Ok, Since I didn't see anything over here about GPU overclocking, I'm starting this from my post over at the GPUGrid section- this is going to be continually under construction to compile as much knowledge as we can about how to get the most out of our cards. So here it goes, please feel free to add/make suggestions to this:
Notes Before Starting:
For WCG, core clocks (???) have the largest impact on points. Memory makes no difference. Dedicated crunchers can actually drop the mem. freq. to keep temps down/save power. Doing so may impact gaming performance though. Effects of shader speeds have not been determined, but are slight at best. (???)
Although graphics cards (105C) tend to be rated higher than CPUs (with some exceptions - 70C), we recommend bumping up the fan speed also. These chips were designed for high temps, but not to hold those temps 24/7. (IMO - Temps below 80C are acceptable, but opinions vary). Also, we've found over at GPUGrid that it is well worth cranking you fan as high as is bearable - CPU temps have a significant impact on power draw, especially for higher end cards! Lower your temps, Lower your power consumption!
As long as Temps are kept in check, hardware longevity should not be an issue.
WCG Stable OCs:
(please give these a week to let your RAC settle and make sure it is stable- aka no errors. Also, please note 24/7 or not)
Numbers after card are PPD/Avg Price= ppd/$
HD7970:930k/$369 = 2.52k
1125 core/1425 mem - pirogue ~930K PPD WCG
.......... Tasks: 8 .......... OS: Win 7.......... Brand: XFX DD Black Edition.......... Cooling: Stock fan @ 55% .......... Voltage: Stock .......... Temp: 55°C
HD7950:750k/$290 = 2.58k
850/1000- Bun-Bun ~750K PPD WCG (200w @ wall 2600k @ 4.5GHz)
.......... Tasks: 8 .......... OS: Win 7.......... Brand: Asus.......... Cooling: Stock fan @ 40% .......... Voltage: Stock .......... Temp: 43°C
HD7870:540k/$230 = 2.35k
HD7850:325k/$175 = 1.86k
860/925- Bun-Bun ~200K PPD WCG
.......... Tasks: 2 .......... OS: Win 7.......... Brand: Asus/Sapphire.......... Cooling: Stock fan @ auto% .......... Voltage: Stock .......... Temp: 50°C
960/1200- kjeldoran ~325K PPD WCG
.......... Tasks: 4 .......... OS: Win 7.......... Brand: Visiontek.......... Cooling: Stock fan @ 55% .......... Voltage: Stock .......... Temp: 70C
HD5870:140k
900- OldChap ~127K PPD WCG
.......... Tasks: 2 .......... OS: Win 7.......... Brand: xfx.......... Cooling: Stock fan @ 60% .......... Voltage: Stock .......... Temp: 48°C
.......... Tasks: 2 .......... OS: Win 7.......... Brand: ati?.......... Cooling: Stock fan @ 60% .......... Voltage: Stock .......... Temp: 60°C
1000- OldChap ~145K PPD WCG
.......... Tasks: 2 .......... OS: Win 7.......... Brand: asus.......... Cooling: Stock fan @ 60% .......... Voltage: 1.275.......... Temp: 43-60°C
.......... Tasks: 2 .......... OS: Win 7.......... Brand: asus.......... Cooling: Stock fan @ 60% .......... Voltage: 1.275.......... Temp: 40-55°C
HD5850:??k/??k
800/1000- Jaco ~??K PPD WCG
.......... Tasks:?? .......... OS: Win 7.......... Brand: Sapphire.......... Cooling: Stock fan @ 43% .......... Voltage: Stock .......... Temp: 55°C
850- OldChap~96K PPD WCG
.......... Tasks: 2 .......... OS: Win 7.......... Brand: Sapphire.......... Cooling: Stock fan @ 60% .......... Voltage: Stock .......... Temp: 39-45°C
GTX 670:??k/??k
1050/1215- Bun-Bun ~100-200K PPD WCG
.......... Tasks: 2 .......... OS: Win 7.......... Brand: Asus.......... Cooling: Stock fan @ 75% .......... Voltage: Stock .......... Temp: 49°C
GTX 460:??k/??k
850/1133/1800- Otis11 ~55K PPD WCG (This points value is not accurate yet)
.......... Tasks: 1 .......... OS: Win 7.......... Brand: EVGA.......... Cooling: Stock fan @ 60% .......... Voltage: Stock .......... Temp: 41-51C
Please help me build this - The more info we have the better we can do. Please post your info in this format in the PHP bracket if possible. Makes my job easier.
Tools:PHP Code:
GPU - GTX 460
[SIZE="1"].......... Tasks: 1 .......... OS: Win 7.......... Brand: EVGA.......... Cooling: Stock fan @ 60% .......... Voltage: Stock .......... Temp: 41-51C [/SIZE]
Voltage Tuner Thread - Thanks Ikiller123
EVGA Precision
RivaTuner
CUDA mem test - Thanks PG
Also, If you have any tools or just other suggestions - please, sound off in the comments. Let's do this!
