Should I upgrade to the GTX 680's? Currently upgrading to x79 platform due to lighting frying my mb
and cpu. is it worth it for noticeable gains? While mainly playing bf3?
What are the benefits if any?
Please advice
Hlo
Please advice
Hlo
Asus RIVE Bios 2003
3930k 4.5 ghz @1.29v
G-SKILLS 32gig ddr-1600 ripjaws Z
Enermax Evo Galaxy 1250W
2x EVGA GTX 480 Superclocked SLI @ 900/1800/2000
X-Fi Fatal1ty Titanium PCI-E
4 x crucial Realssd C300 256 Raid 0
Areca 1880i
Seagate 1TB
CM HAF 932
On water:
HK 3.0
2x MCP655
FESER X360
Blackice GTX 480
DD-GTX 480 VGA blocks
DD Reservoir
Windows 7 64bit
Dell 3008WFP 30"
Help Save Lives Join World Community Grid!
PlatForm X79 For Workstation And Servers And 3Ds Max And ...
Buy >>> Intel Corei7 3770K For Games. + Sapphire HD 7970
PERSIAN GULF
I just picked up a EVGA 690gtx to replace my two older Giga 460gtx SOC cards and could not be happier.
I debated long and hard between getting 2x 680gtx's vs 1x 690gtx tho. I was planning on water cooling these in my final build.
Sure 680gtx's clock higher and have more head room for OC's and WCing them would help with that. For a gaming rig these cards are plenty powerful enough that there is no real need to OC them tbh.
But in the end I have less heat as the 690gtx runs pretty darn cool, lower power usage and less noise vs the 460gtx's. It really runs well enough as it is and no real need to water cool the 690gtx so I am saving money on blocks.
I might end up WC the 690gtx after I get the build all setup but I am pretty happy with it on air atm.
ok. I will play around with my 480's once I build the new rig then I will decide if I should buy now or wait a little longer to upgrade the cards. I was mainly concerned with the video cards been the bottleneck of the system while playing bf3.
Asus RIVE Bios 2003
Areca 1880i
Seagate 1TB
CM HAF 932
On water:
HK 3.0
2x MCP655
FESER X360
Blackice GTX 480
DD Reservoir
Windows 7 64bit
Dell 3008WFP 30"
Asus RIVE Bios 2003
Areca 1880i
Seagate 1TB
CM HAF 932
On water:
HK 3.0
2x MCP655
FESER X360
Blackice GTX 480
DD Reservoir
Windows 7 64bit
Dell 3008WFP 30"
What resolution do you intend to run at? If it's beyond 1920 x 1200 then you will see a respectable difference in BF3 on ultra with msaa. Otherwise 2 480s will do High without AA comparably. Assuming you want to run native at 2560 x 1600 the 480s will run out of steam in part due to vram ( might be able to get away with ultra sans AA), Either way it's multi gpu territory.
Feedanator 7.0
CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
Asus RIVE Bios 2003
Areca 1880i
Seagate 1TB
CM HAF 932
On water:
HK 3.0
2x MCP655
FESER X360
Blackice GTX 480
DD Reservoir
Windows 7 64bit
Dell 3008WFP 30"
As chickenfeed said, it depends on your resolution really. If it were me though I would probably try to hold on to the 480s a little longer to see what nvidias next card is like or to at least wait for prices to settle again. GTX670s can now be had for under $380 so they would be a worthwhile consideration, as would some 7950s or 7970s.
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
the 7970 is meant to be really good at that res (i run a similar res but with a 460 currently) as is the 680/690.
If your not a FPS whore then keep them 480's. they still pack a punch even if they run hot.
Work/Gaming: i7-950|GB X58A-UD7|12GB Trident BBSE/XMS3|460GTX|WD 1TB BLK|Pioneer DVDRW|CM HAF-X|Win 7 Pro 64 bit|U2711|HX850|G500|G510
Heatware: jimba86
Bench:Custom Giga-bench|Win 7/XP SP3|WD 36GB Raptor|Dell 22|AX1200|MS intellimouse
Bench 1:i7 930|water 2.0 performer|Gigabyte X58A-OC | 4GB corsair 1866 CL7|GTX 295 Quad SLI
Bench 2:E8500|NHD14|P45-UD3P(2nd PCIEx16 slot broken.. )|2GB Corsair 8888 Cl4|GTX 260 SOC
(Bench 3: In Progress) 4770K|F1EE|Gigabyte Z97X-SOC Force| 4GB GTX1 /8GB Gskill TridentX 2666CL11 ney pro|5870 x3 on KPC tek9 slim 5.0/7.0
Bench 4 E8600|NHD14|REX|2GB Corsair 1800 Cl7|Asus GTX 280
Bench 5 (TBC): FX?|990FX-UD7|Gskill Flare 2000 Cl7|6970
Server/renderbox: G3258|TT Water 2.0|Gigabyte Z87 Sniper M5|8GB Gskill Sniper 2133|gigabyte 5750|FD NODE 804
I picked up a GTX670 myself after my 580 died in a cross-country move. The 670 runs better than my 580 did @ 2560 x 1600, and it's a much smaller / cooler running card. The extra RAM on the 670 is a big help as well as Chickenfeed said... I've had quite a few issues with VRAM limitations on the 580 that are gone on the 670.
