+ Reply to Thread
Results 1 to 18 of 18
Thread: 3770k failing again
    Xtreme Cruncher masterg's Avatar
    Oct 2006
    A place the sun don't shine (Seattle)
    19
    3770k failing again
    so my 3770k system is dying again. first it would heat up and bsod due to GPUs getting hot. or it would freeze and lockup the desktop. i pulled them out, cleaned them and reseated them, cleaned out H100 rad too. i will get an aftermarket cooler on when i get time. started it up and still seizing when the gpus run Milkyway@home. I disabled MW@H and i wake up this morning to a BSOD thats stuck: 0x0000009C MACHINE_CHECK_EXCEPTION
    have no idea why this keeps freezing and dying. this is how it started the last time my ssd failed tho
    Intel C2Q Q9550 2.83ghz :: Intel DQ45CB :: 4 x 2gb OCZ DDR2 PC2-8500 Reaper HPC :: ASUS EAH5850 :: Thermaltake TR2 RX 750w :: Western Digital Caviar Black 4 x 750gb in RAID 10
    Intel e3-1235 3.3ghz :: Intel s1200kp :: 4gb kingston hyperX 1600mhz :: WD 500gb Cavier Green
    Intel i7-3770k 4.4ghz :: msi z77ma-g45 :: 8 gb patriot Signature 1600mhz :: 160gb WD Cavier :: 5830 + 5870 CF :: Antec Earthwatts 650w
    "...all men die, and no brave man lets death frighten him from his desire..."
    Nanoseconds from Permaban retro77's Avatar
    Mar 2008
    Southern California
    217
    Do you think its some faulty hardware? How does it run in default BIOS settings?
    I am Xtreme andressergio's Avatar
    Jul 2007
    Montevideo - Uruguay
    90
    Quote Originally Posted by retro77 View Post
    agree with the mate try stock, you pulled the IHS of the 3770K ? if not do so willl drop 10C certified
    freeze could be many things first MEM, run a memtest and let it pass 400% 4 instances at 1500RAM if you are runing 8GB
    but first of all go stock and play watch movies give it a heavy use ok ?
    then report back
    also can be BIOS corrupted u can try to reflash again
    cheers and best of lucks
    Sergio
    ASUS M5E BIOS 1707 new RAID ROM
    I3770K@5Ghz HT on Water
    2x4Gb Gskill TridentX 2666CL10-12-12-31 1T
    2x ADATA SSD SX900 256GB Sata III
    1x SEAGATE ST3000DM001 3TB Sata III
    3x SLI GALAXY GTX680 SOC on Water
    CORSAIR AX1200
    SAMSUNG 32EH5300 LCD TV
    Coolermaster HAF X / Lamptron CW611
    W7x64 SP1
    Oct 2006
    19
    cpu temps are mid 60s running a push pull H100 on it. GPUs were hitting 80c and thats what was causing it to crash earlier
    Jul 2007
    90
    Quote Originally Posted by masterg View Post
    take the IHS replace tim and reseat 10C less certified and more stable
    you got all on the Gene 5 thread
    or PM me
    cheers !
    Sergio
    CORSAIR AX1200
    W7x64 SP1
    Oct 2006
    19
    I really dont have the money to make sure i don't fuzk it up, so id rather not try.
    Jul 2007
    90
    its so easy that u cannot up anythin mate it goes off so fast you will not notice but as u wish u want high clocks on and on AIR ? then u must do it
    CORSAIR AX1200
    W7x64 SP1
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    Event Horizon
    6
    Quote Originally Posted by andressergio View Post
    H100 is a corsair water cooler with a double rad.
    3770k L221B009 @4500mhz 1.2v HT on IHS Tim replaced | ASUS Maximus V Gene | G.SKILL F3-2400C10D-16GTX | CORSAIR AX850 PSU | GTX 680 water cooled | Swiftech MCP35X | 2x PA120.3 | Swiftech APOGEE-XT
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    If he's running in the 60s temps shouldn't be the issue. A bit warmer, yes, but temps alone shouldn't be causing the BSODs.
