Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 69
Thread: G.SKILL Trident X Series 8GB (2 x 4GB) F3-2400C9D-8GTXD
  1. #26
    May 2008
    Decatur, GA
    Quote Originally Posted by SonDa5 View Post
    Do you know if I can run the mem tweakit app on my MSI Mpower MB?
    I can't see any reason it wouldn't work, but it won't hurt to try it. I'm surprised you're having issues clocking 2600+ on the Mpower, has to be CPU IMC.
    i7 4930K
    32GB Corsair Vengeance Pro DDR3-2400C10
    Asus Rampage IV Black Edition
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  2. #27
    Oct 2009
    Stable 2666mhz with CL 10-12-12-31 2T with 1.7v on DRAM and 1.25v on I/O voltage.
    http://valid.canardpc.com/2587083
    Only thing I have tweaked is the first 4 timings, command rate, DRam voltage and I/O voltage.
  3. #28
    Apr 2012
    Melb, AU
    have you tried at a lower IO voltage? that seems quite high.
    i7 4770K [L315B347]
    Gigabyte Z97 SOC Force
    F3-2600C10D-8GTXD | F3-2666C11Q-16GTXD
    GTX780 Epower2
    Corsair AX1200i
    TRUE Copper| Custom Water | Kingpin Venom 6.66 | Kingpin Tek-9 Fat
    i7 4770K [L312B515] | Asus Max VI Impact | 2x8GB Kingston 1600c10
    600GB WD Velociraptor
    GTX580 Classified
    Silverstone M600W Strider
    Coolermaster Elite 130
    i3 3225 | Asrock B75M Pro3 | 2x4gb Kingston 1333c9
    Intel 520 60GB | LSI 9211-8i | 6x Seagate 4TB
    Silverstone GD08
  4. #29
    Oct 2009
    Quote Originally Posted by AVulgarPicture View Post
    I tired at 1.21v and it wouldn't post. Bumped it up to 1.25v and its stable. I will see if I can bump it down any more.
    2400mhz 9-11-11-28 1T @1.7v dram, 1.21v IO seems seems faster. Faster latency.
  5. #30
    Oct 2007
    Portugal
    my 2400 CL10 trindentX do well.
    tries 9-11-12-14 1T 1.69V and sub​​-timings tight
    just can not get the TRP at 11
    32M stable
    Intel i7 4770k @ 4.5Ghz
    Asrock Z87 OC Formula
    CF R9 290x - WC
    16Gb Avexir Core 2800Mhz
    Samsung SSD 840 128Gb + RAID 0 500Gb F3
    Antec TPQ 1200W
  6. #31
    May 2008
    Decatur, GA
    Under the hood:
    Looks like HYK0 is getting more popular with the enthusiast kits.
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  7. #32
    Jul 2004
    Saint Johns, FL
    That's a stick from your GSkill Trident X quad kit with the HYK0? Wonder if Corsair is going to/has started using them.
    In memory of Gracie, my sweet, sweet wife and mother of my children. Darling, we will miss you dearly. May you rest in peace (born to this world on March 30, 1976; went to her Heavenly Father on Good Friday, April 22, 2011).
    http://animoto.com/play/E0wFhd6tN0nA...ent=challenger
    Heat
  8. #33
    May 2008
    Decatur, GA
    Quote Originally Posted by Reefa_Madness View Post
    Yep, the 2400 C9 4x4GB kit.
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  9. #34
    Aug 2008
    Atlanta
    Quote Originally Posted by Shiranui Gen-An View Post
    I noticed that your 4x4GB kit has a 2500 series serial number like my 2x4GB 2666C10 kit which also has a 2500 series where as SonDa's 2x4GB kit is a 1500 series with HCH9.
    Ryzen 9 on the test bench... Sometimes older generation/tech as well.
  10. #35
    Jul 2004
    Saint Johns, FL
    I noticed that 1500 vs 2500 difference myself after seeing his pics and comparing labels and was wondering if the fifth digit of the serial # was being used by GSkill to distinguish between the type of Samsung chip being used (with the 6-8th identifying the manufacturer). But then I thought about the fact that some of the Trident X 2400 CL10 "1500" were single-sided and some were double-sided and using different density ICs. Maybe density doesn't matter and only type of IC is used to differentiate.
    ...or maybe they are just getting a good laugh out of all of this and continuing to mess with our heads???
