Page 1 of 4 1234 LastLast
Results 1 to 25 of 76
Thread: Work in progress... TCI K2
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    For Llano, no overclocking tools were ever released to public...
    Yet the ones that excisted were very limited.
    I wanted to see if I could change it with Trinity...
    It seems I can.
    Work in progress..
    The current "code" is 95% finished but there are still some optimisations to do and features to add.
    All of the features shown are adjustable, except the ones that cannot adjusted without recalibrating / training the DRAM (tCL, tCWL, MEMCLK ratio).
    Core PStates, dividers and multipliers can be adjusted individually, per compute unit.
    DRAM timings are also adjustable per DCT, so you can have different timings on different channel
    Built-in offset & loadline trim adjustments work on all motherboards meeting the electrical requirements of socket FM2.
    All of the power saving features can be turned off (BApm, SCLKDpm, LCLKDpm, NBDpm, ApmMaster, TDC, etc), so they do not tamper with the settings while overclocking.
    Work todo: Display, Video, UVD clocks adjustment, some DRAM fine-tuning parameters (skews, etc), and Pll control.
    Adjusting the display clocks especially will help at high BCLK.. Which will be easier to achieve when I add the in-flight control for the Pll...
    The "program" will work on all Trinity K-series (rumored) APUs and all FM2 motherboards other than Gigabyte and MSI.
    I might make a different version for the non K-series APUs, but the current version is for K-series (again rumored) only.
    Naturally I still need to field test the software on some of the alleged K-series APUs!
    I have NO clue if the software will work or if any of my information is even correct, until I have tested.
    Update 09.29.2012: The user guide is up. TCI K² - User Guide
    Update 10/02/2012: TCI K² V1.0
    Update 12/19/2012: TCI K2 V1.1
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    Looks nice Stilt!
    Are you going to make a GUI for it, or will I have to brush up on my CMD skills...?
    I get the feeling these Trinity K's are going to be alot of fun...
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
    Jan 2006
    Dayton, OH
    Any particular reason the tool won't work on Gigabyte and MSI?
    Heatware
    filmbot
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    wow, nice Stilt! After lunch date of Trinity will be here the program avaiable? Thx again!
    ROG Power PCs - Intel and AMD
    May 2003
    Hopatcong, NJ
    omg o_O
    you are a god Stilt. FM2 release to online retailers already so we can test this!
    Oct 2006
    Quote Originally Posted by filmbot View Post
    I too am wondering the reason, but I am guessing it has to do with the electrical compatibility or something? Perhaps Gigabyte wants to do their custom stuff that breaks compatibility?
    Since Trinity uses the Piledriver core, are there any plans to do an update to this utility to be compatible with Vishera once it releases later this year?
    Everything looks great so far though. This will be a wonderful tool to use.
    Rig 1:
    ASUS P8Z77-V
    Intel i5 3570K @ 4.75GHz
    16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
    Nvidia GTX 670 4GB SLI
    Rig 2:
    Asus Sabertooth 990FX
    AMD FX-8350 @ 5.6GHz
    16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
    AMD 6950 with 6970 bios flash
    Yamakasi Catleap 2B overclocked to 120Hz refresh rate
    Audio-GD FUN DAC unit w/ AD797BRZ opamps
    Sennheiser PC350 headset w/ hero mod
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    Gigabyte and MSI boards will be fine, no doubt.
    The reason they are not supported is other than physical/electrical, i.e there is nothing wrong with them!
    I´ll upload the software immediately after the curtain has been lifted.
    Regarding Vishera support; It will only require some small changes.
    Pie assassin
    Nov 2007
    Where lights collide
    man, this thread needs alot more activity. Mr. Stilt has been nothing short of amazing with his ability to provide AMD support.
    Legend status doesnt even describe what he has given to the community.
    Current Status - Testing & Research
    Jan 2006
    Dayton, OH
    Quote Originally Posted by The Stilt View Post
    Figured it was something a long these lines, as in they probably weren't brands that in the testing labs. Great to hear though
    Heatware
    filmbot
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    NOTHING is what it appears to be
    If you were right ASRock would be also unsupported, but it is not.
    Xtreme 3D Team
    Jan 2009
    Ohio
    Thank you The Stilt for your contributions to the community and wonderful things like this
    Smile
    May 2008
    Czech republic
    I really hope, with good BIOS and A10 will be in overclockicng right fun
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    The work continues...
    Since A1 build:
    Added support for FirePro A320 APU
    Enabled APU telemetry output (for VDD, IDD reading)
    TjMax adjustment for CUs, GPU & HTC activation adjustment
    Product specific (fused) values now read from "OTP" (FID, VID, SIMD config, etc...)
    AGESA core control over-ride, the forbidden SC-mode is available too (bios "support" required)
    PLL output divider ratio control between 2:1-72:1 (for ICS 9LPRS477)
    Removed the extra delays from SMU operations, the SMU firmware will now acknowledge in real time
    I will still try to reduce the amount of temporary data the program creates to make it even faster.
    Removing the delays between the SMU operations already made it significantly faster.
