Results 1 to 6 of 6
Thread: what type of epoxy?
    Jan 2005
    what type of epoxy?
    Ok so I'm building a scratchbuilt sff lanbox and I have a dual 120mm swiftech rad that I want to modify. I want to add a fillport/window into The top of the radiator. The end cap on the rad is brass I believe, I've already cut a big rectangle out of it and I plan on securing a 3/8" acrylic block to the end of it with a g1/4" port on it. So I'm planning on drilling a bunch of holes through the existing end cap material and epoxying brass 6-32 nuts under the holes so I have something to bolt into when I secure the acrylic top. What epoxy or resin can you guys recommend that can hold up to distilled water or premix coolant?
    Feb 2008
    Not to be a smart ass or condescending but aren't all epoxies waterproof?
    Dec 2007
    Earth
    Yeah they are all pretty much waterproof. They do however make marine epoxy, I would choose it in this case: http://www.homedepot.com/buy/loctite...l#.UD5ertaPWbQ
    Adding a fill port is super easy check out my thread: http://www.xtremesystems.org/forums/...d-Modification
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Jan 2005
    Thanks CrazyNutz, I purchased this Lepage Marine adhesive from home depot and it seems to have worked. I drilled a bunch of holes around the square opening i cut into the rad and secured nuts behind the holes with the adhesive. I was just planning on running a bead of silicon around the edge of the "window" to seal against the acrylic but I found this How to Make Silicon Oring And I also plan on using your oven technique to paint my radiator with white enamel paint. I will post some pics of the rad today or tomorow.
    Nov 2001
    Wichita, KS
    when you do post pics, please link in here, i'm interested to see the results
    Jan 2005
    Click image for larger version.
