Update:
1:009:xx:xx:xx
1:023:xx:xx:xx
1:038:02:43:51
1:052:xx:xx:xx
1:063:16:04:44
1:074:20:11:53
1:083:02:48:03
Update:
1:009:xx:xx:xx
1:023:xx:xx:xx
1:038:02:43:51
1:052:xx:xx:xx
1:063:16:04:44
1:074:20:11:53
1:083:02:48:03
Last update just now at 0:357:12:32:12.
I have 1720 WU on my 2600k, 395 WU on my E7500 machine, 360 WU on my Athlon 64 X2 5000+, 225 WU on my Athlon II X2 250, and no tasks on my E8500.
I have 310 WU Pending Val. or Ver.
Concentrate on GK and O_U for now guys unless your already on mine. I'll take the leftovers when they hit their goals.
EDIT: I see 2 rigs show up today on my account...thanks guys!
24/7 Cruncher #1
Crosshair VII Hero, Ryzen 3900X, 4.0 GHz @ 1.225v, Arctic Liquid Freezer II 420 AIO, 4x8GB GSKILL 3600MHz C15, ASUS TUF 3090 OC
Samsung 980 1TB NVMe, Samsung 870 QVO 1TB, 2x10TB WD Red RAID1, Win 10 Pro, Enthoo Luxe TG, EVGA SuperNOVA 1200W P2
24/7 Cruncher #2
ASRock X470 Taichi, Ryzen 3900X, 4.0 GHz @ 1.225v, Arctic Liquid Freezer 280 AIO, 2x16GB GSKILL NEO 3600MHz C16, EVGA 3080ti FTW3 Ultra
Samsung 970 EVO 250GB NVMe, Samsung 870 EVO 500GBWin 10 Ent, Enthoo Pro, Seasonic FOCUS Plus 850W
24/7 Cruncher #3
GA-P67A-UD4-B3 BIOS F8 mod, 2600k (L051B138) @ 4.5 GHz, 1.260v full load, Arctic Liquid 120, (Boots Win @ 5.6 GHz per Massman binning)
Samsung Green 4x4GB @2133 C10, EVGA 2080ti FTW3 Hybrid, Samsung 870 EVO 500GB, 2x1TB WD Red RAID1, Win10 Ent, Rosewill Rise, EVGA SuperNOVA 1300W G2
24/7 Cruncher #4 ... Crucial M225 64GB SSD Donated to Endurance Testing (Died at 968 TB of writes...no that is not a typo!)
GA-EP45T-UD3LR BIOS F10 modded, Q6600 G0 VID 1.212 (L731B536), 3.6 GHz 9x400 @ 1.312v full load, Zerotherm Zen FZ120
OCZ 2x2GB DDR3-1600MHz C7, Gigabyte 7950 @1200/1250, Crucial MX100 128GB, 2x1TB WD Red RAID1, Win10 Ent, Centurion 590, XFX PRO650W
Music System
SB Server->SB Touch w/Android Tablet as a remote->Denon AVR-X3300W->JBL Studio Series Floorstanding Speakers, JBL LS Center, 2x SVS SB-2000 Subs
As of right now I have 125 days of work CACHED for GK. All I have to do is run them all. I could clock it down from 3.5 Ghz to 1.4 Ghz and that would get it up to 312 days?
I hate to do that cuz I'd still like the work to get done... Also, I just aborted my last 517 tasks under my name...
Moving my final 16 cores to U_O.
Edit: found 1426 CFSW tasks I didn't realize I had DLed... those are also up for grabs as of now!
I have not been able to DL any since I switched 3 hours ago. I think it is because I dumped a few HCC when I dropped my account so the rig is not considered "reliable" and the only WUs left are resends which only go to "reliable" rigs. If you're listening Blue and still need the help please turn your project prefs to include HCC (shortest WUs they have) for a an hour so I can grab a few and convince WCG that I really CAN crunch!
Just added HCC for you. Try a manual update and see what happens. I'll take HCC back off in a little.
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
Just read this - switched over to BlueStang...?
Agreed - my rigs for GK are getting WUs. Few, but some... mine for you got nothing.
Edit: Got some HCC! Will abort them once I start getting CFSW WUs!
Everyone on BlueStang's account, make sure to abort the HCC WUs once you have enough CFSW units to keep you going for a while as otherwise your cache will be full and you won't request any more!
1 more minute and I'll be good!
cool ... think I'm all set now!!!
off to bed now, I've been up since 3:00 AM this morning
I'm have my cache set for 7 days...should I set higher? I don't want that High Priority fiasco I had a week or so ago.
