Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: Swiftech releases Maelstrom 5 1/4" dual bay res
  1. #26
    Mar 2011
    SoCal
    usually when running two pumps you will want to make sure you fill up the reservoir when both pumps are full speed. because of the greater suction when using 2 pumps at full speed you should be able to add more liquid in the loop.
    we've tested it with 2 pumps and just a tube (no water block or radiator) and we didn't have any problem.
    Let me know if I can be of any assistance: (Call or email or forums).
    Stephen
  2. #27
    Jun 2009
    New Zealand
    Awesome res and pump combo absolutely love it, put off ordering my parts just so I could get this res. I have an issue though and this is to do with the TJ11 not your res, it does not fit in the front drive bays the opening is only 149mm. So any TJ11 owners looking to buy this res keep in mind you are going to have to trim the front plate to get it to sit flush.
    Main Gamer
    HW: Gigabyte Sniper 2-i7 2600k@4.6GHz-8GB Corsair Dominator GT 1866MHz 8-8-8-24 1T-2x Sapphire Toxic 6950 2GB CF@925/1425-Enermax85+ 850w-2x Crucial M4 64GB raid 0-Silverstone TJ07 Black Inverted ATX-2x Viewsonic 24" 1920x1080
    Cooling:EK HF Supreme EN Nickel-XSPC RX480-Swiftech MCP355-Koolance 240mm Tube Res-PrimoFlex Pro LRT UV Green Tubing - 7/16" ID X 5/8" OD-Bits power 1/2" fittings-Distilled water with silver kill coil
    Spare Gamer
    HW: Giga-byte P55 UD3R-i5 750@3.6Ghz-4GB Corsair 1333Mhz 8-8-8-24 1T-Sapphire HD4890 1GB@925/1200-Cooler Master eXtreme Power Plus 550w-Hitachi Deskstar 320GB 7K1000.C-Cooler Master Elite 330 custom window-Viewsonic 22" 1920x1028
    Cooling: Aywun Radi V10 120mm LED fan-2x 120mm LED fans
    HTPC
    HW: Asus M4A78L-M-AMD Athlon II x4 630@3.2Ghz-4GB Corsair XMS2 Xtreme 800Mhz 4-4-4-12 2T-Sapphire HD4650 1GB-Enermax Liberty 500w-2x WD 500GB Raid 0-3x WD 1TB-Silverstone GD01B-MXR-Sony 52" 1920x1080
    Cooling: Aywun Radi V6- 2x Noctua 80mm fans
    Help Save Lives Join World Community Grid!
  3. #28
    Mar 2011
    SoCal
    we have a replacement front panel for the TJ11 which has a smaller than standard opening. Just email us with a copy of your invoice and we will send the replacement front panel.
    Regards,
    Stephen
  4. #29
    Dec 2007
    I've just received my Maelstrom 35x2 and I love it ! going to install it later this week or maybe next week when I have the time.
    intel Core i7 980x, ASUS Rampage III Extreme , Corsair Dominator GT DDR3 2000 CL9 3x4GB , nVidia GTX 680 FTW TriSLI , Auzentech X-Fi HomeTheater HD
  5. #30
    Jan 2007
    Michigan
    Well done Swiftech crew! You've made my next upgrade path a no brainer! I hope this product performs as good as it looks, and I have no doubts it will given swiftech's excellent track record!
    Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
    Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
    Intel 4.5GHz LinX Stable Club
  6. #31
    Jun 2009
    New Zealand
    Quote Originally Posted by stephenswiftech View Post
    Regards,
    Stephen
    Got to love the fast response.
    Cheers for that Stephen I just sent an email to help@swiftech.com with a copy of my invoice.
    Main Gamer
    Spare Gamer
    HTPC
  7. #32
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Wow nice work gabe, really have missed seeing your products!Might have to invest in one of these soon !
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
  8. #33
    Dec 2007
    I am having a hard time bleeding my loop with the maelstrom
    Also guys, make sure you use good quality tubes with slightly thick walls, make sure the tube are connected tightly to the fittings and the fittings tightly to the blocks, the dual pump maelstrom is too powerful
  9. #34
    Mar 2011
    SoCal
    Hey there
    yes the MCP35X2 does push quite a bit of water
    A good tip on bleeding Maelstrom with this pump is to make sure both pumps are full speed. Then top off the liquid with both pumps still at full speed. Then tighten the cap with fingers until it's tight and then add another 1/4 to 1/2 turn with a screw driver or large coin. Only THEN adjust your pump speed to your needs. If you are topping off the reservoir with the pumps on a lower speed (or even turned off) the back pressure of the 2 pumps at full speeds will lower the water line to a point where they could actually start sucking air. Making sure it's bled with both pumps at full speed will prevent that!
