Results 1 to 15 of 15
Thread: BL2 fixed congig for amd/ati
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    this is a fixed and optimized cofig for use with amd cards, this may not work with DX11 (i am still on 10.1) but it makes the game play much smoother. now to find a way to make physX multithreaded in the config
    bl2 AMD FIX.zip
    it will also work for NV if you change the line that says check for ati to false and enable NV optimization to true.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Oct 2006
    I see this in the config:
    [MemoryBudgets]
    AnimationMB=15
    AudioMB=10
    CodeMB=30
    LevelObjectsMB=4
    TerrainMB=4
    GameDataMB=3
    MaterialMB=1
    ParticleMB=5
    PhysicsMB=10
    ScaleformMB=8
    ShadersMB=10
    SkelMeshMB=2
    StaticMeshMB=10
    TextureMB=120
    Looks like it adds up to around 256mb or so from a quick look. So I am guessing this means it is configured to use 256MB of RAM? Or is this for vram? Either way, I wonder if this can be increased to get better performance and/or visuals.
    And the same with these under Wwise (supposed to be audio?):
    IOMemoryPoolSizeMB=2.56
    DefaultPoolSizeMB=6.0
    DefaultPoolSizeMB_x64=8
    DefaultPoolSizeMB_Uncooked=8
    DefaultPoolSizeMB_Uncooked_x64=16
    LowerEngineDefaultPoolSizeMB=7
    LowerEngineDefaultPoolRatioThreshold=.9
    MaxMemoryPools=128
    EDIT: I doubled all memory values in the memory budgets and the game plays perfectly fine for me in a short test. Visually I dont notice a difference from running around for just a min, and performance seems the same too.
    Rig 1:
    ASUS P8Z77-V
    Intel i5 3570K @ 4.75GHz
    16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
    Nvidia GTX 670 4GB SLI
    Rig 2:
    Asus Sabertooth 990FX
    AMD FX-8350 @ 5.6GHz
    16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
    AMD 6950 with 6970 bios flash
    Yamakasi Catleap 2B overclocked to 120Hz refresh rate
    Audio-GD FUN DAC unit w/ AD797BRZ opamps
    Sennheiser PC350 headset w/ hero mod
    Jul 2007
    SF bay area, CA
    i had only changed the same settings that i do in all UT games, smooth frames, shader on demand, disable NV optimization, enable amd, thread compiling to 4 from 1 and other basic UT3 stuff. i am sure that there is alot that can be changed still. what i posed makes the game run like butter and stop stalling at 33fps and then jumping up randomly, now it is a solid 55-70 depending on the zone.
    i am also getting about 600MB of peak vram use so i could defiant be modded to take more, i would do the cashe load personally but i will look at it latter. the budget is normally the reserve size per asset.
    Oct 2006
    I made some of my own configs, one for AMD and one for Nvidia if anyone is interested. I mostly just increased the cache sizes everywhere I saw listed in the config, changed the AMD/Nvidia specific optimizations, enabled/disabled PhysX, lowered tessellation for AMD, and made some changes to shadows and particle LOD. I left PhysX disabled in the AMD config because people who dont have a good quad core might run into performance problems
    AMD:
    http://www.mediafire.com/?g9wxwwwpk6kzgob
    Nvidia:
    http://www.mediafire.com/?v74cw03btvaogik
    Rig 1:
    ASUS P8Z77-V
    Rig 2:
    Jul 2007
    SF bay area, CA
    did you find a way to make physX multithreaded, if not physX wont work well on any cpu.
    Oct 2006
    No I did not, but it runs well enough on my computer. Yes it does lower FPS, but not enough to cause lag. I think the only way to enable multi-threaded PhysX on the CPU would be to replace the PhysX libraries the game pulls from. A simple ini edit wont be able to do it.
    Rig 1:
    ASUS P8Z77-V
    Rig 2:
    Jul 2007
    SF bay area, CA
    changing PhysXMeshCacheSize=8 to 16 really helped the cpu physX, it is not more threaded though.
    May 2004
    Aland Islands, Finland
    I found this to be somewhat amusing
    http://www.techspot.com/review/577-b...nce/page5.html
    Haven't played it myself yet, looking to have a small coop lan this weekend and didn't want to spoil anything before that.
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
    Oct 2006
    Quote Originally Posted by zanzabar View Post
    It is already like that in my configs.
    Interesting about that picture though, that GTX680 ets less FPS when using PhysX on high than a 7970 does when using the same but on the CPU instead. They are using a 12-thead processor in that though so Im sure it has ample resources to put towards PhysX and normal game processing.
    Rig 1:
    ASUS P8Z77-V
    Rig 2:
    May 2004
    Quote Originally Posted by EniGmA1987 View Post
    Yea its a pricey CPU... But the majority of those threads will not be utilized anyway it seems, as mentioned earlier in here. On any decent i5/i7 I bet the results would follow the same pattern. Shame they only included none/high on the AMD card.
    AMD FX-8350
    4x4Gb HyperX T1
    Corsair AX1200
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by wez View Post
    i cannot see the difference from high and mid on my card, i am not sure that setting it to 2 on the config changes anything with amd cards.
    Jul 2007
    Alberta, Canada
    The main difference from medium to high are the SPH fluids which include blood, slag, chemical and molten pools as well as water. There are more particles and they apply self shadowing. Cloth is also more dynamic and reacts to more things. I'm actually running medium as the game needs further optimizations for high to play nice. Gpu usage is also very inconsistent. Nvidia has said gearbox are working to improve performance in general with a future patch.
    As it stands the game is more cpu bottlenecked than anything else and a 3960 outpaced a 3770 by a healthy margin.
    Feedanator 7.0
    CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
    LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
    Jul 2007
    SF bay area, CA
    if the 3960 beats out the 3770 there is some voodoo going on as it only loads 3 cores on my 1090t. for the inconsistencies in gpu usage, i do not get that since i disabled smooth frames in the config and changed the desired frame rates. doing one or the other is not good enough you have to change both.
    Jul 2007
    Alberta, Canada
    The in game options allow you to disable framerate smoothing. There's the 22 - 60 smoothed setting (standard UT3 and default) and then 60, 120 caps and unlimited. I've compated them all as well as playing with the various cvars in the inis and there was no benifit on my system. Gearbox have admited the game needs some futher optimization and Nvidia and AMD obviously will keep an eye on it as well.
    As far as using only 3 threads not sure there, it could be the 3960s better cache doing some magic there. It showed even a 4.5 8150 struggling to keep up with the Intel stuff so the game clearly seems to like their hardware for one reason or another. Even Nvidia had used a 3960 for their tweakguide's baseline system even though that was with a 660ti. They clearly did that for a reason as they haven't in the past.
    Feedanator 7.0
    Jul 2007
    SF bay area, CA
    the 1090t is quicker than the fx, but i only run 4.1ghz. the usable cashe on the 3960 is less than the 3770 though and much slower so i am really not sure what is going on. i could understand if it used 6-12 threads that it would better but it is not.
