+ Reply to Thread
Results 1 to 4 of 4
Thread: PSU Sleeved... next step?
    Jan 2012
    Chicago
    0
    Hey guys! Quick question... I have finished sleeving my PSU but am a little nervous just plugging it in the motherboard and other components directly to try it out. I'm afraid that if I mixed up a wire or one of the pins that it's going to fry everything. Any suggestions? I'm not even sure if this is possible?
    Hackintosh Lover davidkozat's Avatar
    Aug 2009
    Between London & Eastbourne, United Kingdom
    10
    Try powering it on its own? and use a Multimeter? maybe power fans or stuff you dont mind blowing??
    Why Not Try a Hackintosh for A Change?? Steps HERE!!
    Want to installing Mountain/Lion from a DVD or USB on you Apple PC?? Steps Here!
    OLD RIG
    HAF 932 Modded Case
    http://img192.imageshack.us/i/img0416nv.jpg/
    http://img502.imageshack.us/i/img0417w.jpg/
    MB: Asus P6X58D-E
    CPU: Core i7 950 @ 4.2 Ghz @ 1.336
    RAM: 24Gb DDR3 Corsair @ 1600 7-7-7-20-1T
    GPU: 480GTX 700/1400/1848 @ 1.038
    HDD: 4 Tb Raid 0 Data
    SSD: 4 X 120 GB Agility 3 RAID 0 OS Win7/Lion Speed
    Super Stable aKa 24/7
    Winners of EURO 08 | World Cup 10 | EURO 12
    Quote: Killin' Tube Kinks One Coil At A Time
    Hackintosh Lover
    "Dumb people" shouldn't use "Smart Phones"
    New Personal Wallpapers Selection
    I am Xtreme Zeus's Avatar
    Feb 2003
    Netherlands
    7
    Just get one of these:
    They're dirt cheap, see here:http://www.dealextreme.com/p/pc-comp...r-33393?item=1
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Xtreme Addict NEOAethyr's Avatar
    Sep 2010
    US, MI (Muskegon)
    16
    Do what davidkozat mentioned, power it up with a small load, like a fan.
    Make sure to check the colors of your wireing, if you can't do that then check with a meter, make sure all of the cables are correct.
    One screw up on a hd power cable, and bye bye drive...
    You can get wiring diagrams online on google images.
    Just look up atx connector, or something like that.
    Then test away with the meter.
    CPU: AMD Phenom 1090T
    CPU Heatsink: NZXT Kraken X60
    Mobo: ASUS Crosshair IV Formula (2101 BIOS)
    MEM: 2x 4gig ADATA XPG Gaming Series v2.0 [AX3U2000GC4G9B-DG2] (Hynix H9C-BFR)
    PSU: Seasonic X-750
    VGA: nVidia Grid VGX K2 (Only got 1 out of the 2 gpu's at the moment)
    Monitor: ASUS VG278HE & 3DVision2 Kit
    Drives: 2x WD Green 1TB Modified Drives (RAID 0), Corsair Force Series 3 CSSD-F60GB3A-BK 60GB SATA3 SSD, Pioneer BDR-2208 Blue Ray Burner
    Case: Rosewill Blackhawk Ultra
    OS's: Windows 2003 Enterprise x86 SP2-R2 VLM, Windows 7 Standard Embedded x86 SP1 EVL (128GB Patched)
    Mouse: Razer Abyssus (I smashed this because of a usb comflict, still have the prob though afterwards ..., using generic mouse for now)
    777
    Just ordered an Samsung Galaxy S IV i9500 Octo-Core Quad Band 16gb Unlocked.
    Should be getting the screen protector anyday now.
    Also got 64gig micro sd card but it turned out it's a bad card, rma'ing.
+ Reply to Thread
