Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: GPU supported?
  1. #26
    Xtreme Cruncher
    Dec 2008
    Texas
    Quote Originally Posted by Movieman View Post
    I think it's time I had a nice "short" phone call with chispy..
    Definition of short: Any time frame that is less than the storage time on my cordless battery pack..
    Ah, you're letting him off easy! IIRC, last time we talked your battery died... mine was still at 60 something %... either dave needs a new phone or I got really lucky...
    People have noticed that I'm a little hard of hearing in my right ear though...
    24 hour prime stable? Please, I'm 24/7/365 WCG stable!
    So you can do Furmark, Can you Grid???
  2. #27
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Quote Originally Posted by Otis11 View Post
    Bingo..My panasonic cordless needs replacing..
    Might have something to do with the night I got pissed off and tossed it at a wall.
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
  3. #28
    Apr 2010
    NC
    I don't know about yours, but I have a panasonic that will take regular NiMH AAA batteries. A couple of rechargeable batteries would be quite a bit cheaper than a new phone. Have you checked to see what type of batteries yours uses?
    Click image for larger version.
ID:	130890Click image for larger version.
  4. #29
    Nov 2005
    New Hampshire
    Quote Originally Posted by pirogue View Post
    mine has 3 AAA's tied together with a connector to the phone
  5. #30
    Apr 2010
    NC
    I've seen that type of battery in the store before. You should be able to just buy the battery pack, which would still be cheaper than a new phone. Try searching for the battery pack/phone model number on amazon.
  6. #31
    Jun 2010
    Crab Nebula
    Quote Originally Posted by werdwerdus View Post
    if it's winxp then you have to use version 11 drivers to have opencl, but not sure if versions 11 drivers support 6xxx series (I think so)
    They do. I use 11.8 on my lone XP box but I've heard up to 12.1 will work.
    You'll never know what you're living for until you know what you're willing to die for.
  7. #32
    May 2009
    middle of no where called evansville in
    im stuck
    i have a GTX 275 that was running
    and now its not
    i paused the work to actually do homework
    and now its thrown in the towel
    how do i restart this darn thing
    i want to tear up some WU's :P
  8. #33
    Jan 2008
    Athens -> Hellas
    I just tried my Firepro V7900 :
    Is the result ok ?
    It was 100% at 4:01minutes
  9. #34
    Nov 2005
    New Hampshire
    Quote Originally Posted by felix_w View Post
    Is the result ok ?
    Perfect!
  10. #35
    Jan 2008
    Athens -> Hellas
    Thanx, can i improve the stuttering thing while running gpu WU's ?
    I mean, is there any way to reduce a bit the use of the gpu to leave some power for the machine to be usable for basics ?
    EDIT : Maybe i do need that EK VGA Supreme HF, finally...68?C is increasing in-case temperature...
  11. #36
    Nov 2005
    New Hampshire
    There may be but I'm not sure.
    Your card is doing app the same work/time as my 5870 card but my card is at 48C with fans at 60% BUT in a open case..
  12. #37
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    Quote Originally Posted by disturbed13 View Post
    im stuck
    and now its not
    In BOINC Manager do you have the "Use GPU while computer is use" checked on?
    If all else fails turn BOINC off completely and restart, then post the messages from the event log here so we can take a look.
  13. #38
    Xtreme Cruncher
    Mar 2009
    kingston.ma
    Unfortuntely no, I really don't think there is no way to reduce the internal gpu usage as this is all a matter of the OpenCL implementation and the way the app itself was coded.
