I have looked high amd low for some anwsers but no one really knows what they are talking about in the car audio industry...i mean people keep saying the gain is not a volume knob for god sakes when the actual thing is a potentiometer. Anyways i wonder if any of you can help me out
I wonder about the purpose of dual rca left and right outputs for lfe pre outs in head units and monoblock amps, the purpose i mean does not make sense to me. (all home theatre are single mono cables from what i know) I understand that from a two channel perspective that the sub channel is diluted from the two front left and right channels low end frequency spectrum and they are summed together incase of left and right variations so why is there a need to split it at the pre outs. I can only assume its got something to do with power transfer or some kind of standards carried over before sub pre outs were even around and left and right pres were only available.
Another thing id like to add is my mono amp has two rca inputs and if you feed it with say the left pre out LFE channel to only one of the monoblocks inputs you get less SPL output than if you used a Y splitter to split the signal to both left and right. Now im assuming this is becuase the amp is internally bridged ?. Another thing is if i use both the pre outs on the head unit and connect them to both right and left main ins on the monoblock amp i get a even further increase in SPL output which i am assuming is becuase more voltage is being delivered yet again but i dont know why becuase i would have though the y split technique would be the same as theres no voltage drop when its a parallel circuit.
Any help much appreciated.
