 50 of 175
Thread: Radeon HD 8000 Sea Islands first details
  1. #26
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    1. Even next gen consoles won't be able to touch the horsepower of a 7950/7970 or a GTX670/680
    2. Next gen consoles will still lag behind current top tier GPUs in the amount of memory available by at least 1GB
    3. 20 pounds says my OC'd system will run Crysis 3 perfectly fine
    Think people. The next gen consoles will at best have half the GPU power of current top tier GPUs and a maximum of about 2GB vRAM, a combined memory pool may allow developers to stretch that though so next gen consoles could have up to 2.5-3GB memory available for games. Eitherway no matter which way you slice the pie no angle gives AMD or nVidia incentive to release a GPU with more ROPs / stream processors / CUDA cores at this time.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
  2. #27
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    Quote Originally Posted by Ket View Post
    1. BF3 is a current gen console game but most of the cards can't a constant > 60 on ultra. also old tech consoles didn't stopped game developers to put new technologies in games like tesselation.
    2. Memory is not important. It just gives us high quality textures. For developers putting low quality ones to console disc and high quality ones to the pc disc is not a problem.
    3. I agree with you on this.
    Nvidia may not have reason for increasing rops cores or etc because of their profits and market share but amd has to do something special to reverse this.
    When i'm being paid i always do my job through.
  3. #28
    May 2009
    Switzerland
    Quote Originally Posted by kromosto View Post
    Dont forget both AMD and Nvidia are restricted by the fact they use both 28nm, and tdp.. Nvidia will increase too SP count, the question is more for the 780 if they take the GK110 and play on core speed and resolve computing parts ( the GK110 is at 225W with low core speed/no turbo ( K20x = 235W@730mhz and the K20 = 225w@706mhz ) and we can see the TFLOPS in single precision is not really high for a card with so much more stream processors of the GK104 ..
    They could choose something with core count between the GK110 and the GK104, and goes for higher clock speed ( with the turbo mode, it have really well paid on the GK104 ) ..
    I ask me performance/cost/TDP wise, if they really want to use the K20 (GK110), for push it at 1000mhz+ ( ~ 40% clock increase )
    CPU: - I7 4930K (EK Supremacy )
    GPU: - 2x AMD HD7970 flashed GHZ bios ( EK Acetal Nickel Waterblock H2o)
    Motherboard: Asus x79 Deluxe
    RAM: G-skill Ares C9 2133mhz 16GB
    Main Storage: Samsung 840EVO 500GB / 2x Crucial RealSSD C300 Raid0
  4. #29
    I am Xtreme
    Oct 2004
    U.S.A.
    hopefully AMD will fix the dx9 flickering problem on the current 79xx cards first... wait there's a new 12.11 beta 11 driver
    http://support.amd.com/us/kbarticles...etadriver.aspx
    I have not tested it yet.. but the witcher 2 and World of tanks was bad for me yet had reduced flickers with beta8 for me.
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
  5. #30
    Dec 2010
    Quote Originally Posted by Lanek View Post
    GK110@1000 MHz? Dream on
    At 850 MHz base clock with only 3 GB VRAM it should come in at 4800 GFLOPs SP, that is about 50% more than GK104 has. More Cuda cores at lower frequencies is more energy efficient than fewer cores at higher frequencies.
  6. #31
    Mar 2007
    ...and this is how you kill innovation, you remove the incentive for it. F*ck how i hate consoles. I mean I don't game much and its probably right to say that the console form factor is the ideal for gaming, but their insistence in low grade technology hurt us enthusiasts firstly but mostly the wider public that will never benefit from the new possibilities that computer power would bring to the households of the future.... Low grade morons without vision seling out a better future so that to sell the 10th cod title in a row...
  7. #32
    May 2005
    Quote Originally Posted by safan80 View Post
    It helped a LOT, but the problem still exists with the witcher 2. It's just nowhere near as prominent as it was with beta 8.
    Quote Originally Posted by Leon2ky
    "dammit kyle what's with the 30 second sex lately?" "Sorry sweetie, I overclocked my nuts and they haven't been stable since"
    Quote Originally Posted by trinibwoy View Post
    I don't think his backside has internet access.
