Page 2 of 8 FirstFirst 12345 ... LastLast
Results 26 to 50 of 191
Thread: lowfat's Big Lian Li
  1. #26
    Jan 2008
    Bonnie Scotland / Sunny England
    Om nom nom nom! No Mobo cooling though?
    PROJECT :: The Xtreme (WET) Dream!!!
    PERSONAL H2O BESTS :
    E8600 @ 4.8GHz
    E6750 @ 4GHz QX9650 @ 4.6GHz
    i7 920 @ 4.6GHz
    PERSONAL AIR BESTS :
    Sempron140 @ 4Ghz (Stock Cooler)
    i7 3960x @ 5.4ghz (Air Cooler)
    Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
    Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
    Swift_Wraith : "could someone please check bex for a penis?"
  2. #27
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Quote Originally Posted by RCG_Bex View Post
    I've seen the thermals of the Z9PE-D8 WS online. Even while under load it doesn't throw a lot of heat. I also dislike the look of the new EK blocks and AFAIK no one else is making them. I think they look pretty decent stock anyways. To the point and useful.
    More pics of the cable management so far.
    All the cable management standoffs mounted.
    The power/reset buttons.
    Front panel. Seriously dislike these things. All I want is 2 USB3.0. The rest I will never use.
  3. #28
    I am Xtreme
    Oct 2005
    Did a bit of work on the case. Finished off making all the retention bars. As you can see all the screws are too long.
    Dremeled down the screws so they could fit. The retention bars will be getting a new paint job before the finished product.
    The long standoffs are for the front shroud, which will cover those stupid so called cable management holes. It will also hide the USB & front panel cables.
    Small cut I needed to make to one of the motherboard supports. Also for cable management. Not so great at cutting as you can see. :o
    Changed the plumbing of the front radiator a bit. Seems a bit cleaner.
    This is before:
    And the after:
    Reinstalled the motherboard tray and the hardware. The 24-pin + 8-pin in place on the case.
    Ignore the blue splatter all over the fan, the fans were just place holders to see how it fits.
    And I'll throw in these few pics of random hardware and tools I took.
    My nibbler, one of my favourite case modding tools.
    Heat gun, this thing has got a lot of use. Not so much now that I do shrinkless sleeving.
    And my iPad keyboard.
  4. #29
    Dec 2009
    ATHENS
    Awesome build!
    混沌とした アンモラル
  5. #30
    May 2009
    ITALY
    holy S**T lowfat, I really love your photos, really nice macros. Another thing, how and where can I find tube sleeves? by the way goooooood work mate
  6. #31
    I am Xtreme
    Oct 2005
    Quote Originally Posted by salucard View Post
    I am using ⅜” ID 1/2" OD (10mm / 13mm) tubing paired w/ MDPC-X SATA sleeving. The SATA sleeving will not fit over larger tubing though.
  7. #32
    I am Xtreme
    Oct 2005
    Have been working on the cable management again the last few days. Thinking about ditching my top 2 x 140mm radiator. It is blocking my bauce sleeve job . But seriously, it is. I don't like how the radiator hides most of the sleeving up top. Not to mention the radiator putting tension on the connected because it is such a tight fit. Someone one another forum suggested for me to install a window up top. Might just do that.
    And the bad. Going to have to adjust almost every one of these cable lengths while in the case. Too messy.
  8. #33
    I am Xtreme
    Oct 2005
    Been working on cabling all weekend.
    I worked on length and straightening out the 24-pin for probably 6-8 hours. . Still not quite perfect, will get the lengths 100% there once I finish the GPU and 8-pin cables.
    Crimped the cables for the first video card. I ran out of 18-gauge wire last night and the store was closed today. Ended up using 16-gauge since that is what I have around. I already test fit to make sure the shrinkess method of sleeving works and it did perfectly. The stacked PCIe power connectors don't even look half bad IMO.
    This is the finish on a Silverstone Strider 750W Gold. Looks pretty cool. Will take another pic when i get my reverse lens mount in the mail.
    Just a random pic of a screw.
    And some fittings.
    Some rams.
    Photobucket is being a POS currently. Some pics might not load properly.
  9. #34
    I am Xtreme
    Oct 2005
    Changed the plumbing up a bit last night. Ditched all the 45˚s. Looks a lot better IMO.
    Before:
    After:
    The ioXtreme. So bauce.
  10. #35
    I am Xtreme
    Oct 2005
    Not really an update. Just took a bunch of pics.
    This is a macro of the finish on the power supply.
  11. #36
    Apr 2011
    North Queensland Australia
    That. Iso.
