    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 25 of 25
Thread: OCZ announces Indilinx Barefoot 3 on the way...taking it to the next level...
    Jul 2008
    In the space between...
    Looks like the beginning of the next gen ssd...can't wait.
    'The OCZ/Indilinx Barefoot 3 controller utilizes internally designed - the first time for OCZ - Aragon 400MHz 32-bit processor. The Aragon core supports an SSD specific RISC instruction set, allowing most instructions and branches to be executed in a single cycle, OCZ claims. The chip is set to be made using 65nm process technology at Taiwan Semiconductor Manufacturing Co. OCZ believes that the new Barefoot 3 SoC will significantly boost performance of its SSDs.'
    From Ryan Peterson, CEO
    "When implemented in SSD controller, this the [Aragon 3 core gives] a much higher performance than when using an off-the-shelf embedded safety field. This design opens a world of new possibilities for game changing SSD solutions as it supports unprecedented levels of processing power"
    http://www.xbitlabs.com/news/storage...ontroller.html
    The timing is also looking about right for them to use the new Intel 20nm nand and the new Toshiba 19nm toggle which will help keep the price down. Afaik SandForce's next controller isn't due out til Q2 2013 so Ocz doesn't have to rush the launch and profit before the other makers could get the controller too. Hope it's available by xmas.
    'Best Bang For The Buck' Build - CM Storm Sniper - CM V8 GTS HSF
    2500K @ 4.5GHz 24/7 - Asus P8Z68-V Pro Gen3 - GSkill 2x4GB DDR3-2400 C10
    Sapphire Vapor-X 7770 OC Edition - PC Power & Cooling Silencer MkIII 600W
    Boot: 2x 64GB SuperSSpeed S301 SLC Raid 0 Work: Intel 520 120GB
    Storage: Crucial M500 1TB - Ocz Vertex 4 128GB - 4x 50GB Ocz Vertex 2
    HDDs: 2 x 1TB WD RE4 Raid0 - Ext.Backup: 2 x 1.5TB WD Blacks Raid 1
    Xtreme 3D Team
    Jan 2009
    Ohio
    Hmm controller on a 65nm process at TSMC, why not 40nm?
    Smile
    Apr 2011
    North Queensland Australia
    But how much faster can we get on SIII? Or is PCI-E 1x/4x perhaps the new way forward for 600Mbps+ consumer drives (not including Revo's etc as consumer class drives).
    -PB
    -Project Sakura-
    Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
    2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
    Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
    Sep 2010
    Australia / Europe
    To be honest Paul I am of the opinion that SIII was already saturated bandwidth wise because the the sheer performance of SSD's I would also be of the idea to have PCI-E based boot drivers. I would really love to see a range of PCI-E 120GB for under $200 that could fill this market gap.
    この世界には 人の運命を司る 何らかの超越的な 〝律〝...... 〝神の手〝が 存在するのだろうか? 少なくとも 人は 自らの意志さえ 自由にはできな
    Jul 2008
    Yeah, 'sata via PCI-E' based solutions are in the making...would be 4x/8x for PCI-E 2.0 or x1/x4 for 3.0 probably. A Barefoot 3 based Revo or Revo X2 would simply be a beast. But there is still lots of room for improvement within sata3 besides just seq top speed...I'd like to see 250MB/s+ 4k writes or something wild like that. :P
    Xtreme 3D Team
    Jan 2009
    Ohio
    Why don't companies just start developing PCI-E x4 cables and compatible 2.5" drives?
    You know, like a riser cable
    Smile
    Sep 2010
    Australia / Europe
    ^^^ ohhh super F-KING idea!!! quickly Paul! To the Patent Lab!!!!..... we need to files ourselves a whole bunch of IP's
    edit*** and at post 1000 this idea cannot be wrong!
    Xtreme 3D Team
    Jan 2009
    Ohio
    Alright, I must be a genius now.
    Really though, RevoDrives in 2.5" form factor with a riser cable (those of which do exist, and are used all the time) would be great.
    Smile
    Jul 2008
    I think we can look forward to a few new ways to blow past sata3 limits by using PCI-E without using a $300 raid card.
    Sep 2007
    CA Bay Area
    Guys, SATA 4.0 is just around the corner...
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    SSDs are not about max throughput, the small IO speed matters more. there is plenty left in sata III for that.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Jul 2008
    Quote Originally Posted by zanzabar View Post
    +1...bring on the crazy low queue depth 4k write speeds!
    Mar 2010
    Istanbul
    There is still plenty of room to improve 4K speeds which is OCZ talking about.. When you are dealing with thousands of small files you are left alone with your processor..
    Oct 2004
    Where is that PCIe-Marvell-SSD without SATA/RAID burden they showed in January?
