+ Reply to Thread
Results 1 to 2 of 2
Thread: DeathAdder 1800 DPI vs Respawn
    Registered User Piospi's Avatar
    Oct 2009
    0
    I have an old Razer DeathAdder 1800DP and Steelpad 5LI. Unfortunately, started to go bad.
    As it has Respawn? Is it better than the old Razer? I have to buy a new mouse or fix the old?
    I'm confused
    i5 3750K + EK Supreme HF Full Nickel | Asrock Z77 Extreme4 | G. Skill ECO 1600 MHZ CL7 2x4GB | Seasonic X-Series 760W Gold
    EVGA GTX 480 + EK Acetal Nickel | Samsung 2233RZ
    Samsung 830 128GB | Samsung F3 1 TB | Samsung SH-S222AB
    Xonar ST + H6 | Sennheiser HD 555
    Obsidian 800D | Swiftech 350 |EK-DDC X-RES 140 Acetal | Phobya G-Changer 360
    BQ SilentWings 3x120mm | BQ SilentWings 2x140mm | Zalman ZM-MFC1
    Xtreme Member ArCElM's Avatar
    Jul 2006
    0
    Very much depends on how serious you take your FPS games.
    The facts are, the 3G sensor destroys the 3.5G sensor in every way, other than DPI, but since people have started to think DPI actually means something mice brands are all gunning for thehighest DPI possible at the cost of functionality, versatility and reliability.
    Hmm, well, to try and answer your question more directly, no the respawn is not better than the original.
    ASUS P8Z77-V PRO
    Core i7 2700K @ 4.8Ghz | H80
    Gigabyte Windforce HD 7970
    8GB Crucial Ballistix Elite 1866Mhz
    2x 128GB Samsung 830 RAID-0
    Corsair AX750W
    Silverstone FT02
+ Reply to Thread
