+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 32
Thread: GTX 680 4GB SLI or GTX 670 4gb Tri SLI?
    Xtreme Enthusiast BringerOdeath's Avatar
    Dec 2008
    Franklin, TN
    0
    I got a hold of 2 more 30" monitors for dirt cheap and 3xgtx 480's isn't cutting it @7680x1600 on the games I play.....Would either one of these setups work? I could do triple gtx 680 4gb, but I will have to sell a kidney...:P. Anyone have an benchmarks on this res?
    (New build):MSI Big Bang X-power II with XSPC MB blocks, Core I7 3930k@4.6Ghz with HT on, 3x GTX 480 SLI with EK Waterblocks(for now), X-fi Titanium, Gskill quad kit 16GB 2133mhz, 2x240GB Corsair GT SSD's(raid 0), 3xWD 2TB drives, Silverstone Strider ST1500 Watt, Dell3007WFP and 2x Samsung 305T's. Water loop: EK HF CPU block, XSPC RX480 Rad, Coolgate GC480, Airplex Revolution 420 Rad, 2x DDC 3.25 18W with EK dual top, Caselabs STH10 white with customizations....
    Xtreme Enthusiast koc's Avatar
    Dec 2006
    Kuwait
    1
    since the GTX 670 almost the same performance of GTX 680, the gtx670 would be the best choice, but for 3x 30", i believe you need 4 way GTX 670 sli.
    Gaming rig;
    Asus MVF
    i5-3570K @ 4.2Ghz (1.2v)
    G.SKILL Ripjaws 16GB 2133 @2400MHz
    Intel 520 240GB
    2x GTX670
    Corsair AX1200
    HP ZR30w 30
    Sound rig;
    Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
    Dec 2008
    Franklin, TN
    0
    Wow, that's going to be spendy. Might as well go with 4 gtx 680 4gb since I can get them for about $550 and the 670 4gb is about $480. I have seen some benches that 3 cards can do it if you enable the pci-e 3.0 on my x79(sorry haven't updated my system specs here). 4 cards and waterblock is going to hurt me a bit....:P
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    0
    GTX670 or 680... doesn't really matter. At that resolution a SLi setup of either 670s or 680s will have their work cut out for them. As the performance between the two cards isn't earth shattering I would probably get some 670s, OC them for stock GTX680 and a bit performance, and pocket the savings.
    "Prowler"
    Asrock Z77 Extreme6 | i5 2500k @ 4.6GHz 1.4v | 2x4GB PC12800 Ripjaws @ 2133MHz 10-10-10-15 1T 1.55v | Sapphire HD7950 Vapor-X w\ Gelid Icy Vision A | Xonar DX 7.1 | 640GB WD Black | 2x Sony Optiarc | Corsair 850w HX
    Cooling:
    3x Coolermaster Sickleflow 120mm 70CFM fans | Modified CoolIT ECO sealed loop CPU cooler | Custom made "The Judge" VGA VRM heatsink
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    (\_/) This is Bunny.
    (+.+) Bunny is dead.
    (^ ^) Copy and paste Bunny into your sig to create an army of BUNNY ZOMBIE MINIONS!!!
    Dec 2008
    Franklin, TN
    0
    Do you think 3xgtx 670 4gb with the pci-e hack would be powerful enough to run bf3@7680x1600 with AA off on ultra?
    Xtreme Addict Chickenfeed's Avatar
    Jul 2007
    Alberta, Canada
    5
    I'd look over these results here,
    http://www.tomshardware.com/reviews/...nd,3162-5.html
    http://www.anandtech.com/show/5805/n...-ultra-fast/11
    Take in mind this only reflective of single player performance. As I'm sure you know by now multiplayer can be a lot more demanding.
    Also you are talking of pushing over 12MP vs shy of 7MP. Thats significantly more so all that said I have my doubts that even 3 680s would run that setup at a respectable clip on Ultra in BF3. Perhaps you can check on various forums and you might get lucky enough to find someone crazy enough to already have tried that kind of setup
    Feedanator 6.0
    CASE:FT02B|PSU:AX850|CPU:i7 4770K|Mobo:Z87 Pro|Ram:8x2GB GSkill 2400|GPU:SLI GTX 780 3GB|HD:M4 128GB+256GB/F1 1TB|SOUND:Titanium HD,PC350|LCD:QH270-lite|OS:Win8 x64 Pro|INPUT:SS Sensei /w HD9/DasUltSilent|COOLING:H80
    Htpcanator 2.0
    CASE:Fractual Mini|PSU:X660|CPU:i5 2500K|Mobo:MIV Gene Z|Ram:4x4GB GSkill 1600|GPU:GTX 670 2GB|HD:M4 128GB+256GB/F3 1TB|TV:ST30 50"SOUND:HTRC360/Klipsch 5.1|NAS:DS212+ 2TB Raid1
    Apr 2004
    United Kingdom
    0
    Quote Originally Posted by BringerOdeath View Post
    I doubt it. Probably high settings, but the same can be said of the 680s in that scenario. If you really want to run crazy high settings like that really you are looking at 2 or 3 GTX690s.