    Quote Originally Posted by n00b 0f l337 View Post
    Hey I just met you
    And this is crazy
    But I'm on bath salts
    And your face looks tasty
  8. #33
    Mar 2008
    川崎市
    if they was looking only at this case, they will both have stop do gpu's 6 years ago ..
    The situation isn't the same as a couple years ago, back then high end gpus struggled with the prettiest games at commonly used resolutions, now they don't.
    5 years ago:
    Best looking game available to buy: Crysis
    Top end gpu back then: 8800 Ultra
    http://www.overclock.net/t/310856/98...s#post_3602920
    Less than 60FPs (in other words, too slow)
    now:
    Best looking game available to buy: BF3
    Top end gpu: GTX 680
    http://www.anandtech.com/show/5699/n...-680-review/13
    More than 60 FPS (in other words, fast enough)
    And for the niche of the niche (people with 30 inch screens / people with screens capable of putting out more than 60 FPS) there are always multi gpu solutions.
    Before we get significant improved console performance and or higher res screens there just isn't any reason to go beyond what exists now.
  9. #34
    Apr 2011
    North Queensland Australia
    I bought a comp with 2x 8800 Ultras solely to play Crysis.
    Those were the days :')
    -PB
    -Project Sakura-
    Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
    2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
    Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
  10. #35
    Jul 2004
    London
    Quote Originally Posted by paulbagz View Post
    -PB
    Hopefully Crysis 3 will need two 8800's too to max out. HD 88xx i mean heh
    i7 920@4.34 | Rampage II GENE | 6GB OCZ Reaper 1866 | 8800GT (zzz) | Corsair AX750 | Xonar Essence ST w/ 3x LME49720 | HiFiMAN EF2 Amplifier | Shure SRH840 | EK Supreme HF | Thermochill PA 120.3 | MCP355 | XSPC Reservoir | 3/8" ID Tubing
    Phenom 9950BE @ 3400/2000 (CPU/NB) | Gigabyte MA790GP-DS4H | HD4850 | 4GB Corsair DHX @850 | Corsair TX650W | T.R.U.E Push-Pull
    E2160 @3.06 | ASUS P5K-Pro | BFG 8800GT | 4GB G.Skill @ 1040 | 600W Tt PP
    A64 3000+ @2.87 | DFI-NF4 | 7800 GTX | Patriot 1GB DDR @610 | 550W FSP
  11. #36
    Oct 2007
    Mid UK. Lift a few rocks, eventually you will find me.
    Expect to see games that will need the HD8000 in around 2014.
    With few exceptions consoles drive game development.
    It usually takes at least a year or more for games that fully take advantage of new console hardware to emerge.
    Until these games do emerge the 7970 and 680 will likely play all future console ports up until then at over 60fps.
    From a purely gaming perspective until we do get games that will tax the next gen of console there is little point in getting a GPU > 680 or 7970.
    There are a whole mountain of other reasons though!
    Fun Box: Asus P8Z68-V GEN3++Corsair AX850++i5 2500k@4.5Ghz-1.272v++Corsair A50++2x8Gb Corsair Vengeance++MSI R7970 Lightning++Audigy2 Plat-EX++TBS 6280 DVB-T2 tuner++256Gb OCZ Vertex 4.500Gb Caviar Black.500Gb Seagate Barracuda++Sony AD7240s++Lian-Li PC-60++Linux Mint/Win 7++Asus P238Q
    Work Box: Gigabyte H61MA-DV3++Corsair HX620++i5 3450@stock++2x8Gb Corsair Vengeance++120Gb OCZ Agility 3++Linux Mint
    Quantum theory in a nutshell: It's so small we don't know where it is, it could be here, it could be there.
    Just 'cos it's legal don't make it right.
  12. #37
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Your conclusion doesn't logically follow since the renderer is different on the PC as opposed to the console. Ket is talking about hardware performance potential. The software that runs on top of it is another matter.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
  13. #38
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    Quote Originally Posted by Particle View Post
    no i think that exactly proves my point. so as you said consoles may have lesser hardware performance, also game maybe a console port but this doesn't stop developers to use PC performance potential. So games being console ports shouldn't stop gpu manufacturers .
