Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: XS 3DMark01 5.0Ghz Ivy LCC
  1. #26
    May 2007
    Hampshire, UK
    Quote Originally Posted by Deux View Post
    Haven't run much 01 on IB yet myself, only a bit on SB, so I may be way off base here. I would guess you're taking most of that hit from using a 680 instead of a 580 with 285.38. There is a chance that a different driver may score better, unlike 11/heaven newer isn't always better for 01
    I guess so thing is I really don't know as I haven't run 01 for years. I have read a lot of stuff on the net looking for tips & can't find anything I don't already know (which aint much tbh) I also accept the 580 is the 01 king & that don't bother me I love my quiet 680 (ex ATI owner) but would like to just tweak, mess about & gain a few points/some knowledge. I'm kind of stuck I got my best score in hours..... no tweak fun!!
    I think I will have to play drivers & see what happens.... thanks for the post
    Home / Play Rig Asrock Z87 OC Formula/AC, i7 4770K L310B487, 8GB Corsair Dominator Platinum 2666 CL10, BeQuiet Dark Power Pro P8 1200W PSU, 120GB Corsair Force GT SSD, 2 x 1TB WD Sata Drives Mirrored, Palit 680GTX JetStream, Antec Kuhler 920, Windows 10 Pro, Logitech LX700 Deskset, AOC 27" Monitor.
    Work 24/7 Rig Gigabyte GA-Z97X-SOC Force, i7 4790K L418C133 ,8GB Team Xtreem LV 2600, PC Power & Cooling 850WPSU, 120GB OCZ Vertex 3 SSD, 2 x 500GB Hitachi Sata Drives Mirrored, Antec Kuhler 620, Windows 10 Pro 64 Bit, Logitech LX700 Deskset, Benq 27" Monitor.
    Home NAS DFI P35 T2RL Motherboard, Intel E6850 CPU, 8GB Nanya DDR2 6400, 2X 2TB Toshiba DT01ACA200 SATA Drives, ZFS RAID Mirror On Intel ICH9 AHCI, Artic Blue 850W PSU, Marvell Yukon 88E8053 Gigabit Ethernet, FreeNAS 9.2.1.5 RC, 64-Bit On 4GB USB2 SanDisk Cruizer Blade Thumb Drive.
  2. #27
    PI in the face
    Nov 2008
    damn, Im at 113k hahaha need to push my 580 only at 900/1050 atm
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
  3. #28
    Xtreme Memory Hoarder
    Mar 2010
    Quote Originally Posted by Splave View Post
    Awaiting your most excellent results bro
    Thinking I need to redo my sub as it has been a bit quite in here
    Quote Originally Posted by Hondacity View Post
    gskillllin it!
  4. #29
    PI in the face
    Nov 2008
    found a small boost, car high turn compatibility bits off and just run with LOD
  5. #30
    May 2007
    Romania
    how much faster is ivy bridge clock per clock compared to sandy in 3dm 2001?
  6. #31
    PI in the face
    Nov 2008
    my findings so far
    run order: Nature first (only thing that seems to matter)
    If you get lucky run on both car high and low you will have a good score. approx 300 point boost.
    133 memory reference clock dividers are best, aka 2400/2666 better then 2600/2800 by about 500-600 points and scores seem more stable less variations.
    3.375-3.50 is best for nature with 580, and I use 10 on all other test.
    Downclocking memory for car low has given me better scores on average (2500mhz down to 2380mhz)
    going to run at billy's card clocks now to compare, on air I can only do 1000/1250
  7. #32
    May 2007
    Romania
    I can't understand squat,i have very good fps in all other tests except nature,where i get 1520 at 1000/4800 or 1550 at 1040/4800.Lod 3.5 comp bits with inspector,nature first,all things done properly but i miss nature by far.Need about 60-70 fps and don't know what is wrong,d3d overrider on too...Other setting in inspector have a big impact on nature or should i reinstall windows...)
  8. #33
    May 2007
    Romania
    Oh and tried 285.38 and 285.58 drivers too,not a single difference...
  9. #34
    Xtreme Enthusiast Gunslinger's Avatar
    Jan 2007
    Decatur, AL
    What board?
    Quote Originally Posted by chuchnit View Post
    Why do you always have to bring two sockets into everything?
    Quote Originally Posted by Movieman View Post
    Because a one socket system is only 1/2 a system..
    You got two balls don't you?
    I rest my case!
    http://www.usdebtclock.org/
  10. #35
    Nov 2006
    Extreme Tweak enable in bios if use asus ?
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
  11. #36
    May 2007
    Romania
    V formula and yes extreme tweaking is on
  12. #37
    PI in the face
    Nov 2008
    ^ do you have Triple buffering enabled in nvidia control panel?
  13. #38
    May 2007
    Romania
    Hmm,not in nvidia control panel,i think i checked it in inspector.Bios is 0804.To be more specific,the other tests are fine,ch,dh,lh ,low's etc are all in good range,but nature is not.1520 at 1000/4800 or 1550 fps at 1040/4800 so i am off at least 70 fps...
  14. #39
    PI in the face
    Nov 2008
    you running nature first? that would make the difference
  15. #40
    May 2007
    Romania
    yes,nature first ill try what you said,then another bios and clean windows.After that...i am out of ideas.
  16. #41
    Jan 2007
    Decatur, AL
    Are you running PCI-E gen 3?
    I rest my case!
  17. #42
    May 2007
    Romania
    Yes,installed anotger sp3 same deal,tried other old sp2 windows and boom gained 100fps,so Problem solved guys,thanks
  18. #43
    May 2007
    Romania
    So first score is 120268,think i need to change the driver to .38 version and see what's up.
  19. #44
    Jul 2008
    Czech Republic
    117339 and finding what I am doing wrong...screenshot only after better result
