Page 3 of 3 FirstFirst 123
Results 51 to 69 of 69
Thread: G.SKILL Trident X Series 8GB (2 x 4GB) F3-2400C9D-8GTXD
  1. #51
    Oct 2009
    Quote Originally Posted by Ivanlabrie View Post
    Any new results with these?
    I found a sweet spot for 5GHZ on 3770k, 1.65v on the sticks at 2500mhz.
  2. #52
    Jan 2008
    Athens -> Hellas
    Won't they go down on CL9 in that frequency ?
  3. #53
    May 2007
    Romania
    they will at 1.75+
  4. #54
    Oct 2009
    Quote Originally Posted by Alex-Ro View Post
    they will at 1.75+
    I tried that and it worked.
    CL9 2500mhz 1.75v
  5. #55
    Dec 2012
    Buenos Aires
    Pretty good! Glad those worked out nicely with your mpower man
    Now go for 2800mhz cl9
  6. #56
  7. #57
    Dec 2010
    PA
    This is an old thread but I wanted to share my experiences with this ram. I was able to run 2600 9-11-11 on 1.70v, and I could get 2800 10-12-12 at 1.75v (1.70v crashed). Could not get above 2800 no matter what timings or voltage.
  8. #58
    Jan 2004
    North America
    That looks great, I just bought a set of these sticks for a new build. Awesome ram for the money.
  9. #59
    Xtreme 3DTeam Member
    Aug 2006
    Where You don't get nothin' for $
    This kit is also made for ultra fast running @ 1300MHz:
    Performs much better bandwidth and latency than set @ 1200Mhz CL9.
    Stock volts @ 1.65v.
    32M @ 4GHz only for stability - will get better time - too much stuff running in background.
    Trfc is set to 147. Insane sticks from G.SKILL................
    If nothing works nomore......:
  10. #60
    Aug 2006
    Update - now better 32M @ 4GHz:
  11. #61
    Aug 2006
    Here's 1300MHz @ 4.5GHz:
  12. #62
    Aug 2006
    So this is max I can do with the current CPU - 1300MHz @ 4.8GHz:
    All results on air - CPU cooled by CORSAIR H60.
    Now looking for 5GHz chip...........
  13. #63
    Aug 2006
    So after a long search I was successful - here's the 5GHz chip paired with the GTXD in action:
    BTW, nice fan includet:
    I tried all possible settings @ 1300MHz - changed subtimings also.
    10-12-11-25 or lower is not 100% stable, lowering ref interval & ref cycle time also somtimes freezes. No matter what voltage used. 32M is possible.
    So best @1300MHz for 24/7 is 10-12-11-30 1T. 100% stable @ 1.65v. Left subtimings to AUTO. Faster in 32M than 1200MHz @ 9-11-11-21 1T.
    I'm curious to see them working with BROADWELL K chip on Z97...............
  14. #64
    Aug 2006
    First test 10-12-11-23 1T @ 1300MHz - tREF set to 147 & refCycleTime set to 7936. Small bump on voltage to 1.655:
    About half a second faster compared to 10-12-11-25 1T I was running before @ 4GHz. Will be continiued with testing @ higher CPU speeds.
  15. #65
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    I told you the 2400 C9 would perform much better than the 2400 C10!
    Have fun!
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
  16. #66
    Aug 2006
    Quote Originally Posted by Don_Dan View Post
    Have fun!
  17. #67
    Nov 2005
    The Netherlands
    tried two sets of 2400C9 recently
    set #1 (141625.........) on ASUS Z97:
    set #1 (141625.........) on MSI Z97:
    set #2 (143525.........) on ASUS Z87:
    set #2 (143525.........) on ASUS Z97:
    set #2 (143525.........) on MSI Z97:
  18. #68
    Sep 2014
    Quote Originally Posted by TaPaKaH View Post
    Tapakah, RAM in air?
  19. #69
    Nov 2005
    The Netherlands
    yes, all on air, normal ambients.
