Weird, I only run GPU WU's in my 7970 rig with this setup:
GPU: HD7970(Ref. PCB not sure which brand as GPU-z only shows ATI) stock 925/1325MHz OC'ed to 1000/1325MHz on stock volts.
CPU: 3770K OC'ed to 4,7GHz(Water cooled)
Mobo: Asus Maximus V Gene
Memory: 8GB G.Skill RipjawsZ 2133 CL 9
SSD: 120GB OCZ Vertex3
PSU: cheap 450W
running on Win7 ultimate with Boinc 7.0.28 and the AMD app_info.xml
24/7 Cruncher #1
Crosshair VII Hero, Ryzen 3900X, 4.0 GHz @ 1.225v, Arctic Liquid Freezer II 420 AIO, 4x8GB GSKILL 3600MHz C15, ASUS TUF 3090 OC
Samsung 980 1TB NVMe, Samsung 870 QVO 1TB, 2x10TB WD Red RAID1, Win 10 Pro, Enthoo Luxe TG, EVGA SuperNOVA 1200W P2
24/7 Cruncher #2
ASRock X470 Taichi, Ryzen 3900X, 4.0 GHz @ 1.225v, Arctic Liquid Freezer 280 AIO, 2x16GB GSKILL NEO 3600MHz C16, EVGA 3080ti FTW3 Ultra
Samsung 970 EVO 250GB NVMe, Samsung 870 EVO 500GBWin 10 Ent, Enthoo Pro, Seasonic FOCUS Plus 850W
24/7 Cruncher #3
GA-P67A-UD4-B3 BIOS F8 mod, 2600k (L051B138) @ 4.5 GHz, 1.260v full load, Arctic Liquid 120, (Boots Win @ 5.6 GHz per Massman binning)
Samsung Green 4x4GB @2133 C10, EVGA 2080ti FTW3 Hybrid, Samsung 870 EVO 500GB, 2x1TB WD Red RAID1, Win10 Ent, Rosewill Rise, EVGA SuperNOVA 1300W G2
24/7 Cruncher #4 ... Crucial M225 64GB SSD Donated to Endurance Testing (Died at 968 TB of writes...no that is not a typo!)
GA-EP45T-UD3LR BIOS F10 modded, Q6600 G0 VID 1.212 (L731B536), 3.6 GHz 9x400 @ 1.312v full load, Zerotherm Zen FZ120
OCZ 2x2GB DDR3-1600MHz C7, Gigabyte 7950 @1200/1250, Crucial MX100 128GB, 2x1TB WD Red RAID1, Win10 Ent, Centurion 590, XFX PRO650W
Music System
SB Server->SB Touch w/Android Tablet as a remote->Denon AVR-X3300W->JBL Studio Series Floorstanding Speakers, JBL LS Center, 2x SVS SB-2000 Subs
It looked to be working fine running 2 WU's. But it got stuck right after I checked it this morning. When I got home from work it was stuck on 2 WU's for 10 hours.
It worked fine a lot longer, but it isn't fixed yet after the registry change.
For anyone using firefox and having weird hanging/driver not responding errors, check this:
https://support.mozilla.org/en-US/questions/935632
I just disabled it because I started having problems and it seemed to always be while I was browsing. I don't know if it's the solution, but it appears the hardware acceleration is not ready for prime time.
Yin|Gigabyte GA-Z68X-UD5-B3|Swiftech XT -> GTX240 -> DDC+ w/ Petra's|2600K @ 5.0GHz @1.368V |4 x 4 GB G.Skill Eco DDR3-1600-8-8-8-24|Asus DirectCUII GTX670|120 GB Crucial M4|2 x 2 TB Seagate LP(Raid-0)|Plextor 755-SA|Auzentech Prelude 7.1|Seasonic M12-700|Lian-Li PC-6077B (Heavily Modded)
Squire|Shuttle SD36G5M| R.I.P.
i7 3970X @ 4500MHz 1.28v
Asus Rampage IV Extreme
4x4GB Corsair Dominator GT 2133MHz 9-11-10-27
Gigabyte Windforce 7970 OC 3-way Crossfire
Windows 7 Ultimate x64
HK 3.0-MCP655-Phobya 400mm rad
Corsair AX1200i
Sandisk Exrtreme 240GB
3x2TB WD Greens for storage
TT Armor VA8003SWA
So my 7950 I have in a box beside me should handle 8 threads...
For sure! When I first fire it up I like to pause all the WU and then resume them 2 at a time in stages so the get spread out in their start and finish times.
Corsair AX1200i
TT Armor VA8003SWA
That's a good idea.
Vinas's multi client method takes care of that itself fairly nicely. I don't feel like setting up 8 seperate clients though. Think I will stick to app_info for this one lol
EDIT:
Hey fellow SK'er where you located?
Main: Gulftown i7-970 4.00 Ghz | G.Skill 24GB DDR3 | Sapphire 7970 | Samsung 830 2x256GB | Lian Li PC6070B
File Server: Dual Westmere-EP E5645 2.40 Ghz | Super Micro X8DTi-F | PERC 5/i | Samsung 8x2TB | Norco 4224
ESXi Host: Dual Harpertown E5450 3.00 Ghz | 8GB ECC DDR2 | 4x36.6GB 15k RPM | HP DL380 G5
Great, nice to know. Is the PC still usable running 4? May have to try it out until I get my 2nd card and use up all 8 of my threads.
Thanks for the tip on staggering the WU to keep the GPU loaded at all times. Should help keep temps more stabalized.
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
Everytime I had a crash with my 7870 it was always when browsing or idle, never under load. Make me think an issue with 2D clocks/volts or even a DirectX issue. I'm cleaning out my drivers and going back to 12.3 as I've read it doesn't happen on that driver version. Who knows, but we'll see soon enough.
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
Here is the link to the actual microsoft article
http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
Even says in there the code is complex and could cause compatibility issues with drivers. I am surprised this isn't a more widely known fix to the 1000's of people having issues with this.
Corsair AX1200i
TT Armor VA8003SWA
I'm pretty jealous of you all. I'm trying to sell my GTX 570 to get a 7950 to take advantage of the just announced game bundle and to get some crazy numbers on WCG. The 570 struggles on this app.
Some call it HCC GPU and others call it a game bundle.
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Yeah, congrats One.shot. That first one is a nice one. And the start of more and more points...............and rigs............and upgrades..........