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
    Oct 2006
    19
    I have a 5830 and a 5870 vapor-x in crossfire with the 5830 on top. right next to each other, 5830 is clean and its speeds have been halfed from 800/1000 to 400/500 and still pushing 80C. i turned off the gpu crunching and its fine for now, i think the 5830 needs a new heatsink, the fan could be dead for all i know, cant exactly see it when its all running
    Jul 2007
    90
    Quote Originally Posted by dengyong View Post
    yep didnt read that thanks
    CORSAIR AX1200
    W7x64 SP1
    Oct 2006
    19
    event logger says its a power management issue on core 0. and parity issue
    Performance power management features on processor x in group 0 are disabled due to firmware problem. Check with the computer manufacturer for updated firmware
    Xtreme Cruncher Conquistador SW's Avatar
    Jan 2009
    The Hague, Netherlands
    9
    I never heard of that power managment issue before.
    I have some experience with the WHEA error parity issue though. I noticed that even though Linx/prime95 will never fail and so you think it is stable at a certain voltage, there will still be some WHEA errors until you raise the voltage further.
    My 3770k was linx/prime95 stable at 4.7Ghz at 1.26v, but the WHEA errors only disappeared when I got to 1.31v.
    Maybe raising the core voltage will help solve your problems.
    3770K 4.7Ghz 1.32v / ASUS P8Z77-V PRO / 8GB DDR3 1866 9-9-9-27 /ASUS HD7970 1025MHz / Antec NeoHE 550 / Samsung 830 256GB Crunching
    Cooled by PA120.3, EK-HF, D-tek Fuzion GFX, DDC3.1 XSPC res/top
    i5 2400 Stock / ASUS P8P67 LE / 4GB DDR3 1600 / HD7950 1050MHz / Seasonic S12II 430W / Intel G2 40GB Crunching
    2600K 4.6Ghz 1.34v / ASUS P8Z68-V PRO / 8GB DDR3 1600 8-8-8-24 / Antec 430W / Intel G2 80GB Crunching
    W3520 4.0Ghz 1.19v / Rampage II Gene / 6GB Kinston Value 1333 / 9800GT / Corsair TX650 / Antec mini P180 / Intel G2 160GB Crunching
    Intel G860 Stock / Gigabyte H67MA-UD2H-B3 / 4GB DDR3 1333 / Antec Earthwatts green 380W / Crucial M4 64GB Crunching
    E6600 3.2Ghz 1.36v - P5B Deluxe / i7 930 4.0Ghz 1.29v - ASUS P6X58D-E / Q9450 3.6Ghz 1.28v - Rampage Formula Retired
    Xtreme Cruncher WhiteFireDragon's Avatar
    Jul 2007
    @ the computer
    0
    How is 80C even considered hot? I ran my gtx295 for several months 24/7 at 105C doing gpu crunching for gpugrid, knowing that it's a suicide run but somehow the video is still perfectly fine lol. I also did bitcoin last year for a little bit with AMD cards, 80C is pretty normal. This is with 4 cards stacked on one mobo. I don't think that temp is what caused your crash.
    Jan 2009
    9
    Indeed, with my HD5870, the fan profile only started to really ramp up the fan when it hit 80C. It would only reach max rpm at 90C, so AMD apparently thought 90C should be an acceptable max temperature.
    Oct 2006
    19
    ok, maybe it wasnt gpu then. it just seemed like it was the most obvious answer. event logger says otherwise
    Mar 2006
    Ohio, USA
    44
    If it does this even at stock speeds I'd start suspecting motherboard or the CPU itself even. I've had a defective CPU in the past.
  18. #18
    Oct 2006
    19
    its running 99.5x44
+ Reply to Thread