    Hope that'll help!
    Regards,
    Stephen
  10. #35
    Aug 2009
    Great product! will get one soon, i am very excited
    My hardware changes to fast and to much to keep a sig up to date. I just gave up on the idea.
  11. #36
    Dec 2007
    Quote Originally Posted by neonatas View Post
    Ohh ya it is, love it so much.... An awesome product indeed
  12. #37
    Mar 2005
    Finland
    Anyone else having problems with fill cap? my unit keeps pushing little bit of water out when turned off if i dont tighten it bottom out :S
    Asus Rampage IV Formula X79 | EK-MOSFET ASUS RF4 - Acetal Copper
    Core i7-3630K@4.5GHz 1.4V | EK-Supreme HF - Full Copper
    G.Skill 16GB Quad Kit Ripjaws Z (4x4GB), DDR3 1600MHz, CL 9
    EVGA GTX TITAN SC | EK-FC Titan SE Copper - Plexi Full Cover | EK-FC Titan SE Backplate
    Corsair AX1200i
    Samsung 256gb 830
    Intel SSD 160GB X25-M G2
  13. #38
    Mar 2011
    SoCal
    Quote Originally Posted by Mobsters View Post
    hey there,
    you either have a defective unit (possible but unlikely since they're 100% leak tested under pressure), or your cap isn't tight enough (you may want to wet the o-ring to allow for a greater torque on the cap hence compression on the o-ring), or you may have cross threaded the cap into the reservoir (you can easily see if it's been cross threaded by looking at it from the side, if the cap is not parallel to the top of the reservoir then it's cross threaded - it doesn't necessarily mean it's dead just unscrew it and re-tighten it down making sure the cap remains parallel to the top of the reservoir)
    hope that'll help
    Regards,
    Stephen
  14. #39
    Mar 2005
    Finland
    Cap seems to in right place. It seems like o-ring groove might be little bit too deep, allowing o-ring to sink too low and thus, needing extreme pressure to seal. Or 2x35X pumps at 100% are too much
    heres a pic of the unit cap, and yes, it is a little bit tricky to get on right thread.
    Corsair AX1200i
    Samsung 256gb 830
  15. #40
    Jul 2012
    Long Beach, CA
    It looks like it definitely is on correctly. The problem that you're having sounds like it's related to pressure being caused when the unit switches off. This is common and will just require you to ensure that the cap is fully tightened each time you fill the reservoir. I hope this answers your question.
    Phenom II 1090T @ 4.2 GHz with a voltage of 1.55 set in BIOS, Gigabyte 990FXA-UD7 motherboard, dual reference GTX 560 Ti video cards overclocked to 900 on the cores with a voltage of 1.35, 8 gigs of Kingston Hyper X Genesis @ 1600 MHz with a voltage of 1.65 9 9 9 24 timings, 1100 watt Cooler Master UCP power supply, 4 500 gig mechanical drives and a Kingston V+100 128 gig solid state drive, in a modded HAF X edition case.
  16. #41
    Mar 2011
    SoCal
    also, wetting the oring before tightening the cap helps in giving a good tight seal (less friction on the oring = more compression with equal torque)
    using a tool for the last 1/4 or 1/2 turn really helps
  17. #42
    Dec 2007
    Sorry but I had to dig this from the grave, after owning this product for less than a year now, I am facing a really big issue with it.
    1- The temperature digital clock is now totally off, no green light or digits, started only display green light since a month an a half ago and now dead.
    2- The 2 pumps are off of sync, there is a deference of about 250 to 300 RPM " is this OK?"
  18. #43
    Jul 2012
    Long Beach, CA
    The difference between the pump speeds is perfectly normal and shouldn't have any issues in terms of performance. The temperature monitor on the other hand is another story. Please send me a copy of your invoice for the purchase of this reservoir so that we can look at getting it replaced for you. Just send it to bryan@swiftech.com.
  19. #44
    Jul 2014
    any plans to have this unit in stock again?
    *with factory pre-installed MCP35X2 dual pumps
