+ Reply to Thread
Results 1 to 3 of 3
Thread: Nibitor voltage issue?
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    0
    Ok, I might simply be forgetting something here but in a nutshell I have my P-States set up so (according to nibitor) P3 is 0.925v (I have custom 2D clocks), 1.025v for P7, while P12 and P15 are set for 1.125v. To my understanding, that means 2D voltage is 0.925v, Blueray / DVD playback voltage is 1.025v, while throttle / 3D clocks are 1.125v. The thing is nvidia inspector while apparently using the P7 state (I have dual monitors) reports the voltage as being 1.125v. Naturally, I don't want all that voltage running through the card. Heres a screenshot to make things clearer.
    "Prowler"
    Asrock Z77 Extreme6 | i5 2500k @ 4.6GHz 1.4v | 2x4GB PC12800 Ripjaws @ 2133MHz 10-10-10-15 1T 1.55v | Sapphire HD7950 Vapor-X w\ Gelid Icy Vision A | Xonar DX 7.1 | 640GB WD Black | 2x Sony Optiarc | Corsair 850w HX
    Cooling:
    3x Coolermaster Sickleflow 120mm 70CFM fans | Modified CoolIT ECO sealed loop CPU cooler | Custom made "The Judge" VGA VRM heatsink
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    (\_/) This is Bunny.
    (+.+) Bunny is dead.
    (^ ^) Copy and paste Bunny into your sig to create an army of BUNNY ZOMBIE MINIONS!!!
    Apr 2004
    United Kingdom
    0
    So... everybody is as confused as I am over this? I'll try editing a older vBIOS I have for my card with FBE instead of nibitor and see if it does the same thing, And yes, the reason I haven't used FBE with this newer vBIOS for my card is simply that FBE doesn't recognise it, just says "unrecognised device" with everything greyed out when I try opening the file.
    "Prowler"
    Cooling:
    Apr 2004
    United Kingdom
    0
    Nevermind I figured it out. What appears to be throttle clocks aren't throttle clocks at all, they are a seperate speed profile for if you are using dual monitors.
    "Prowler"
    Cooling:
+ Reply to Thread
