Results 1 to 14 of 14
Thread: Radiator XSPC RX360 v2
    Apr 2008
    Hello
    Is that the v2 is better than v1? I have not found a review on the v2
    And this is the RX, the most efficient of the 360​​ at low rpm?
    Or EK XTX 360 is as good?
    Thanks so much
    Sorry for my english
    LL A77F - Asus Rampage V Extreme - 5930K - Corsair Platinum 4x4Go 3000 C15 - Zotac 770 - SSD Samsung 850 Pro & 830
    Pump D5 with mod Bitspower - EK Supremacy - Koolance GTX680 - HW Labs SR1 280 & EK XTX 360
    Oct 2006
    England, UK
    The RX is the King of Low RPM radiators.
    Heres Skinees review on the V2
    http://skinneelabs.com/xspc-rx360-v2/
    Jan 2009
    Consider the NexXxoS UT60 radiator.
    According to Martinsliquidlab radiator testing, the UT60 is the best performer @ all the fan settings (except @ 600rpm)
    http://martinsliquidlab.org/2012/04/...otout-summary/
    Apr 2008
    Thanks for your help
    I think I would take the RX, with push/pull (Gentle Typhoon) at ~600rpm
    For performance, it will be "the same" as a push at ~800rpm?
    Or I taking the EK XTX with M3 screws (easier than 6-32 in Europe)
    I saw that on the XTX, the chambers are in brass, it is good or not?
    Thank so much
    Jan 2009
    Quote Originally Posted by tistou77 View Post
    Thank so much
    I'm not a watercooling guru, but according to the tests I saw (mostly from Skinnee and Martin) XSPC RX, EK XTX, NexXxoS UT60 and Coolgate are all great performers at medium to low speed fans, even in push-pull configuration. And they do perform really well even with high speed fans.
    So, in my opinion, whichever radiator you pick, you'll be good. The only thing I can tell you for sure is that the EK XTX are really huge radiators (64mm thickness against the 58.2mm of the XSPC RX) so keep in mind that you'll need at least 25mm + 64mm + 25mm (tot: 114mm) of total thickness to be able to install that radiator in push-pull config. Be sure to have the right amount of space in your case if you plan to install it inside
    Apr 2008
    Thanks so much for your response
    I would put the radiator in the front of a Lian Li A77F, I saw that the RX is 63mm of thickness
    http://www.xs-pc.com/products/radiat...-fan-radiator/
    Jan 2009
    Sorry, I looked at this link --> http://shop.xs-pc.com/xsp/XSPC-RX240...ack_25299.html and the thickness is 58.5mm, maybe the previous revision is smaller, my bad.
    Anyway, with both XSPC RX Rev.2 or EK XTX you'll be good and in front of the LianLi A77F there's enough space to fit both type of radiators (the case is 220mm wide and the 5,25" drive bay in the front is 146mm wide, so it should fit without any issue since the XSPC RX Rev.2 for example is 124mm wide). You should also be able to install a couple of "L" shaped pieces of metal to hold the radiator in place
    Apr 2008
    Ok, thanks
    But here it is said that is 58.5mm of thickness
    http://shop.xs-pc.com/xsp/XSPC-RX360...ack_25300.html
    Jan 2009
    Ok, thanks
    Yeah I noticed it too, but then I saw your link to the Rev.2 and I tought that XSPC shop was listing only the previous RX revision (Rev.1).
    Maybe Rev.1 was a bit less thicker than Rev.2? I don't know, but even other shops are reporting the same thickness (58.5mm)
    Here's Aquatuning link for example http://www.aquatuning.it/product_inf...-Radiator.html
    EDIT: http://www.sidewindercomputers.com/xsrx2xrare2.html Sidewinder Computers has the Rev.2 and it's listed as 58.5mm thick
    Apr 2008
    I sent a email to XSPC to be sure, otherwise, I would take the EK XTX
    Apr 2008
    Compared to TFC Xchanger 360, the RX360 and EK XTX 360 are more efficient or the results are identical, less than 1000 rpm and push/pull (I have not found a review with these three radiators)?
    Jun 2010
    Oregon, USA
    My XSPC RX is a little under 60 mm so I would call 58 to 59 mm accurate. I bought mine in 2010 and thought it was a v2 but could be wrong. With the 25 mm fans and rubber washers, it is 85 mm.
    Here is a test with the TFC-Xchanger 360 vs. the RX360.
    Here is a test with the RX360, EX360, and EK XTX 360 including sub-1000 rpm fans.
    Keep asking questions and good luck.
    [SIGPIC][/SIGPIC]
    Cooler Master HAF 932 case; Corsair 850 tx psu; Dell 27" monitor
    XSPC rx rads; Apogee xt2; gtx680+Heatkiller fc; mcp655's in EK-D5 top
    distilled water + silver in MasterKleer 7/16" ID on 1/2" barbs & compressions
    Apr 2008
    Thanks for the link
    I got a response from XSPC, and v2 is 63mm (thickness)
    Jan 2009
    So:
    RX Rev.1 = 58.5mm thick
    RX Rev.2 = 63mm thick
    I searched for a couple of minutes a bunch of e-shops and even if I found someone selling XSPC RX Rev.2 the description is always wrong (58,5mm instead of 63mm)... I'm wondering if they're selling the old revision or if the radiator is correct and only the description is wrong
