Results 1 to 12 of 12
Thread: 2x Diff SSD
    I am Xtreme
    Dec 2001
    S.W, Florida
    2x Diff SSD
    Can you run a OCZ Agility 3 240gb and a Crucial M4 256gb SSD together in Raid0??
    Jul 2008
    In the space between...
    Sure you can run em together...not sure what to expect performance wise as they are 2 totally different type controllers that handle incompressible data in totally opposite ways. Now I'm curious...:P
    'Best Bang For The Buck' Build - CM Storm Sniper - CM V8 GTS HSF
    2500K @ 4.5GHz 24/7 - Asus P8Z68-V Pro Gen3 - GSkill 2x4GB DDR3-2400 C10
    Sapphire Vapor-X 7770 OC Edition - PC Power & Cooling Silencer MkIII 600W
    Boot: 2x 64GB SuperSSpeed S301 SLC Raid 0 Work: Intel 520 120GB
    Storage: Crucial M500 1TB - Ocz Vertex 4 128GB - 4x 50GB Ocz Vertex 2
    HDDs: 2 x 1TB WD RE4 Raid0 - Ext.Backup: 2 x 1.5TB WD Blacks Raid 1
    Xtreme Cruncher Russ_64's Avatar
    Aug 2005
    London, UK
    I have been thinking about something similar as I have a Vertex 4 128gb and an unused Vertex 2 120gb - they are different controllers and SATA2 / 3......... ??
    PS - If I was to try it, what is the best backup software to move a Windows 7 OS boot partition from single to RAID SSD's ?
    Asus Maximus VIII Ranger Z170 : Core i5-6600K : EVGA RTX2080 XC : 16Gb Corsair Vengeance DDR4-3200 : 256Gb Crucial MX500 : Corsair H100i : PCP&C 750w 60A : CM Cosmos S : Windows 10 x64
    Asus Z8NA-D6 : Dual Xeon E5645 : 24Gb DDR3-1333 ECC : MSI GTX470 : 120Gb Samsung EVO 840 : 1TB HDD : PCP&C 750w 60A : CM Stacker : DD MC-TDX, EK-FC470, RX240+RX120, D5 X-Top, BayRes : VMware ESXi 6.7.0 - VM's - WCG crunchers x 5 (Ubuntu 18.04 LTS), Mint 19, Windows 10 Insider Preview
    Sophos XG 17.5.3 running on GA-Z97-Wifi : Core i3 : 8Gb DDR3-1600 : 120Gb SSD : Corsair H80
    BenQ GW2765, Aten 4-port KVM, Asustor AS5002 4Tb NAS, Belkin 1500va UPS, Sky Fibre Max 80/20Mbps
    SLC
    Oct 2004
    Ottawa, Canada
    Depending on your workload, you either get the worst characteristics of both SSDs or an average between the two.
    Administrator andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    remember that if you RAID0 them it takes the lower capacity in your case 240 each you loose some space but nothing important
    for ex if you raid0 and 80 and 120 result is 160 of space
    cheers !
    Sergio
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
    I am Xtreme
    Dec 2001
    S.W, Florida
    Going to get another M4 and then do Raid0. Thanks for the replies.
    Jul 2007
    or you can leave the crucial for the OS ans some apps and run RAID0 on the other 2
    either way i would try to raid the 3 perfomance would be nice 3 RAID0 is awesome as theres NO impediment to do it
    I am Xtreme
    Dec 2001
    S.W, Florida
    I only have 1 of each.
    Jul 2007
    Quote Originally Posted by Hardass View Post
    yes sorry do it raid them and you will see perfomance is veryyy good
    this are my 2 intel series 520 sata 3 on raid0
    I am Xtreme
    Dec 2001
    S.W, Florida
    I am already running 2 M4 256gb in my main rig.
    I am Xtreme
    Dec 2001
    S.W, Florida
    The next Raid0 is for my gaming rig.
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    If you put them in RAID the speed will be constrained to multiples of the speed of the slowest member of the RAID.
    So you will basically get the speed of the agility times two.
    that is when fresh though! This being SSDs we have to remember the steady state performance. Even though not as critical in consumer apps, it is very important, even moreso when used in RAID, which has no TRIM (unless possibly under a very certain set of circumstances).
    That agility 4 is going to be terrible in steady state. it is a value ssd for a reason. i think yo9u are headed in the right direction with going with the M4s, and use the Agility for games or data storage or something.
    "Lurking" Since 1977
    Jesus Saves, God Backs-Up
    *I come to the news section to ban people, not read complaints.*-[XC]Gomeler
    Don't believe Squish, his hardware does control him!
