Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: [Case Mod] Lian Li PC-7H Grafit
    Apr 2011
    Time for a small mod named Grafit.
    Last week I have picked up a Lian Li PC-7HX in the local hardware store. I didn't had much choice because it had to be this one.
    With this case I want to enter in the Lian Li Case Mod Competition. I know that the end of the competition is in less then 2 months. ^^
    So lets start!
    Fitting the 420 Rad in the front of the case.
    Removed the alu that is in the way. To make room for the radiator.
    By lowering the radiator in to the hole the top of the case fitted back on it.
    Placed some hardware in the case to check out how much space I have left for all the rest.
    I picked up some new parts from IT-Service this weekend.
    Corsair fans are really well designed.
    Working on this piece of plexi when this is ready I will post a new Update.
    For some reason some of the pictures that needed to be in Landscape are in portrait mode. :s
    Jan 2010
    welcome !
    GL & HF!
    Casemodding Addict.
    Apr 2011
    Thanks Kenneth ^^
    Update.
    Removed the MBtray and replaced it with a plexi version.
    Used the Original MB tray for all the dimensions.
    Drilled holes taped wire and placed the standoff on it.
    Making the opening for the PCI cards
    Tray in the case
    Using a HDD case from the Cosmos 2
    Saw 3 pieces of alu to make new fronts for the HDD
    First front is ready the rest will follow later this weekend.
    Till next Update. ^^
    Jan 2010
    Nice update!
    Allot of custom work!
    Casemodding Addict.
    Apr 2011
    Thx Kenneth ^^
    Small Update
    Dismantle my TJ07 this weekend with pain in my hard. I will be needing all the hardware for this build.
    Drainage ^^
    After the draining I cleaned the pc and prep it to put it back in to the box till the buyer comes and pic it up.
    By By
    Back to the Lian Li case.
    Cutted the top plated in to pieces. And filled up the holes with some 2K filler.
    Reshaping the side panels
    Total picture.
    That was it again I am waiting for some pieces before I can continue with the body and cable management. Hope u all like it so far.
    Cya next time
    Jan 2010
    Yes i like it !
    Casemodding Addict.
    Apr 2011
    Thanks Kenneth
    Update!!
    Did a small mod on the heat-sinks of the MB. Because the theme color for this build will be red. I was obligated to change the color of it.
    Removed the heat-sink from theMB
    Filled a small cup with D-stop and placed the pieces that where colored in the cup for 10 minutes.
    Cleaned the product with water. As u can see there are still some blue spots on it. These are the places where the glue was so U wont see a thing of it when the are back in place.
    This way I don't have to sand the pieces and I keep the brushed effect on the parts.
    The HDD case is finished to but I am not convinced by it.
    Had to come up with a new idea for the HDD. Started with some plexi to create a new HDD bay.
    Short movie of how u place the HDD in place
    Case Mod Lian Li PC-7HX Grafit (HDD Cage) - YouTube
    Did the wires already for the HDD and found a spot for the AC poweradjust 2
    That was it again if the mail service do there job good I will have a very nice suprice before Xmess is here.
    Cya next Time.
    Jan 2010
    Looking good my friend
    Casemodding Addict.
    Apr 2011
    Thanks Kenneth
    Update!!!!
    The update was suppose to be posted before Xmess. But do lak of time with the holidays I only had time to post it today. Time to get a move on.
    Received my 1st package from Nate (Editor22) E22 - Welcome to our website! . Thank U Nate for the great service in this short time. :rock:
    Custom made top res/window.
    And a lovely Cherry MX key chain HL.
    Some extra pins for the powercables.
    Extra colour sample for future mods.
    On Xmess evening I received a lovely gift from my GF.
    Installed on the MB
    Removed the top of the case.
    Drilled some holes and taped wire in them to mount the res.
    Didn't had much time these days with all the Family dinners and visits to work on the case. Now that it is all past and over I can continue my work.
    Cya next week for a Update.
    Jan 2010
    Lovely design and reservoir!
    Casemodding Addict.
    Apr 2011
    Thank U Kenneth!
    Small update!
    Started with the side panels and top of the case.
    2 layers of Primer
    2 layers of colour
    I am not sure what to do now I might leave the panels like this without the blank lak. Love how the colour looks now so ...
    Apr 2011
    few pictures of how the case look atm. There is still some stuff that need to be made. Before I can paint the frame of the case. Also need to make new front for the case.
    Jan 2010
    wow, verry nice !
    Casemodding Addict.
    Apr 2011
    Thanks Kenneth
    Update
    Still a lot of small thing to do before the case will be ready. To make sure that all the cables are next to each other I used some heatshrink that I cut to small pieces of 3 mm. And glued together with this as result.
    Next step was to add extra details to the top res. Used the same alu bars as on the sidepanel.
    Painted the frame of the case.
