Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
Thread: Proper PCIE Alimentation @ Motherboards - FPS Boosted
  1. #26
    Mar 2010
    Montgomery Scott...
    Click image for larger version.
    ...approves of this thread.
    Scotty, I need more power!
  2. #27
    Xtreme Guru
    Dec 2002
    Quote Originally Posted by El Maņo View Post
    Montgomery Scott...
    hahaha thanks El Maņo more power indeed
    atm im testing all 6 fan headers on the mobo.. condensed and powered
    so far same effect as an evga pcie power boost
  3. #28
    Xtreme Guru
    Dec 2002
    bottom 3x fan headers adapted to pcie
    top 3x fan headers adapted to pcie
    firewire and 7th slot booster adapted to pcie
    if my counting is correct.. 23x total 12v lines powering just the mobo now.. yeh id say this mobo is finally properly 12v fed
    had to use the sata y spliters on the ssds after a couple of raid failures (nothing serious.. the ax1200i sata cables are not ssd friendly) so i gotta order more.. i also need more pcie extensions.. pcie 12v 3.3v turbo boosters by weekend
  4. #29
    May 2004
    AB. Canada
    something you may want to think about,
    the 12v on the fan headers may be voltage adjustable by a mosfet or something, so feeding 12 volts there my cause some problem
    I'm guessing since it didn't go up in smoke right away it may not be. however just something to consider.
    "Great spirits have always encountered violent opposition from mediocre minds" - (Einstein)
  5. #30
    Xtreme Guru
    Dec 2002
    Quote Originally Posted by MadHacker View Post
    thanks.. haha it wouldve gone up in smoke had i solder yellow to yellow black to black lol.. pin 1 is gnd pin 2 is +12v so i had to inverse the yellow/black wires.. yes i did consider the speed control.. but since im just using the 2 pins i was like it should work just fine.. so before i booted the mobo i turned the psus on and there was no debug led indication that something aint right so i went for it.. i did attempt to power the usb headers but when i turned on the psus the debug led showed 88 and the nb/ram leds were lit.. so i didnt bother to turn on the system.. same with the spdif in (+5v) when i turned the psus on the debug led went haywire.. only the front panel speaker header is +5v powered
    well this is an upcoming power mod for gtx 580.. additional 2x 8pin (eps/cpu)
    total of 14x 12v and 2x 6pin more could easily be added if needed
    so what this means is that each 580 will be powered by its own psu lol yup that means i need a 4th psu
  6. #31
    Administrator andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    Quote Originally Posted by NapalmV5 View Post
    thats pure NapalmV5
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
  7. #32
    Xtreme Guru
    Dec 2002
    thanks sergio cheers!
    by tuesday shall receive the 4th 1200axi and further modding of the 580s will commence
    well as promised heres stage 3 pcie 4x 12v + 3.3v booster @ 4x/8x/16x extension
    5x +12v/12x gnd ~ 3x +3.3v/9x gnd adapted to sata
  8. #33
    silver wall jumper X
    Apr 2005
    Las Vegas
    Dude! Your are nuts - awesome soldering job!!!
  9. #34
    Xtreme Guru
    Dec 2002
    thanks mike cheers!
    stage 4/for best results at sata best to use low esr 4v 1000uf cap on the 3.3v and 16v 470uf cap on the 12v
    cap specs: http://www.chemi-con.co.jp/e/catalog...c-e-111201.pdf
  10. #35
    Xtreme Guru
    Dec 2002
    just got 4th 1200i hooked up all good.. absolute silence even at utmost loads
    after closer look at the mobo 11x additional 12v will be powering the mobo ala gtx580 power mod and the pcie slots will be properly beefed up.. so 34x 12v total.. atm its 23x 12v since im not using the raid card @ 7th slot - still would like to reuse it.. once all said and done the main psu will be fully utilized by the mobo.. napalmv5 style lol @ mike thanks man i just noticed earlier in your sig
  11. #36
    May 2004
    AB. Canada
    question
    at what point do you get diminishing returns on you mad modding?
    I can understand adding 3.3v to the unused PCIE slots, 12 volts are already added via the 2 molex connectors.
    adding 12V to the PCIE when your adding the 3.3v makes sense since your adding the 3.3v anyways.
    but I'm not sure if your getting any improvement with the rest of the 12v connections.
  12. #37
    Mar 2008
    Wherever I may roam
    Just read the whole thing .....