    "Prowler"
    Cooling:
    RAIDer
    Jul 2005
    19
    Quote Originally Posted by ket View Post
    i doubt it. Probably high settings, but the same can be said of the 680s in that scenario. If you really want to run crazy high settings like that really you are looking at 2 or 3 gtx690s.
    lol :d
    Xtreme Addict Andrea deluxe's Avatar
    Jan 2009
    Italia
    13
    3 x 670 4gb
    Nanoseconds from Permaban [XC] Oj101's Avatar
    Jan 2006
    South Africa
    268
    Most GTX 670 reviews were done with newer drivers than the GTX 680 reviews, newer drivers which offered more performance. I've played with both and the GTX 670 at 1,200 MHz comes close but can't quite touch a stock GTX 680. I'd say the performance difference is pretty decent. As you add more cards, scaling also becomes less and less efficient, so based on these two points I'd rather go for three GTX 680s than four GTX 670s.
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    Xtreme Enthusiast UrbanSmooth's Avatar
    Jun 2005
    Madison, WI
    27
    At that resolution, four GTX 680 4GBs or bust. Also, get yourself a board that will do full x16 PCI-e 3.0.
    Anything less would be uncivilized.
    \Project\ Triple Surround Fury
    Case:
    Mountain Mods Ascension (modded)
    CPU: i7 920 @ 4GHz + EK Supreme HF (plate #1)
    GPU: GTX 670 3-Way SLI + XSPC Razor GTX670 water blocks
    Mobo: ASUS Rampage III Extreme + EK FB R3E water block
    RAM: 3x 2GB Mushkin Enhanced Ridgeback DDR3 @ 6-8-6-24 1T
    SSD: Crucial M4 256GB, 0309 firmware
    PSU: 2x Corsair HX1000s on separate circuits
    LCD: 3x ASUS VW266H 26" Nvidia Surround @ 6030 x 1200
    OS: Windows 7 64-bit Home Premium
    Games: BF3, Crysis 3, Dead Space 3, MW2 (Dom only), TR2013
    Dec 2006
    Kuwait
    1
    This words from my friend who have 3x 30" HP monitor,
    With three GTX670 4GBs + (Asus R4E X79), he can not max the settings of all the games, and when he add one more GTX670 he get many errors while gaming, also he suffer from the bandwidth limit. and HE is thinking now to buy a full x16 PCI-e 3.0 z77 board.
    Gaming rig;
    Asus MVF
    Intel 520 240GB
    2x GTX670
    Corsair AX1200
    HP ZR30w 30
    Sound rig;
    Dec 2008
    Franklin, TN
    0
    Well Z77 boards don't have quad or triple SLI I believe. They only have SLI. I saw a lot of people that removed the bandwith limit by turning the pci-e 3.0 on with the patch (I think the guys name is callsignvega) which fixed the bandwith on the cards on 8x slots. LOL, the only board I have seen with 4 16x full speed slots is that SRX.....
    Xtreme Addict Boulard83's Avatar
    Mar 2009
    1
    670 4gb 3way. Cant need more power, it can run surround at that res with lots of candy.
    - Le Quebecois @ infodupat.com -
    - - - BTTB - - -
    Gigabyte Z87X-OC - 4770k - PH-TC14PE - 2x8gb Ballistix 1600 CAS8 - Zotac GTX780
    Tecnofront HWD BenchTable - Corsair HX750 - 2x Agility 4 256gb - Surround Asus VE278Q 5760x1080
    - - - HTPC - - -
    Asus Z77-m Pro - 2500K - NH-C12P - 2x4gb G.Skill Ares 1600mhz
    Asus GTX 650 TI - Agility 4 128gb - Enermax Naxn 550w - Lian Li PC-C60B
    - - - NAS/Server - - -
    Gigabyte H77m-D3H - G2020 - 2x4gb G.Skill 1600mhz - 2x 1TB Black - 1x 2TB green - CX430M
    Forum Quebecois, si tu parles francais !
    Jun 2005
    Madison, WI
    27
    Quote Originally Posted by boulard83 View Post
    BUT I NEED MOAR POWA, CAP'N!! SHE'S FADIN' FAST!!!!i!!
    Case:
    Dec 2008
    Franklin, TN
    0
    I am leaning towards 3x zotac GTX670 4gb and play at 5760x1200 on BF3. I should be able to max out on that res, but I do think that I can play that with my current setup though......maybe I should wait to see ATI 8 series or GK110....
