Goal:
I carry my PC around quite often and have made a few different builds of PCs in Briefcases. However those were larger and heaver than what I needed. I spent nearly a year designing the case for specific pieces while still trying to keep it in standards for if I needed to swap things out. The build had to be compact, lighter, and look good.
Features:
Very Compact Size. Overall dimensions are 9.5" x 11" x 18.5". Its actual size is nearly the same as the Silverstone FT03, except mine includes a rather large radiator. Siting next to a typical mid tower it looks half the size.
Can Sit or Stand. There are case feet on the bottom and the side, allowing the case to be laid down to sit up
Handles for Travel. Easily removed carrying handles for quick travel when needed.
Lightweight. Total weight for PC is under 30lbs
Silent. A few GT AP-15s at low speed and low speed pump make the PC about as close to inaudible as possible.
Cool. The triple 120mm radiator is more than enough to keep an OCed 2500k and GTX-680 and the Motherboard, all cooler than a decent Heatsink could at these noise levels.
Any GPU. Enough room for Graphics Cards up to 13" in either slot.
Key Started. Uses a Momentary Key Switch to start the PC. Honestly this purchase was by random luck. Only $11 for this compared to nearly $20 for a LED Momentary Switch that is not nearly as awesome.
Hot Swap. Can hold two 2.5" Hard Drives with easy removal.
Looks Good. Don't you agree?
Hardware:
Maxiums IV Gene
2500k
2x 1866 CL-9 4GB Corsair Sniper
Zotac GTX-680
128GB Crucial C300
500GB Segate Momentus XT
650W Seasonic Gold Rated PSU
Water Cooling:
Swiftech Apogee Low Profile CPU Block
Swiftech MCR-320 Drive Radiator w/ PWM MCP35X Pump
EK GeForce 680 GTX Block - Acetal+EN (Nickel)
EK-MOSFET Max IV Gene Block - Acetal+EN (Nickel)
Gentle Typhoon AP-15 1800rpm Fans
PrimoFlex Pro LRT UV Red Tubing - 3/8in ID x 5/8in OD
Enzotech G1/4" Thread 90-Degree Rotary Barb Fitting - 3/8" ID Matte Black
Enzotech G1/4" Thread Barb Fitting - 3/8" - Matte Black
Koolance Hose Clamp 16mm
Other PC Parts:
I/O Shield for Danger Den or Custom Cases - 7 Slot
Manhattan SATA Drive Rack Dual Drive, L-type, Internal, 2.5"
Bitspower Mesh Radguard 360 - Black Aluminum
2x Lian Li Case Feet - SD-01B 4pack - Black
NZXT Premium Sleeved Bright LED Kit - 2 Meter - Red
McMaster-Carr Build Parts:
Key Switch - Momentary - Screw Terminal
Plastic-head Thumb Screw With Socket Drive, 6-32 Thread, 13/32" Length
Scratch-resistant Clear Cast Acrylic Sheet, 7/32" - Black and Clear
End Results:
Some nice DSLR Images
My brother was in town and brought his Nikon D60. So we picked up a tripod and remote to get the best image accuracy. Built a photo-tent about 3ft wide and deep and almost 4ft tall. And had some fun. After that weekend I was almost ready to drop nearly a grand on a nice camera myself.
Playing with different Exposure times on the camera. The first I think is about 2 seconds, the last is about 30 seconds, all with the ISO as low as it could handle.
