Results 1 to 16 of 16
Thread: mcp 355 Pump replacement suggestion
    Nov 2007
    looking for dual pump option to replace laing (mcp 355) , i been replacing dead pumps like battery's now
    using EK dual ddc top v2 with x2 ddc 355 , 4 have failed already and iam getting tired of this replacements
    each time one fails i go back to single D5 vario or use x2 12w ddc look alike till my replacement comes
    *D5 total run is more then 2 off my top ddc runs combined >.>
    *12w ddc in series using tube (wont fit any after market top , 2 in series equals to 1 mcp355)
    should i go for D5 Vario with EK dual top ? or is there a better pump option that i should look into
    Administrator andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    mcp35x amazing pump replaced my D5 for it no noise super power
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
    Nov 2007
    Quote Originally Posted by andressergio View Post
    it looks good , but the void warranty using a top turns me away from it
    Dec 2009
    Brisbane, Australia
    Quote Originally Posted by warmage View Post
    If your looking for dual pumps then the MCP35X2 is hard to beat, great performance, no need to replace the top, pwm control, low noise, it's a gem.
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    If your burning through pumps that fast, I'd have to question whether if the flow rate is excessive (2+ GPM) or if the pumps are sitting on something that may trap the heat and release it back into the pump housing. Pumps do not like having a "light" load on them (which would be a byproduct caused by excessive flow rate) and they'll actually draw more power which will burn out something on the pcb sooner or later.
    Circles SucQ!
    Jul 2007
    Quote Originally Posted by Liam_G View Post
    +1 for this
    Mar 2011
    If you are having pumps die that often I'd have to question wether they are spinning too fast due to a lack of pressure and burning out.
    Do you really need two pumps in serial?
    Nov 2007
    setup is EK HF cpu block , EK 6970 block , 150ml res and PA120.3 , 3/8" tubing and fittings
    pumps are mounted on alum plate
    dead 355 pumps are
    1- stock top swiftech 355 (single) dead 2008
    2 swiftech 355 with XSPC top (single) dead 2009
    3- laing 1plus (ek dual ddc top , that had an extra 6970 card) bought and died in 2011
    4- laing 1plus (ek dual ddc top , my current setup) dead 2 days ago 2012
    dual pump gives an extra fail safe for me , if one fails i have another running till i notice it >.>
    which happened 2 times now
    iam looking into that atm , any data of they are more reliable then ddc 355 ?
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    i really like the CPX pro 18W, you can get them from EK, DD, and directly from jingway as the dp1200. they drop less heat in the loop and my temps went down 2c when i swapped my ddc with ek top for one.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    This gets my vote. Use the PWM to run the pumps @ 2000RPM. They should last considerably longer, you still have redundancy, and it will be very quiet.
    Oct 2003
    USA /okla
    My Dual D5 vario are like the energizer bunny it keeps going and going
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
    Xtreme Cruncher Russ_64's Avatar
    Aug 2005
    London, UK
    Quote Originally Posted by Vicey View Post
    I am with Vicey - two pumps are not needed for a single CPU/GPU/RAD/RES loop. I have both a single D5 and single MCP355 with ample flow.
    Asus Maximus VIII Ranger Z170 : Core i5-6600K : EVGA RTX2080 XC : 16Gb Corsair Vengeance DDR4-3200 : 256Gb Crucial MX500 : Corsair H100i : PCP&C 750w 60A : CM Cosmos S : Windows 10 x64
    Asus Z8NA-D6 : Dual Xeon E5645 : 24Gb DDR3-1333 ECC : MSI GTX470 : 120Gb Samsung EVO 840 : 1TB HDD : PCP&C 750w 60A : CM Stacker : DD MC-TDX, EK-FC470, RX240+RX120, D5 X-Top, BayRes : VMware ESXi 6.7.0 - VM's - WCG crunchers x 5 (Ubuntu 18.04 LTS), Mint 19, Windows 10 Insider Preview
    Sophos XG 17.5.3 running on GA-Z97-Wifi : Core i3 : 8Gb DDR3-1600 : 120Gb SSD : Corsair H80
    BenQ GW2765, Aten 4-port KVM, Asustor AS5002 4Tb NAS, Belkin 1500va UPS, Sky Fibre Max 80/20Mbps
    May 2009
    Upstate, SC
    jesus how are you killing so many pumps? i just went 4yrs on a single DDC3.2 with a GPU block, Swiftech GTZ, Viperjohn chipset block and a pair of Bitspower mosfet blocks thru an MCR320... you need to stop jamming 17v into your pump or something
    SYSTEM
    i5-3750K @ 4.6ghz - ASRock Z77 Extreme4 - 16GB Samsung DDR3 - Sapphire R7 370 Nitro 4GB
    Water Cooling
    EK Supremecy - DDC-3.2 w/XSPC Top -Swiftech MCR320-QP - EK Multioption 150
    Nov 2007
    Quote Originally Posted by RoadconeTuning View Post
    you sound hostile for some reason , regarding voltage its getting 12.4v max and 2 died in a single pump config in a year and a half one with stock top other with XSPC top
    waiting for the new EK D5 dual top , my other option is Swiftech MCP35X2
    I am Xtreme
    Jun 2007
    Dual pumps is total overkill for that setup. If you must have 2 pumps, go for a pair of MCP350's. . .otherwise, go with a single MCP35X.
    Circles SucQ!
    Sep 2007
    Coimbra - Portugal
    Well I wouldn't thing that achieving >2GPM is that easy. This are my results with different blocks using two mcp-35x in series.
    CPU: Chart
    GPU: Blocks 2x FC7970 parallel
    3x360 Rads
    Only top performer went for ~2GMP, and this is with the GPU blocks in parallel, so less restriction then a single GPU block.