    <333333333333333333333333333333
    -pb
    -Project Sakura-
    Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
    2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
    Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
  12. #37
    Jan 2009
    Sydney, Australia
    Quote Originally Posted by lowfat View Post
    *snip*
    *snip*
    For a moment there I thought you used your skin as a canvas to take this shot! Far too much alcohol for me this weekend, and naughty you for for putting a disclaimer!
    Great work btw - would love to see more!
  13. #38
    Sep 2011
    Canada
    Had a bunch of those screw caps in my cart at PPCs, never thought of using them on my mobo. Time to order more :o
    Also see a pic of a lonely molex pin. I ordered a bunch of pins since I planned on switching out the ones in my 1200w with some gold plated ones for extra bling.
    To bad I can never take any pics as good as yours.
    Carnage
    [Silverstone TJ11] [Silverstone 1200w]
    [EVGA Z77 FTW] [I5 2500k] [8gb Samsung 30nm]
    [Sapphire HD 7970]
    [Sound Blaster Titanium HD] [Sennheiser PC360]
    [Patriot Wildfire 120gb] [Seagate 1.5tb 7200pm]
    [Steelseries Sensei w/ I-2 Mousepad] [24" 1920x1200 Samsung]
  14. #39
    I am Xtreme
    Oct 2005
    Worked on the GPU sleeving today. Still a to work on their tightness and lengths.
    A few more macro pics as well. :p
  15. #40
    Aug 2008
    England
    Can you tell me what look like 3 wire black clips that your using in this picture, also roughly where there located:
    Regards
    -Ninja
    Computer Worklog (Scratch Build)- [Great Heights]
    "Peace Is About Having A Bigger Stick Than The Other Guy"
  16. #41
    I am Xtreme
    Oct 2005
    Quote Originally Posted by Darkninja462 View Post
    Regards
    -Ninja
    They are made by Mod/Smart.
    http://www.performance-pcs.com/catal...ducts_id=31903
  17. #42
    I am Xtreme
    Oct 2005
    Added some more curves.
  18. #43
    Dec 2008
    Jerusalem, Israel
    The bottom pipe look great,
    Hot water?
    [SIGPIC][/SIGPIC]
    EVGA SR-2 , 2X Intel Xeon 5620, 12X2GB Corsair Domminator 1600 MHZ CL7
    3X GTX580, Corsair AX1200, Lian Li PC-Z70
    3X Dell U2311H, Liliput 7" touchscreen monitor
  19. #44
    I am Xtreme
    Oct 2005
    Quote Originally Posted by arkadur View Post
    Hot water?
    Yes.
  20. #45
    Oct 2004
    Looks impressive!!!
    what kind of "holder" is the one for the "floating reservoir"? is it handmade or what?
    Thx!
  21. #46
    I am Xtreme
    Oct 2005
    The reservoir is being held on with the stock Koopance 140mm reservoir mount. But only the top piece. Nothing is holding it up from the bottom though.
  22. #47
    Aug 2002
    .CA
    Incredible work lowfat, absolutely beautiful.
    If my answers frighten you, stop asking such scary questions...
    • Hush V2
    • Intel i7 4770K - XSPC Raystorm - Gigabyte G1.Sniper Z87 - Crucial Ballistix DDR3-1866 - 9-9-9-24
    • Zoltac Geforce GTX 780Ti - EK-FC780GTX Ti
    • SanDisk Ultra 480GB SSD - WD Black 1TB 64MB Cache
    • Custom Water Cooled Fractal Designs Define R4 - Antec HCP-1000 Platinum
    • EK Coolstream XTC 280 - Cougar CF-V14HB Vortex HDB - XSPC EX240 - Scythe GT AP-15
    • Dazmode Storm DDC 3.25 - AquaComputer Aqualis DDC 150 Reservoir
  23. #48
    PI in the face
    Nov 2008
    awesome build
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
  24. #49
    Mar 2006
    Sydney , Australia
    Any updates on this?
    Bencher/Gamer(1) 4930K - Asus R4E - 2x R9 290x - G.skill Pi 2200c7 or Team 2400LV 4x4GB - EK Supreme HF - SR1-420 - Qnix 2560x1440
    Netbox AMD 5600K - Gigabyte mitx - Aten DVI/USB/120Hz KVM
    PB 1xTitan=16453(3D11), 1xGTX680=13343(3D11), 1x GTX580=8733(3D11)38000(3D06) 1x7970=12059(3D11)40000(vantage)395k(AM3) Folding for team 24
    AUSTRALIAN DRAG RACING http://www.youtube.com/watch?v=OFsbfEIy3Yw
  25. #50
    I am Xtreme
    Oct 2005
    Quote Originally Posted by aussie-revhead View Post
    No
    I don't have a lot of free time lately.
