Results 1 to 10 of 10
Thread: Fans and radiator (WC)
    Apr 2008
    Hello
    I see that many people have Scythe Gentle Typhoon on their radiators (WC), but with low rpm (less than 1000rpm), the Scythe S-Flex are better than the GT (more perf and quieter), I believe
    For a radiator, thick and low density (TFC Xchanger), the S-Flex will be better than GT?
    Sorry for my english
    LL A77F - Asus Rampage V Extreme - 5930K - Corsair Platinum 4x4Go 3000 C15 - Zotac 770 - SSD Samsung 850 Pro & 830
    Pump D5 with mod Bitspower - EK Supremacy - Koolance GTX680 - HW Labs SR1 280 & EK XTX 360
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    BTW, what do you think of trying out new swiftech's fans? Those have similar blades to GT, but sleeve/hydrodinamic bearings (thus potentially quieter at lowest rpms). Haven't seen yet comparative tests with them though. I'm guessing that GT might win in 1000-1800 range though. But it too is groundless guess/speculation.
    Apr 2008
    No, I do not know these fans, tests are available or not yet?
    The NB MultiFrame are very good (quiet and efficient) but not adapted for rad, I believe
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Taken from this post
    http://www.xtremesystems.org/forums/...=1#post4631619
    which is located in this topic
    http://www.xtremesystems.org/forums/...=1#post4612884
    Personally, I'd go with AP-13's if you never plan to go faster than 1150 RPM and run them @ full speed but, AP-14 and AP-15's are the ones chosen the most.
    Also, S-flex's seem to be getting hard to come by as they have been discontinued.
    Circles SucQ!
    Apr 2008
    Thank you very much ,
    The Gentle Typhoon are better if I understood. I think taking AP13, to turn ~800rpm, this is the most efficient and quieter for a rad Xchanger, (always if I understood correctly) right?
    The Scythe Kama Flow 2 are good or not (not seen in the test)
    Thank so much
    I am Xtreme
    Jun 2007
    PC Look claims to still have some AP-12 which run @800 RPM if you want to give them a try. I've thought about it but, it's too big a hassle to import them from a etailer in France I know nothing about to USA.
    http://www.pc-look.com/boutik/Prod_S..._21837_fr.html
    Circles SucQ!
    Apr 2008
    Thank you very much for your proposal
    There AP13 available and cheaper here
    http://www.docmicro.com/pieces/Scyth...-CFM_8914.html
    For you, AP12 and AP13 are the same (point of view performance and silence)?
    I will use a Fan Controller to have the AP13 to ~ 800rpm
    Thanks for your help
    I am Xtreme
    Jun 2007
    Sadly, I don't have any AP-12's and haven't seen any kind of review on them so, I don't know much about them. They disappeared from the U.S. market pretty quickly and by time I figured out I wanted to give a pair a try, they were long gone.
    I do have 10 AP-13's though and was prepared to use a pair on my current build but didn't quite have the room I needed to use them on a pair of MCR140's so I swapped for a pair of 140mm Bitfenix fans. They're not terrible but they are also not GT's. I'll sure I'll eventually use all my AP-13's somewhere, just a matter of how, where and when.
    Circles SucQ!
    Apr 2008
    Ok thank you for your help, I will use the GT AP-13 I think
    The NB PK2 is good with a radiator 140 (quiet and efficient) or What fan 140 (used horizontally)
    Thanks so much
    Jun 2012
    I personally use delta pwm 3500 rpm fans on my black ice gtx Gen 2 rads. I chose these because I am able to bench with the best possible cooling but am also able to drop those suckers to about 800 rpms before they start to pucker out. Its nice to not have to buy a fan controller to control speeds. I will always go pwm from this point on.
