"Inspired by Hondacity"
3DMark01 5.0Ghz Ivy LCC
1. Screenshot Requirements:
- 5.0Ghzghz +/- 1mhz
- 3DMark01 main window with details tab
- cpuz: cpu tab + memory tab + motherboard tab + gpuz + memtweakit
- no limitations on hardware or cooling
2. Ranking requirements (use following format):
Username - score - multi x blck - vga clocks (core/shader/memory) - ram speed(xxxx.yy)mhz - ram sub-timing(tCL-tRCD-tRP-tRAS-tRFC-CR) - Motherboard model - ram info/chipset/vga model - cpu/ram cooling
ZenEffect - 128452 - 50x100 - 900/2040/1080 - 1333.8 - 8-11-6-19-232-1 - Gigabyte UD5 - Kingston 2333mhz 2x1gb/BBSE/Asus GTX 580 DirectCuII - stock air
- Billy-The-Kid - 121697 - 57X106.4 - 1020/1225 - 1276.5 - 8-11-8-24-78-1 - ASRock Z77 OC Formula - Gskill Trident/ BBSE / Msi GTX 580 Lightning Extreme - cpu air / vga air / memory air 1.85v
- Mikecdm - 121376 - 50x100 - 950/1200 - 1200.1 - 8-12-8-28-88-1 - Asrock Z77 OC Formula - Sector 5 2400 9-11-9-27 / PSC / MSI GTX 580 Lightning - cpu air / vga air / memory air 1.8v
- Gunslinger - 121311 - 50X100.0 - 1000/2000/1250 - 1300.0 - 10-12-12-27-209-1 - Asus MVE - Gskill TridentX / EVGA GTX 580 Classified Ultra - CPU air / GPU air / RAM air 1.7V
- M.Beier - 120240 - 48X104.1 - 1055/1217 - 1249.7 - 8-11-8-26-88-1 - ASRock Z77 Extreme6 - Corsair GTX3 / PSC / Gigabyte SOC GTX 580 - cpu water / vga water / memory air 1.84v
- l0ud_sil3nc3 - 120229 - 47X106.4 - 1020/1080 - 1170.1 - 8-11-7-27-88-1 - Asrock Z77 OC Formula - G.Skill RipjawZ 2400 8-11-11-30 / PSC / MSI GTX 580 Lightning - cpu LN2 / vga air / memory air 1.8v
- C-N - 119845 - 50X100 - 1200/1750 - 1400.0 - 11-14-14-36-147-1 - GA-Z77X-UD5H - Team LV2666 Samsung / Palait GTX 680 Jetstream - CPU Kuhler 620 Water / VGA Air / RAM Air 1.70v
First sub, testing 3226C209
l0ud_sil3nc3 - 120229 - 47X106.4 - 1020/2040/1080 - 1170.1 - 8-11-7-27-88-1 - Asrock Z77 OC Formula - G.Skill 2400 8-11-11-30 / PSC / MSI GTX 580 Lightning - cpu LN2 / vga air / memory air 1.8v