    Urban since you have a similar setup to what I used to have, did you ever have an issue with scaling on triple sli? I always get an issue with usage dropping into the 30's on all 3 cards and then back to the 90's randomnly which causes stutter. Everything is new in my setup except for the vid cards and it is still doing this. Tried a different psu also, same issue. If I set any combination of the 3 cards in dual sli they work fine with scaling in 90's all the time.....Could one of the cards be bad?
    Xtreme Mentor Utnorris's Avatar
    Sep 2007
    Dallas
    11
    I know Vega switched to the Gigabyte Sniper Z77 and is using 4 x HD7970's for his 5 panel 2560x1440p setup (not sure what the res comes out too), so maybe you might want to ask him to see what he thinks. I believe he tried GTX680's originally, but I am not sure.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
  18. #18
    Dec 2008
    Franklin, TN
    0
    I thought vega was doing pci-e 3.0 fine on x79 with 4 gtx 680's. Isn't the z77 kind of a downgrade? Four 7970's work at pci-e 3.0 on x79, so why would he change?
  19. #19
    Jun 2005
    Madison, WI
    27
    Case:
  20. #20
    Sep 2007
    Dallas
    11
    Because his MSI took a big dump and the Gigabyte has 4 x PCIe 3.0 x8 slots, which is more than enough for current cards.
    Desk Build
    W/C System
  21. #21
    Jun 2005
    Madison, WI
    27
    Quote Originally Posted by Utnorris View Post
    Though, not enough for UrbanSmooth.
    Case:
  22. #22
    Mar 2011
    0
    If I can play BF3 at 7680x1600 with two GTX 480's on Medium with acceptable FPS then I think two GTX 680's with 4GB of memory would handle it on High/Ultra.
    The main issue I have with the game is the 1.5GB of graphics memory. I'm confident if I didn't have that issue I'd be able to play the game on high because I can play it fully maxed out with everything on Ultra at 2560x1600 and still get above 30 FPS with my 480's - I know 7680x1600 is a lot more but it's not that much more taxing on the rendering. It's just the memory usage which is so much higher.
    In other games for example: Team Fortress 2 (Yes an old title, but hear me out!) I get about 450FPS with the FPS limiter turned off with a single display (2560x1600) everything maxed out. Then if I bump that to 7680x1600 in surround mode I get over 300 FPS still. The memory usage is about 1.35GB though. I think it's the memory that makes the most difference because if you can't fit everything in to the frame buffer you're going to have a serious bottleneck as the game struggles to fit different things in to memory and that is when BF3 messes up for me when I increase texture sizes and other things like that which increase the memory use.
    So my advice: Get either the Two GTX 680's or Three GTX 670's - Don't get three or four GTX 680's like some of the above advice you've received because with what I see attempting to play BF3 on my system such hardware isn't necessary and I think you'll get more than acceptable performance with just two GTX 680's.
  23. #23
    Xtreme Addict CrazyNutz's Avatar
    Dec 2007
    Texas
    12
    You right. Three 680's, or 670's will have enough compute power to get the job done. However it is the vram that is the issue in this game. Will 4gb be enough to run that res on ultra?
    I can't say with 100% certainty but I think it may. Therefore i would do 3x 670's 4gb.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
  24. #24
    Dec 2008
    Franklin, TN
    0
    So I broke down and got 3x zotac gtx 670 4gb cards. They use the gtx 680 pcb and I can use GTX 680 waterblocks on them! . I got them for $440 each which wasn't too bad! After selling my gtx 480's with waterblocks it will put me out just under $1k for cards and waterblocks... I just hope I can actually get good scaling with the 670's, because for some reason I could never get scaling on my 3 gtx 480s above 40% on all 3 cards when running triple sli. If i just had 2 cards in SLI I got scaling in the %90 range, no matter which combination of the 3 cards I used. So it wasn't a bad card or anything and it behaved the same on x58 and x79.....
  25. #25
    Feb 2007
    0
    Yep, 3 690's is the only solution.
    If you have a spare counterfeiting machine, you could go 4 690's. get some octasli action
    Vista64 U.E, Lian Li PC-A71B, Samsung 305T Plus, GA-EX58-Extreme, i920 @3.33Ghz Turbo, TRUE 1366, 12GB DDR3 1333 Dominators + Fan, 2x GTX295 (SLi), 9 HD's = 4.8TB :Pirate: ,1x BD R\W, 2 x DVD R\W, Zalman 1000-HP, NST-400MX-SR, MS Desktop Elite, Pixma MP800, Netgear DG834G, PS3 + KDL46W3100 combo.
    HERMACLES V2.2 & 12Grand Central :leet: 3DMarkVantage = P32531 & X17340, wPrimeV2 = 32M 6.939sec - 1024M 210.416sec
+ Reply to Thread