    Heat
  11. #36
    Jul 2008
    In the space between...
    lol...there's no tellin'. It'd be nice if a GSkill rep would chime in...but that'd ruin all their fun.
    'Best Bang For The Buck' Build - CM Storm Sniper - CM V8 GTS HSF
    2500K @ 4.5GHz 24/7 - Asus P8Z68-V Pro Gen3 - GSkill 2x4GB DDR3-2400 C10
    Sapphire Vapor-X 7770 OC Edition - PC Power & Cooling Silencer MkIII 600W
    Boot: 2x 64GB SuperSSpeed S301 SLC Raid 0 Work: Intel 520 120GB
    Storage: Crucial M500 1TB - Ocz Vertex 4 128GB - 4x 50GB Ocz Vertex 2
    HDDs: 2 x 1TB WD RE4 Raid0 - Ext.Backup: 2 x 1.5TB WD Blacks Raid 1
  12. #37
    Jul 2004
    Saint Johns, FL
    Quote Originally Posted by PolRoger View Post
    In post #24 of this thread, ihog6hog posted a pic of a 2666 C10 kit with HYK0...and also with the "2500" series number.
    http://www.xtremesystems.org/forums/...2666c10d-8gtxd
    Heat
  13. #38
    Aug 2008
    Atlanta
    Some tests of another retail 2x4GB kit with "2500" serial number...HYK0?? I haven't removed the heatspreader to confirm ic. Running an ASUS MVG/3570K... BIOS 1309
    2400 9-11-11-28-1T 1.595v dram - Samsung 2x4GB medium preset:
    2400 9-11-11-28-1T 1.615v dram - auto subs: (note: Higher MemTweakit efficiency score with auto at 2400 vs. Samsung medium preset)
    2600 10-12-12-28-1T 1.585v dram - auto subs:
    2600 10-12-12-25-1T 1.600v dram - Samsung 2x4GB medium preset:
    2666 10-12-12-31-1T 1.660v dram - auto subs: (note: The imc of my 3570K is not as strong when running 2666 speeds vs. 2400/2600)
    2666 11-13-13-31-1T 1.660v dram - Samsung 2x4Gb medium preset:
  14. #39
    Jan 2008
    Athens -> Hellas
    This kit is standard Dual Sided, right ? Or one may bump onto a Single Sided 2400-C9 Trident X kit ?
  15. #40
    Jul 2004
    Saint Johns, FL
    Those single-sided Trident X kits were C10, not these newer C9 kits.
    Heat
  16. #41
    Jan 2008
    Athens -> Hellas
    Yeap, i remember, i hope G.Skill doesn't change this till i get them...
  17. #42
    Dec 2011
    So I have also testet these Kit here an score
  18. #43
    Jan 2008
    Athens -> Hellas
    Just ordered...Hope i have it before the world ends...
  19. #44
    Jul 2004
    Saint Johns, FL
    Quote Originally Posted by Crazzy85 View Post
    Pretty good results from that 2400 C9 kit.
    I'm curious, do those have the "1500", or the "2500" for the 5th thru 8th digits of the S/N?
    Heat
  20. #45
    Jul 2010
    Berlin, germany
    My old mems - 2500, in fact these ran good at my rig and even better at crazzys
  21. #46
    Jun 2007
    Long Beach, CA
    Just got a pair about a week ago 1500 series only hope they are do well... Waiting for a Asus MEV Gene to have some fun maybe even the Gygabyte Z77X- UP7 orange monster..
    Guys is it easier to OC memory/cpu with only using 2-4cores running superpi32?
    CPU: Intel Core i7-4770K 4.8GHz
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
    GPU: 2 x eVGA GTX 780 SC
    SOUND KRK Rokit 5 Limited Edition White Studio Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
  22. #47
    Jan 2008
    Athens -> Hellas
    I just received my kit....2x4GB...batch is 13012500...don't have it in front of me yet...tomorrow...but still no board...
  23. #48
    May 2008
    Decatur, GA
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  24. #49
    Oct 2009
    Quote Originally Posted by felix_w View Post
    I just got another 8GB kit. This time batch number is 13021500 built in January 2013. Haven't looked at the IC yet but these are also double sided. At 2400mhz xmp settings they work well. Hope hey have the Samsung HCH9 IC.
  25. #50
    Dec 2012
    Buenos Aires
    Any new results with these?
