So I was pricing out dedicated crunchers and spotted something very interesting. Apparently, there are new Xeon E3's out--the so-called V2's--that are running Ivy Bridge.
http://www.newegg.com/Product/Produc...82E16819117286
The E3-1230 V2 costs $240 and is a quad-core with HyperThreading. It runs at 3.3GHz (3.7GHz max) but turbo multipliers are 2/3/4/4. It'll run at 3,500 MHz minimum though 3,625 MHz might be the more accurate number. No overclocking and no IGP, but it is a 69W chip so it should work just fine in cheap H61 motherboards.
http://www.newegg.com/Product/Produc...82E16813157315
These Asrock H61M-DGS's seem to be pretty often DOA but they're cheap and should be sufficient to run a low-power cruncher. I'm sure there's better options but I can't afford finding them.
http://www.newegg.com/Product/Produc...82E16820148538
Cheap DDR3-1333 is all you really need. Here's a single 4GB stick. If you want 8GB, you can grab a dual-channel version for $35. In fact, I'd probably recommend it--if only to setup a 2GB RAMdisk for the BOINC directory and scratch space.
http://www.newegg.com/Product/Produc...82E16820139257
A cheap and reasonably reliable USB stick is all that's really needed. You can get away with 8GB but these were priced so similarly that I thought, what the heck? More than enough space to install Ubuntu or your distribution of choice. Performance isn't grand but it's only for the OS and possibly backing up a RAMdisk.
http://www.newegg.com/Product/Produc...82E16817151117
Trust the brand, even in lieu of reviews. What I love is the power efficiency. If the system draws 20% (72W--which is possible), 80 PLUS Gold says that it should be at least 87% efficient. How would you like 83W from the wall?
http://www.newegg.com/Product/Produc...82E16811147122
Finally, a chassis may be required for some of you. As we all know, a cheap chassis can be sufficient. This Rosewill Ranger-M has a couple cheap fans which should get you running for a few years. One day, you'll need to buy replacements--but you'll have plenty of time to find them.
Only thing left out from this build is video. The CPU doesn't have any IGP which means the motherboard can't display anything. Grab your spare graphics card and install--and then run it headless. Or grab a bunch of cheap graphics cards and have at it! eBay usually has Dell Radeon X300's on the cheap ($5-10/ea)--and all you really need it to do is display an image. Regardless of any shortcomings, this is at least $100 cheaper than using a Core i7-3770K. If you could get a solid 4.8GHz out of one of those, you'll have spent 50% more for a 40% gain.
Sticking Sandy Bridge, 3300 MHz, & 32-bit Windows into the old WCG PPD Estimator (v0.6.4b), it comes up with 4,103.43 PPD. Stick in 3500 MHz instead and you get 4,350.00 PPD. Say 3625 MHz and it returns 4,505.36 PPD.