    Some of the features are somewhat "delicate" so I need to figure out what needs to go under the notorious "chapter 8".
    I will probably demo the software on 'FirePro A320' at some point
    May 2008
    Czech republic
    I need Trinity now A320 will be interesting too. Do you have only classic desktop Trinity or A320 profi too?
    Oct 2006
    Wow. This all sounds so great. Trinity overclocking is going to be lots of fun.
    Rig 1:
    ASUS P8Z77-V
    Rig 2:
    May 2008
    Czech republic
    My guess is about 4.8-5.2 GHz benchable for CPU Trinity and over 1000 MHz at jGPU core OC.
    I am Xtreme
    Jan 2005
    Cool, thanks for the effort The Stilt!
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
  18. #18
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    Added: Preliminary support for VS (IMC, CUs), support for reading the REAL T_Die temperature...
  19. #19
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    There is not much I can show you at the moment...
    Any guesses what is happening on the video?
    The software is pretty much completed.
    I´ll start writing the manual within a day or two.
    Due the vast amount of settings (around 300+, without checking) writing the manual alone will take a hefty amount of time.
    There are plenty of improvements since the last update:
    • Clock detection changed to APIC from TSC (worst case accuracy is now <100kHz, compared to x% with TSC).
    • All of the CPU PStates, including the boosted ones are now writable (previously only PState0)
    • Floating CPU, NCLK, MEMCLK, SCLK, MainPll frequencies, the resulting frequencies are calculated and displayed prior writing the changes. No need to calculate all of the different frequencies manually.
    • Safety features: Writing "illegal" clock combinations is blocked (e.g you cannot accidentally violate the DRAM:NCLK rule).
    • Clock source detection (Internal or External Clockgen / Pll), M/N adjustments are automatically applied to the active one.
    • Option to postpone the FID drive, handy for max CPU-Z record attempt
    • CPU Downcore control, available modes: CU1 (Cores 2/3), Slaves (Cores 1/3), Expendables (Cores 1/2/3).
    • Tons of security checks to prevent system crash caused by user error.
    • Check for SVI2 support (to enable Loadline & Offset Trim adjustments).
    • Reading IMC Strength Delta value from fuses (higher the better).
    • Port80 diagnostic message reading.
    • MainPll Range Extension
    • Improved fuse data reading (CPU Pb0/Pb1/PS0, SCLK, NCLK, MainPll, IMC parameters currently supported).
    • Pll window exhaustion warning.
    • + Around 1001 fixed bugs.
    It is likely that some of the features need to go under the "limited access" menu, I still need to discuss which ones.
  20. #20
    May 2008
    Czech republic
    wow, this is awesome Stillt, finally right temps with help of this software. Will be it working at Vishera too?
  21. #21
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    hmm will this work with A10-4600m?
    it would nice since it is a locked chip
    FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
    Asus Crosshair Formula 5 Am3+ bios v1703
    G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
    MSI 7950 TwinFrozr *1100/1500* Cat.14.9
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    2 x 1TB Samsung SpinpointF3, 2T Samsung
    Win7 Home 64bit
    My Rig
  22. #22
    Jul 2012
    Looking through the screenshots, it looks like sclk is adjustable? Does this make bclk oc'ing and bios raid/ahci setups work? Does trinity/a85 even have the same ahci issue llano does?
    Max memory multi is still for 1866, and any more is blck like llano?
    Looks awesome Stilt, I have a lot of reading/learning to do when this becomes available. I also need to get to work fabbing my case...
    Oh, is this program going to be free, $, or donation kind of thing?
  23. #23
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    Quote Originally Posted by Yeroon View Post
    The iGPU core clock (SCLK) is adjustable between 100-1900MHz with the default BCLK frequency, on unlocked "K" APUs.
    The maximum officially supported MEMCLK frequency is DDR-1866, however there are higher options available on some of the boards.
    On "K" APUs there is no need to touch the BCLK, unless you got some very extra fast DRAM available.
    I have not tested the AHCI really, however on Trinity the AHCI issue at high BCLKs can be fixed with a proper motherboard design (as far as I know).
    The software is free, however I will not resists if someone likes to make a donation.
    Quote Originally Posted by tbone8ty View Post
    The software was originally intended for "K"-series APUs only, like the name of the program indicates (K^2).
    Currently it will not support either locked or mobile APUs, however I am not certain if the mobiles are even 'fully' locked.
    Unless I am able to aqquire a Trinity laptop or equivalent no support will be added for the mobile APUs.
    The mobile parts are configured a bit differently than their desktop counterparts, so some things need to be done differently on them.
  24. #24
    May 2008
    Czech republic
    after NDA will be avaiable to download?
  25. #25
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    Added: INITIAL support for Gigabyte and MSI motherboards.
    The program will work in "generic mode" with boards which don´t have a model specific profile.
    In generic mode adjusting the external Pll (BCLK) and some of the VRM parameters is not possible.
    The first public version will have profiles for following boards: Asus F2A85-M PRO, Asus F2A85-V PRO, Gigabyte GA-F2A85X-D3H, Gigabyte GA-F2A85X-UP4, MSI A85XA-GD65.
