Results 1 to 20 of 20
Thread: nickel flaking off koolance qdcs?
    Sep 2011
    hi i am in between upgrading mypc and just removed the qdcs from my gfx loop and noticed the qdcs i have have begun flaking. i also took apart my koolance dual bay res to find tiny little flakes in side. is this normal?
    Xtreme Mentor
    Oct 2007
    USA
    No.
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Aug 2010
    london, UK
    Pics please?
    Nov 2009
    Netherlands
    Yeah, I'd like to see some pictures as well. Also contact Koolance with those pictures.
    “Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's Guide
    It's better to ask dumb questions now, than to look stupid later
    Mondays:
    Mar 2011
    Definitely not normal. I have four QDC's and none of mine have flaked like that after years of use.
    Sep 2011
    Click image for larger version.
ID:	130460Click image for larger version.
ID:	130461Click image for larger version.
    At work atm so uploaded via tapatalk on my phone last pic is of the part of the res used for gfx loop
    Not looking forward to opening my gfx card blocks tonite:/ I hope they are ok as I was going to sell them on
    Sep 2004
    Is that copper deposited on the silver coil wrapped around a part of the reservoir?
    Administrator andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    Not surprised at all..some time ago i bought some EK products and the barbs came in a plastic bag and on the bottom of the bag lots of small pieces of nickel, so i told them and they say it was impossible but well i shoot some pics and it was very clear
    so if it goes out easy not even built i can imagine that inside the loop they will
    happened the same with other brands, from that time till now i use only Bistpower True Silver amazing barbs
    Cheers and good luck
    Sergio
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Yeah, I'm not so sure that it's the QDC's flaking but rather copper being deposited on them and the res tube. I remember utnorris had something similar happen to his res tube and it did come off by wiping/scraping it. If you have nickel flakes, it's likely either EK or bitspower that is causing that mess. What else was in the loop?
    Circles SucQ!
    Sep 2011
    this loop had 2 eK 580gtx acetel/copper blocks the serial link attachment and ek 140.3 rad the silver coil & the valve its wraped round had very dark residue on it and that pipe above has gone dark cant be cleaned. i had no idea this had happened as the res had blue leds on both sides you could not tell anything was wrong. i shall try scraping the qdcs tnoite to see what happens
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Meh, everyone hates on EK nickel to but to be totally blunt EVERY brand of fitting I have had (Swiftech, EK, Dtek, Bitspower) have all had the nickel come off in a few spots somewhere.
    If I could get non-plated barbs I'd do that in a heartbeat.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Sep 2011
    no body is hating on ek, my other fittings are phobya i think which i got from aquatuing, the block are copper but yet too look inside them.
    also thanks for the pointer on utnorris. and id rather not scrap it specialy the the female fitting. couldnt i just dunk them in vinigar and give them a good wipre down?
    also you cant see it in the pic but the fittings on P2 both in and out arnt shut properly
Name:	Photo 05-10-2012 12 49 42.jpg
    Registered User StinkEye's Avatar
    Feb 2008
    North Carolina
    Koolance addressed the issue of some QDCs not sealing properly, wrong O-rings if I remember correctly. If you contact them I believe they will replace them.
    ASUS ROG Zenith Extreme
    AMD Ryzen TR 1950X @ 4GHz
    Corsair AX1600i
    32 Gb Corsair Vengeance LED 3200MHz (16-18-18-36)
    2 x Asus ROG Strix Vega 64
    Sound BlasterX AE-5
    Samsung SSD 950 Pro 512Gb, Samsung 850 Pro, 3 x Samsung 850 EVO, 2 x Samsung 860 EVO
    2 x Koolance RP-1250 (Corsair SP120 Fans)
    2 x Koolance 480mm Copper Radiators (20 FPI)
    XSPC RayStorm Neo TR4
    EK-FC Vega Strix
    Corsair Obsidian 900D (Corsair AF120/140 fans)
    Sep 2011
    well it might not be flaking, the pipe from the res i put in a plastic cup of diluted vinigar we get at work today during my lunch break and it all wiped off. as for the the qdcs is wiped them with tissues and nothing but a my friend gave them a firm rub and bits kinda rubbed off a little cant get them any more cleaner. flushed the rad and it was clean still got to take the blocks apart to see if they are clean inside or not.
    Xtreme Mentor
    Oct 2007
    USA
    In an industrial setting (I am in one), we see this but WC loops are different.
    Metals, no matter the type (kinda) have an affinity for each other. Water is a great dissolver, going round and round in a WC loop forever. Molecules of the metals break loose and deposit where the science says they should. It's material science. I don't know a lot but the basics and 5 years watercooling, but yep, you seem to be fine.
    Maybe next time dig deeper and see what is up before, thanks for the update, wait till you see the inside of your blocks. Material science and the power of H2O..
    SLI GTX470 EVGA
    Sep 2011
    sorry for taking so long to reply just been so busy. i finaly got round to opening my blocks
    both look the same i was prepared for it looking tarnished but near the bottom just below the wave lines there is some corrosion :/
    also got a reply from koolance last week, they said distilled water + killcoil is not recomended with the res and it would only cover the bio side and did not offer any protection from corrosion.
    and recomended thier own liquid. id buy it but i already got a 5l tub of distilled water few days before i got the email from koolance. so what additives would you peeps recomend? primochill utopia?
    I am Xtreme
    Dec 2006
    I still think silver in ppl's loops is the problem with people experiencing these kinda problems with tubing going all white on the inside and nickle flasking
    Just run coolant and see what happens or throw in some liquid utopia
  18. #18
    Xtreme Mentor
    Oct 2007
    USA
    Block looks perfectly normal. It's what water does to stuff.
    Dump the distilled and run fancy liquids.
    And read up on things like this:
    http://www.overclockers.com/forums/s...d.php?t=717099
    http://www.xtremesystems.org/forums/...66#post4544766
    http://www.xtremesystems.org/forums/...ve-fluid-video!
    http://www.overclockers.com/forums/s...51#post6665651
    What would you rather have?
    SLI GTX470 EVGA
  19. #19
    Mar 2006
    Ohio, USA
    Quote Originally Posted by Ka0sX View Post
    My experience says otherwise.
  20. #20
    Jan 2006
    Indonesia
    I used distilled water AND silver coil. My loop still cleanly: no cloudly tubing, no flaking nickel in the blocks and fittings or other nasty things in whole loop.