    Primer layer
    Finished it with light beige color.
    Cleaned up the mounting bracket for the mobo tray.
    Installed tray and light switch.
    Picture of how it stand now at my place.
    The last piece that had to be created was the front panel for the case. Used a old side panel from a antec case as donor part.
    Glued the 2 pieces together with 2k
    There are still a few thing that need to be made before the case is finished.
    Cya with the next Update.
    Xtreme Cruncher
    Sep 2008
    Kansas City, Missouri
    wow very nice work, cant wait to see a final product.
    ~ Little Slice of Heaven ~
    Lian Li PC-A05NB w/ Gentle Typhoons
    Core i7 860 @ 3gHz w/ Thor's Hammer
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    OZC Vertex3 SSD 240GB
    Apr 2011
    Thank U HuffPCair
    Update !!!!
    4 days left before the case needs to be finished.
    Continued my work on the front. Filled the edges up with 2K filler And sanded it all smooth. Had to repeat this proces several time before it was ready.
    Primer
    Colour on it.
    Next step was to finish the top/res. Started to sand it 240 Grid and ended 2000Grid. After that I polished the top/res with Commandant nr4 to give it a clean bling bling finish.
    Before
    After
    After spending few hour on the top/res. I started with the pump mount. My first idea to attach it on the mobo tray. But with the weight and vibrations I changed my mind. Made the mount from a Aluminum L profile.
    When all the pieces where finished I could finally start with installing all the pieces.
    Big moment filling the loop for the first time.
    Atm there is still no leak.
    Made a short movie of the res with all the rest enjoy
    Next up was cable management. I asked Nate to add some 8x8mm plexi bars with the top/res.
    After some filing and sanding I made this cable holder. Will do the same for all the rest of the power cables.
    That is it again. Still a few thing to do before ready.
    Cya next time!
    Jan 2010
    Looking good alain!
    Casemodding Addict.
  18. #18
    Apr 2011
    Thank U Kenneth
    Lian Li Case Mod Grafit Completed
    How the original case looked like.
    2 months later.
    And something extra for U all a short video of the case.
    http://www.youtube.com/watch?v=0rdHX...ature=youtu.be
    It was a fun project shame that it already is completed. Also tried some new stuff like the top/res and the cable management. I hope U all enjoyed this mod!!!
    On to the next one !
  19. #19
    Jan 2010
    F*&^(^(&*ing awesom !
    Casemodding Addict.
  20. #20
    editor22
    Guest
    Turned out wonderfully Alain congrats
  21. #21
    Sep 2012
    Taipei, Taiwan
    WOW!
    GlobalPR.com.tw | Official Agency for Lian Li
    Visit Lian Li at www.Lian-Li.com
    www.facebook.com/LianLiHQ
  22. #22
    Apr 2011
    Thanks guys ^^
  23. #23
    Dec 2012
    Excellent work... another masterpiece Alain... luv project White... and this one just made my favs list as well... great work as always... mod on!
  24. #24
    Oct 2004
    Canada
    This turned out just gorgeous ! The wiring is spectacular !
    Lian Dream: i7 2600k @ 4.7Ghz, Asus Maximus IV Gene-z, MSI N680GTX Twin Frozr III, 8GB 2x4GB Mushkin Ridgeback, Crucial M4 128GB x2, Plextor PX-755SA, Seasonic 750 X, Lian-li
    HTPC: E5300@3.8, Asus P5Q Pro Turbo, Gigabyte 5750 Silentcell, Mushkin 2GBx2, 2x 500gb Maxtor Raid 1, 300gb Seagate, 74gb Raptor, Seasonic G series 550 Gold, Silverstone LC16m
    Laptop: XPS15z Crucial M4
    Nikon D700 ~ Nikkor 17-35 F2.8 ~ Nikkor 50mm F1.8
    Lian Dream Work Log
    my smugmug
    Heatware
  25. #25
    Oct 2007
    Mid UK. Lift a few rocks, eventually you will find me.
    Respect to your skills
    Fun Box: Asus P8Z68-V GEN3++Corsair AX850++i5 2500k@4.5Ghz-1.272v++Corsair A50++2x8Gb Corsair Vengeance++MSI R7970 Lightning++Audigy2 Plat-EX++TBS 6280 DVB-T2 tuner++256Gb OCZ Vertex 4.500Gb Caviar Black.500Gb Seagate Barracuda++Sony AD7240s++Lian-Li PC-60++Linux Mint/Win 7++Asus P238Q
    Work Box: Gigabyte H61MA-DV3++Corsair HX620++i5 3450@stock++2x8Gb Corsair Vengeance++120Gb OCZ Agility 3++Linux Mint
    Quantum theory in a nutshell: It's so small we don't know where it is, it could be here, it could be there.
    Just 'cos it's legal don't make it right.
