Hi all!
I was able to remember my password
It have been long time since I got any decent results in any benchmark. This post will not change that at all, but at least I have put up a lot of steam in my benchroom
So I decided to test how this new ASRock Z77 OC Formula is doing with memory overclocking and what I can get out of my best CPU.
Setup was this:
Intel Core i7 3770K
G.Skill PI series PSC memory
Kingston HyperX SSD + HDD
MSI GTX 670 PE VGA
Cooler master benchtable
Corsair 1200W AX PSU
SF3D OC Inflection point CPU pot
SF3D OC Triple point memory pot
Memory voltage up to 2V and temperature between -100C and -140C. More cold did not seem to do anything after -100C...
Here are some random results and pictures:
Bling bling...
LN2 setup
Some Ln2 scores (Yes, I suck on efficiency, but no idea to spend much time with this kind of CPU )
Superpi scores were run with CPU-Z windows open and program was not closed between runs. There was no tweaks applied in to these memory tests.
First DDR3 2700MHz CL5 8M run
1300MHz CL5 32M run
Then a bit more serious runs with better CPU speed.
That's all!
Article in SF3D.fi website (Finnish): ASRock Z77 Oc Formula
SF3D OC Facebook page, if you like to get some updates from our testing etc.