    Jan 2009
    Near Venice as they say
    I hope they are gonna develop better their firmwares also.
    TRUE Lapped - Intel Core i7 2600k 4,7Ghz - ASRock P67 Extreme4 Gen3 - Nvidia GTX 1080 FE - 16Gb Crucial 2133 Mhz CL9 1,51v - Crucial M4 256Gb - Crucial MX300 1050Gb - Corsair AX850 - Fractal Define R3
    Apr 2011
    Quote Originally Posted by kuroikenshi View Post
    -PB
    -Project Sakura-
    Jun 2003
    Italy
    I'm fetching Barefoot,
    (not) headed for a spin
    3570K @ 4.5Ghz | Gigabyte GA-Z77-D3H | 7970 Ghz 1100/6000 | 256GB Samsung 830 SSD (Win 7) | 256GB Samsung 840 Pro SSD (OSX 10.8.3) | 16GB Vengeance 1600 | 24'' Dell U2412M | Corsair Carbide 300R
  18. #18
    Oct 2006
    Quote Originally Posted by paulbagz View Post
    -PB
    Who cares? What I would like to see is random 4k to be pushing sataIII bandwidths. That would be something impressive. Sequential performance barely means anything, and we havent even broken Sata 1 bandwidths (single drive) with random4k speeds yet.
    What I am most concerned with though is who actually designed the processor and firmware? Because If OCZ designed the processor that makes me EXTREMELY skeptical of it. I would want to wait out a whole generation before purchasing one, just so we know the bugs are worked out. OCZ may have cool people working for them and great customer service, but their engineering ability and technical expertise are 2nd to everybody.
    I did a quick google search and came up with nothing. oes anyone know what kinda specs are on this processor? Dual core? triple? maybe even quad?
    Rig 1:
    ASUS P8Z77-V
    Intel i5 3570K @ 4.75GHz
    16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
    Nvidia GTX 670 4GB SLI
    Rig 2:
    Asus Sabertooth 990FX
    AMD FX-8350 @ 5.6GHz
    16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
    AMD 6950 with 6970 bios flash
    Yamakasi Catleap 2B overclocked to 120Hz refresh rate
    Audio-GD FUN DAC unit w/ AD797BRZ opamps
    Sennheiser PC350 headset w/ hero mod
  19. #19
    Aug 2007
    Arlington VA
    Quote Originally Posted by BeepBeep2 View Post
    Probably has to do with what the market is for SSDs. An SSD has always been a much better upgrade for a laptop than a desktop simply due to size, battery, and heat concerns. So we've seen SSD's appear in just about every form factor possible for mobile devices. Desktops.... for most people desktop = "low budget purchase only if broke" style box, why waste an SSD on it? And while PCI-E riser cards are common for servers nobody sticks these desktop MLC based drives in those.
    AMD Phenom II BE, ASUS Crosshair II formula, 8gb ddr2 800, 470 SLI, PC P&C 750, arcera RAID, 4x OCZ Vertex2, 2x samsung 7200 1tb, HT Omega Clario +
  20. #20
    Sep 2007
    CA Bay Area
    Quote Originally Posted by EniGmA1987 View Post
    Vertex 4 gets over 300mbps with 4KRW. That's not SATA1 speeds...
  21. #21
    Mar 2010
    Istanbul
    Quote Originally Posted by Kain665 View Post
    he's talking about @QD1, up to 5 or 6 is already extreme for desktop usage.. and probably you will never see higher than that.. QD32 or 64 is just meaningless for a Desktop SSD..
  22. #22
    Sep 2007
    CA Bay Area
    Quote Originally Posted by kaktus1907 View Post
    As low as QD3 will still net you over 300Mbps.
  23. #23
    Jan 2009
    that means we still have room to nearly double the performance
    honestly, I wish we could choose firmware that optimized 4Ks over seqs. I would gladly give up hundreds of sequential Gbs for much faster 4ks
  24. #24
    Aug 2008
    SF bay area, CA
    ...OCZ may have cool people working for them..
    I'm guessing you have never dealt with the executives over there
    "Red Dwarf", SFF gaming PC
    Winner of the ASUS Xtreme Design Competition
    Sponsors...ASUS, Swiftech, Intel, Samsung, G.Skill, Antec, Razer
    Hardware..[Maximus III GENE, Core i7-860 @ 4.1Ghz, 4GB DDR3-2200, HD5870, 256GB SSD]
    Water.......[Apogee XT CPU, MCW60-R2 GPU, 2x 240mm radiators, MCP350 pump]
  25. #25
    Sep 2007
    CA Bay Area
    Quote Originally Posted by zads View Post