  14. #39
    Mar 2007
    Portsmouth, UK
    Quote Originally Posted by naokaji View Post
    5 years ago:
    now:
    While out of the box BF3 does look good, Skyrim with some mods to make it look like we all expected it to (console neutering) so I think that would be a better gauge of PC Technology and it's current limitations.
  15. #40
    Mar 2006
    Saskatchewan, Canada
    Quote Originally Posted by boxleitnerb View Post
    Just hope they put the proper voltage components and make it a heavy duty so they thing can be overclocked afterwards. Don't want to see a gk104 like PCB. These monoliths are just asking to be water cooled.
    Core i7 920@ 4.66ghz(H2O)
    6gb OCZ platinum
    4870x2 + 4890 in Trifire
    2*640 WD Blacks
    750GB Seagate.
  16. #41
    Aug 2003
    Finland-Oulu
    5 years ago:
    now:
    Corrected
  17. #42
    Dec 2008
    India
    All you guys complaining that GPU's are too powerful need to score yourselves a 25xx rez screen.
    GTX780/8970 will be looking to have 85% of the performance a 690 has. That would be very very welcome at 500-550$. Last couple of generations have been great competition i hope it continues.
  18. #43
    Mar 2006
    A gtx 780 @ 85 percent performance of a 690 at 500-550 dollars is a bargain. The card would sell out fast. At that performance, $650 would be completely fair even $699. But I doubt we will get that type of jump.
    6gb OCZ platinum
    2*640 WD Blacks
    750GB Seagate.
  19. #44
    May 2009
    Switzerland
    I really doubt we will see a 65-75% jump over the 680-7970 .. 30-40% look more accurate.
  20. #45
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    i will be very happy if i see %40
  21. #46
    Nov 2007
    I will be happy about everything else than a 680gtx xd still in love with the 580 gtx
    little German
  22. #47
    Xtreme Cruncher
    Jun 2006
    I think that even a 40% is a pipe dream. IMO , 25-30% maximum perf. increase over 680/7970.
  23. #48
    Mar 2006
    Quote Originally Posted by informal View Post
    25% percent would be a fail.
    At higher resolutions and AA, the gtx 780, if it has a 384bit bus, should get it 10 percent performance gain at the very least from the bus alone. If nearly doubling shaders and TMU yields 15% that would be a poor effort.
    The difference in number of components and die size between a gtx 560 and 580 was significantly less than what is going to be the difference between a 680 and gtx 780, and the difference between the formers was 47% according to techpowerup.
    So I think at the very least we should get 35% and this is purely because of drivers, with everything optimized I could see a 50% maybe 60% in bandwidth constrained scenarios. The 88 percent increase in shaders, TMU's and 50% increase in bandwidth should make this card a monster. Significantly slower than a gtx 690, I would say by 30%, but the 730 mhz speed on pro parts is actually a good sign. Parts in the mid 800's should be possible for gaming parts as procards have always been clocked significantly slower than their gaming counterparts.
    But anyways, unless sea islands goes past 400mm2 perhaps even getting close to 500, I don't see how they can match up. If AMD is serious about GPU compute, sea Islands is likely to be more specialized for professional applications. I hope AMD has the balls to make another big chip.. Especially if they are going to try to sell it for 550 again.
    6gb OCZ platinum
    2*640 WD Blacks
    750GB Seagate.
  24. #49
    Dec 2008
    India
    Hmm sorry that sorta gain might be too much ...... but 680 and 580 have been pretty slow increases over 480 .... no reasons to think it could be different ? With the 384 bit bus and if nvidia build a BIG chip i guess it will be a 650-700 dollar card(with a 40% increase).
    Sadly they might not want to do that and will go with a cooler smaller more profitable and tree hugger friendly chip like the 680(20% increase) . Good oppurtunity for AMD to take a shot at making something huge and beastly ... 1 of them should or its gonna be boring.
  25. #50
    Xtreme Cruncher
    Jun 2006
    @ tajoh
    I was referring to perf. jump from 7970-> 8970 or whatever AMD calls it. Not the GTX680->GTX780.
