This project is about build a work station for my reviews and other stuff about testing and benchmarking and overcloking the center of my atention will be the build and not the hardware it self I have many hardware here as you will see in the photos but its not the most important thing.
-Cooling-
--Watercooling-
Rad: Phobya Xtreme 400
Fans#1: Phobya G-Silent 18 700rpm Slim white
Fans#2: Phobya Nano-G 14 PWM Black Silent Edition
Pump: Alphacool VPP655 - G1/4 IG complete with D5 HF Top
Res:Alphacool Cape Corp Coolplex Pro 25 LT
Tube: Masterkleer Silver 16/10mm
Controler: Alphacool Heatmaster II
--Aircooling-
Phanteks PH-TC14PE White 3x Fans
Will be used so many other stuff but is so random that dont really matter much
Soon as I can i will post photos
Some photos of some work that have been done.
This isnt the final look, the final look is much diferent then that, and its lefting paiting the HDD cage.
So make some time since the last update on this project, i have been a bit busy with other projects and my new work office, but i done some progress on this build.
I give you some photos guys!
Dremel Trio ready to start, i think that is the right tool for this kind of works, and we can do amazing things with this one.
A very clean cut!
There was some little negligence on that from me.
Fits well!
If it dont have we do it, no problem.
Some sand job, and a nice paint it dont will look the same.