|i7 920 (3910A301) @ 3.8 (200 x 19) HT On||Corsair H50 Push/Pull||EVGA Classified E760||24GB Corsair Vengeance 1600||eVGA GTX670 FTW LE||X-Fi Fatal1ty Pro||6x WD HDDs||Enermax Revolution 1050w||Corsair 650D||Dell U3011 // 3007WFP||Logitech Z5500 // G930||Logitech G510 // Razer Mamba|
would getting a 3GB 580 fix the issue?
Im pretty much stuck to the 580 becuase of the crap 3d maya/max/PS performance of the 600 series..
Heatware: jimba86
the 680 is better all round, the problem with maya is that they have not optimized it yet and they have to wait a few months affter the quatro comes out for the hackish optimizations for the GF card, and the CUDA engine if different on the GK than GF so they need to update that.
the gf100 based cards use way more power than the 680 and you can get the 4GB 680 so getting a 3GB 580 is not a really viable at its price point. but for high rez and BF3 amd is the way to go.
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
Thank you guys, been out of the loop for a few days. Will hold on to the 480's for a bit longer and see what comes out next.
Asus RIVE Bios 2003
Areca 1880i
Seagate 1TB
CM HAF 932
On water:
HK 3.0
2x MCP655
FESER X360
Blackice GTX 480
DD Reservoir
Windows 7 64bit
Dell 3008WFP 30"
if you have the extra cash, why not. but 2011 is more of a workstation instead of the gamer side.
3770k is plenty fast for 99.99% of the games on the market and more to come.
personally i am not the biggest fan of ATI because their drivers.
GTX680 is really nice but if you want to save a few $$$ and still have great performance get 580 they aren't bad at all
2011 is slower than the 1155, the 1155 quads are about 5% quicker than the 2011 quads with gaming and use much less power (the SB 1155 is even quicker than the SB-e 2011). the only advantages are better 3/4gpu support and intel put out 6core parts (all 2011 i7 parts are also broken xeons.) the 580 will also not save you money, it is almost 100W more than the 680 and the 3GB cards are still $450-500 and are not showing up used.
The only reason you have to upgrade your 480s is to gain more VRAM for your resolution of 2560x1600. I know if I crank up my NVIDIA CP Supersampling settings to 8x in games like BF3, The Secret World, Sleeping Dogs, etc the VRAM easily goes over our 1.5Gb limit and then your FPS goes to crap.
I run BF3 at 1920x1200 with everything maxed except AA is set to 2x and I have no problems running on a single 480 w/ Q9550@3.6 as long as it stays below 1.5Gb VRAM usage. I probably avg 55 FPS and min never below 30. However running at 2560x1600 with those settings would be pushing the VRAM to the limit and you'd need more. I don't see upgrading to a 2Gb GTX 680 as a very smart move though, because you are only adding 500mb of frame buffer and you'll easily hit that at 2560x1600, so I'd be looking at a 3Gb+ card to make the upgrade worthwhile. If it was me I'd keep the two 480s until we get the GTX 780 or Maxwell, as Kepler is really just a refined Fermi design that improved power/performance tremendously. The performance of Kepler (670/680) vs Fermi (480/570/580) is just not worth it to me due to the increased cost of 28nm processing and the moderate gain in performance (which could have been much larger if they didn't use that damn 256bit Bus)
CPU: Intel i5-3570K @ 4.2ghz (1.064V)
GPU: SLI ASUS GTX 660 Ti DCII 2GB @ 1215/7012
LCD: BenQ XL2420TE (144Hz)
Mobo: ASRock Z77 Extreme6
Sound: SoundBlaster ZXR + Yamaha RX-V863 (LPCM) + Polk Audio Monitor Series II Speakers
RAM: G.SKILL Sniper Series DDR3 2133 4x4GB
Storage: Samsung 840 Pro 128GB + 1TB Seagate Barracuda +1TB WD Black Caviar
PSU: Corsair HX 750W 80+ Silver (62A)
UPS: Cyberpower CP1200AVR (720W)
OS: Microsoft Windows 7 Ultimate x64
Cooling: Corsair 650D + TT Water2.0 Pro + 2x Silverstone FM121
