Code:
<cc_config>
<options>
<!--report results immediately, only use when project is running low, otherwise it stressed the servers (0 is default, 1 is immediate)-->
<report_results_immediately>0</report_results_immediately>
<!--Make sure this is larger than the per project number (8 by default)-->
<max_file_xfers>10</max_file_xfers>
<!-- Set this to the number of transfers you would like to allow at the same time (2 by default) -->
<max_file_xfers_per_project>8</max_file_xfers_per_project>
</options>
<log_flags>
</log_flags>
</cc_config>
Have a play with this maybe???
