even though this mod doesnt void warranties still mod at your own risk
and thats the point of these pcie mods.. no soldering to the motherboard no voiding warranties
stage 1 - molex evga power boost/12v booster
stage 2 - sata 12v + 3.3v booster
stage 3 pcie 4x 12v + 3.3v booster @ 4x/8x/16x extension
5x +12v/12x gnd ~ 3x +3.3v/9x gnd adapted to sata
stage 4 - boosted boosters
proper pcie 470uf low esr capacitance
for best results at sata best to use low esr 4v 1000uf cap on the 3.3v and 16v 470uf cap on the 12v
cap specs: http://www.chemi-con.co.jp/e/catalog...c-e-111201.pdf
other benefits beside boosted fps..
stable vs unstable system
lowered cpu temp
boosted 12v rail
boosted 3.3v rail
boosted 5v rail
boosted ethernet
boosted storage
boosted usb - no more sluggish usb performance
boosted everything/anything connected to the motherboard
max usb read/write from start to finish
my system was in dire need of more pcie alimentation even at 3x corsair 1200i psus.. had to find a solution.. looking around the web i came across the forgotten evga power boost.. order a bunch in a heartbeat!
http://www.evga.com/Products/moreinf...100-MB-PB01-BR
this morning soon after i received the boosters i found out just how badly the system was deprived of good pcie alimentation.. unstable vs stable and i got 20-40 fps increment in benchmarks
this mod is marvelous for all 4x (7x slots) 16x pcie motherboards
for other motherboards 1-2 boosters depending on vacant pcie slots
link to all pix in fullscreen:
https://picasaweb.google.com/1100060...NrRzbG7ka3CyQE
gigabyte oc (backup system) featuring proper pcie alimentation
gigabyte ud9 (main system) instead of 2x molex it should have 4x sata to properly aliment 3-4x highend gpus
even 3x 1200i have a hard time.. all 3 rails under and drowning.. 3.3v is the worst
evga power boost in all 3x 8x pcie vacant slots.. the molex at the bottom replaced with a 4th power boost
the 3x power boost/3x molex adapted to 1x 6pin pcie
unfortunately the evga power boost fails to aliment the crucial 3.3v
and this is where this mod comes in.. boosted 12v + 3.3v