    ____________________________________________
    More & more very expensive, quickly obsolete parts!!
  13. #38
    Xtreme Guru
    Dec 2002
    question
    thanks.. i wouldnt post diminishing returns mods.. the fan headers took the system to another level.. i didnt mention anything since its not for everyone.. someone doesnt know what theyre doing it goes boom.. once the main psu is fully utilized im curios how the system+psu will perform+behave then ill know for sure the returns.. but the additional power mods on the mobo+580 are impossible @ diminishing returns.. look once ive modded all 4 youll see what im talking about
  14. #39
    Xtreme Guru
    Dec 2002
    Quote Originally Posted by Expat GriZ View Post
    thanks Expat GriZ cheers!
  15. #40
    Aug 2004
    Brasil, S.P.
    mental
    990FXA-UD3 | FX8350@4.7Ghz | Asus HD7870 | 2x 4GB Crucial Ballistix Tracer 2050Mhz 8-8-8-22 | AX850W |SSD Vertex3 Max IOPS 120GB | Auzentech Forte + TAPCO-S5
    EK Supreme Full-Gold | XSPC RX240 + EX120 | MCP35x | 3x Koolance Blue Led @PWM | Tygon Black 1/2 | Bitspower Compression | @ FM CM690 I
  16. #41
    Xtreme Guru
    Dec 2002
    Quote Originally Posted by Barr3l Rid3r View Post
    mental
    oh that ↑ was just a warm up to this ↓
    hey guys what up! well last week when i got the 4th 1200i later on i found out that instead of getting the usual 2x 8pin cpu/6x pcie cables i got 1x cpu/7x pcie so that threw me off a bit.. had to make changes.. went out and got 8pin extensions which i thought would work but dont.. instead of cpu 8pin cables.. anyways finally shook off the laziness and got to work and this is what i got so far.. the mobo power boost mod works like a charm.. the psu is running dead cold vs hot as hell before.. very pleased and happy with the turn out
    gtx580 power boost mod
    ud9 power boost mod
    one cap at top and bottom
    3x boosted evga power boost to pcie
    gpu#1 - main/mobo
    gpu#2 - gpu#3
    unfortunately the 8pin extension is a no go at the psu.. the 580s almost went up in smoke.. so i have to get 8pin cpu cables from corsair
  17. #42
    Feb 2010
    Croatia
    Cool! I love the wiring!
    Out of curiosity have you tried adding extra juice to OC mbo despite proper alimentation?
  18. #43
    Aug 2004
    Brasil, S.P.
    now you just gotta put some sleeves on that cables hehehehe
  19. #44
    Xtreme Guru
    Dec 2002
    Quote Originally Posted by Gorki View Post
    thanks Gorki.. yes but the higher the voltages the worse it got
    lol oh man now you say.. thanks for the late reminder.. i just finished 96x wires - cut - strip - perfect solder - shrink wrap - sleeves? forget it im done
  20. #45
    Xtreme Guru
    Dec 2002
    well they dont have cables for 1200i yet so i didnt wait on cables and just inverted the yellow/black at the male/female 8pin connectors and it works just fine
    hooked up the bottom cap as well plus 5x fan headers - 2x pcie
    inverted yellow/black
    34x 12v utilized by the motherboard - 14x 12v utilized by each gtx580
    only 2x 12v free @ the 8x 8pin main psu connectors
    before and after - gtx580 power boost mod - 4-5 C temp drop
    youtubing at the same temp as idle before
    startup temps before and after mod
    on the 1.5gb air cooled gtx580 5-6 C lower at idle after power mod
  21. #46
    Jul 2007
    NapalmV5 its a pleasure really to see your mods and pics such awesome and neat job and very good skill for soldering man
  22. #47
    Jul 2007
    what solder u use my friend to acomplish such a great job ? i mean what brand and watts ?
  23. #48
    Xtreme Guru
    Dec 2002
    Quote Originally Posted by andressergio View Post
    in one hand just a simple/10$ in store 40-watt iron from radioshack
    http://www.radioshack.com/product/in...ductId=2062738
    and in the other hand this solder from digikey
    and i apply/work the solder/iron until i get that sexy curvy round solder
  24. #49
    Jul 2007
    i must say that im very impressed with your soldering skills congrats man !!!
  25. #50
    I am Xtreme
    Dec 2004
    France
    excellent thread mate, the best original modding I have seen in a very long time.
