They are killa sticks for sure.
I'm feeling pretty good about having bought my kit for $360 just a week ago, and not for $500 yesterday.Originally Posted by stasio
That said, I'm a bit of a tightwad, seldom buying new higher-end parts, preferring the used market for these types of parts (must be an occupational carryover, as I'm an Accountant by trade) and at first glance these prices, when compared to standard DDR3 pricing, seem high. However, thinking back to when the early 2x512MB DDR-400 kits of Samsung TCCD based stuff came out and were going for $225-$300 for 1GB, I must state that a 16GB DDR3-2666 kit for even $500 looks relatively cheap.
In memory of Gracie, my sweet, sweet wife and mother of my children. Darling, we will miss you dearly. May you rest in peace (born to this world on March 30, 1976; went to her Heavenly Father on Good Friday, April 22, 2011).
http://animoto.com/play/E0wFhd6tN0nA...ent=challenger
Heat
Who needs Hynix CFR ?
Samsung 2666 C10,pretty sure they can reach 3300-3400,this was the limit of my imc,after restart code 23
2666C10 - 16GB everything air cooled
Need to cut about 0.4s yet, but mems are so strong
Thanks Corsair!
Alex
MOA 2010 EU finals #3
GOOC 2010 Italy #2
GOOC 2009 Italy #1 Tech Station - Italian technology website
C10@2800 10-12-12-28 tcl7 - 1.685V
Uploaded with ImageShack.us
Got the time to open & flex my 2666 C10's kit tonight so here it is..... I think I could match the 9.12.12 2800 pi time @ 2858 10.12.12 if I tried. Sticks run real good & run spd timings 2666 overnight prime stable at 1.6v so I'm v happy. Lowest I can get 2800 10.12.12 to pass 32M is 1.675~1.68v depending on the pair of sticks & BIOS otherwise they need 1.685 with a slack BIOS or 1.75~1.77 to do super tight with a good BIOS.
2800 9.12.12 air 1.905V
2858 10.12.12 ambient air temp just a snip under 20oC 1.91v
Home / Play Rig Asrock Z87 OC Formula/AC, i7 4770K L310B487, 8GB Corsair Dominator Platinum 2666 CL10, BeQuiet Dark Power Pro P8 1200W PSU, 120GB Corsair Force GT SSD, 2 x 1TB WD Sata Drives Mirrored, Palit 680GTX JetStream, Antec Kuhler 920, Windows 10 Pro, Logitech LX700 Deskset, AOC 27" Monitor.
Work 24/7 Rig Gigabyte GA-Z97X-SOC Force, i7 4790K L418C133 ,8GB Team Xtreem LV 2600, PC Power & Cooling 850WPSU, 120GB OCZ Vertex 3 SSD, 2 x 500GB Hitachi Sata Drives Mirrored, Antec Kuhler 620, Windows 10 Pro 64 Bit, Logitech LX700 Deskset, Benq 27" Monitor.
Home NAS DFI P35 T2RL Motherboard, Intel E6850 CPU, 8GB Nanya DDR2 6400, 2X 2TB Toshiba DT01ACA200 SATA Drives, ZFS RAID Mirror On Intel ICH9 AHCI, Artic Blue 850W PSU, Marvell Yukon 88E8053 Gigabit Ethernet, FreeNAS 9.2.1.5 RC, 64-Bit On 4GB USB2 SanDisk Cruizer Blade Thumb Drive.
I can't undestand how you got TRWSR and TRWDR to 4 stable 32M,you are the only person in this forum that managed that,and also the only one to run on a gigibyte board this type of memory,so this concludes that on gigabyte they work 4 and on other board 5,or somehow you got a gold imc,maybe someone can chime in with a explanation Great job nevertheless
Alex, ability to run (very) tight subtimings also varies from sample to sample on memory, not only MHz/volt ratio and tRCD/tRP walls.
I see...C-N memories must be very special then
I love my C10 2666, never giving it up.
Got 3140 validation with 2666 C10,guess i am now limited at 1.9,ambient was~10....Guess i need to throw some ln2 at my hynix to see limit of this imc...
http://valid.canardpc.com/show_oc.php?id=2667978
So, let me see if I understand:
Are these: CMD16GX3M4A2666C11 Samsung IC's?
I'm almost buying them, but I need to know if they are worth of it
Cheers and congratulations for the awsome results!
Yeap,i suggest you grab a kit of 2666 C10 while you still find them,they are better binned than 2400 C9
Awesome kit there C-N
Test with 4X4gb
Yup its good stuff alright, sweet AIDA bandwidth man
So are the 2666 C10 sticks the only ones really worth hunting down? Or are the 2133 C9's worth looking for? (I spy some in F$ section...)
I'll need a new chip though, mine can't even run 2133 stable, worst IMC in history.
i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
The 2133C9 sticks are pretty nice too, they need more volts than the 2666C10 but can reach nearly the same clocks.
i7 4930K
32GB Corsair Vengeance Pro DDR3-2400C10
Asus Rampage IV Black Edition
2x GeForce GTX 780
Corsair AX1200
Cooler Master HAF-X
Dell U3011
Quick tests C10 @ 2917 Cas9 with -13C~-5C
Did you apply C-N tactics here with 2.1V ?
Yep, it was 2.0V with cpu cold. Trying to find sweet spot with subzero on these C10 sticks.
It gave lot of "55" and stuck @ loops 6~10ish if colder than -15C
Quality bit of there work Dumo
I'm amazed they run C9 that high, these sticks just don't give up!