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
On WCG Profile Settings...Workunit Cache Settings:
Connect to network about every .05 days
Cache 7 extra days of work
Is that first line wrong? Should it say/be labeled minimum work buffer? Cuz in BOINC Manager under prefs>net usage I have m .05 min work buffer. Or is BOINC Manager labeled wrong?
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
Yeah you're good. I got some HCC WUs that are crunching now. I'm now seen as reliable, but have hit my daily quota of 5 WUs...
So I should get tasks in an hour and a half. I'll leave my 16 cores through the weekend with a 10 day buffer, and they'll stay on your account after that requesting more CFSW until they run dry. Good Luck!
One of the two already has a good chunk of WUs... the other got some but all the DLs failed for some reason... so it's still crunching HCC...
Ok, I'm 4 Martini's (with double the gin) into it...so it's nap time.
Good night and see you tomorrow!
24/7 Cruncher #1
24/7 Cruncher #2
24/7 Cruncher #3
Music System
All work units turning to high priority is destroying my queue, I've had dozens abort in the last 12 hours due to the run order changing and them missing their due date. This is with an eight day queue, I have to drop to five days for a bit.
Here's my update:
1:237:11:08:35
1:247:07:20:17 + about 10 days
1:257:14:01:48 + about 10 days
1:268:00:51:08 + about 10 days
1:282:00:26:14 + about 14 days
1:295:02:08:16 + about 13 days
1:302:07:29:47 + about 7 days
1:309:05:58:26 + about 7 days
I see a massive slowdown here, depending on which 24 hour block you look at I'm down between 6 and 13 days per day I really hope I get to my goal quickly as I really want to help someone else.
As for what cores I have available, well it would've been quite a few, but...
Athlon64 X2 6000+ At my previous job, I had permission to install and run WCG but forgot to remove it and I see it's still running. As such, I can't change the account it's on
Core i7-2600K Running 100s in my desk, I can move this around
Core 2 Quad Q8400 Decommissioned server at work, no longer switched on at all
HP Proliant DL580 G2 I was counting on this, as it offers another eight threads spread across four CPUs. What I didn't count on was the noise - it's loud enough to be heard in the neighbour's yard WHILE IDLE. It easily drowns out a hairdryer, I can't leave this running :/
Edit - I've just had another 41 Work Units abort due to being late, I checked the Result Status page on WCG.org and I've had 23 PAGES of WU's abort. I'm now manually going through the list and killing all WUs due in the next two hours which haven't started yet (almost 100 ). Work is dropping off very quickly now, I have only 2,892 WUs remaining including the 100 or so I have to abort.
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
At this time I am getting a few wu's on the machines running for Oj and for Gk. Because 2 were empty when I changed the caches again I guess they might be receiving some of the discards.
Oj: as soon as you reach target I need you to let me know...until then I will stick
My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
as of just now, still need 3 days to emerald, then my 8 threads plus 16 threads from rob are freed from my "slavery"
Tell it it's a :banana::banana::banana::banana::banana: and threaten it with replacement
D_A on an UPS and life
OK, morning update time everyone ... how many days are cached on which account and how many days does each person need?
I have 40 days in the bank for bluestang - If the math doesn't work for sapphire I could move more threads over but I would need to do that ASAP in order to build the cache before the well runs dry.
haschioz: What name do you crunch under?
I think you're going to need to throw everything at bluestang - every computer I have access to currently is on either bluestang's or GKs account.
I have:
BlueStang:
71 Tasks at 2 hours each = 142 hours = 5.92 days
Remote server - not currently responding on teamviewer, but I can tell it's at 100% load...
Edit: remote server - 3390 Tasks at 1.3 hours each = 4407 hours = 183 days. Again, this one won't finish in the allotted time. should get 120 days though.
GK:
3681 Tasks at 1.5 hours each = 5521 hours = 230 days
4117 Tasks at 2 hours each = 8234 hours = 343 days
Unfortunately there's no way either one will finish - they have more cached than they can finish before they're due... idk how that happened.
I'll check them regularly and make sure they're returning useful results. For now though, there's nothing to do. There's 28 cores here with 10 days of cache, so I'm good for 280 days on GK's account.
I have 43 days to go, and no new work-units are coming to me. I've got between 2 and 4 days in the queue, so it's going to be close. Thank you again all for your help.
Distributed Computing: Making the world a better place, one work-unit at a time.
http://www.worldcommunitygrid.org/index.jsp
