+ Reply to Thread
Results 1 to 7 of 7
Thread: TEC Cooled Phase Change Conderser
    Xtreme Enthusiast rintamarotta's Avatar
    Jun 2007
    Finland
    3
    Would it work to cool partly my Phase Change Units Condenser with TECs?
    Where i would put them is at the top of Condenser.
    It will be really hot in here at summer and i would like to keap my Phase Change unit bit more quieter and that would require to ramp my PhaseChange units fans down litlebit what would in turn cause higer temperatures.
    There allready is some noise dampening material at the sidepanels of LD's Phase Change unit i have in here.
    I can stand the sound of compressor but fans need be put to full at middle of summer and they create hell of a noise.
    ::: Desktop's - Intel *** Intel 2
    2 x Xeon E5-2687W *** Intel i7 3930k
    EVGA SR-X *** Asus Rampage IV Extreme
    96Gb (12x8Gb) G.Skill Trident X DDR3-2400MHz 10-12-12-2N *** 32Gb (8x4Gb) G.Skill Trident X DDR3-2666 10-12-12-2N
    3 x Zotac GTX 680 4Gb + EK-FC680 GTX Acetal *** 3 x EVGA GeForce GTX780 + EK Titan XXL Edition waterblocks.
    OCZ RevoDrive 3 x4 960Gb *** 4 x Samsung 840 Pro 512Gb
    Avermedia LiveGamer HD capture card
    Caselabs TX10-D
    14 x 4 TB WD RE4 in RAID10+2Spare
    4 x Corsair AX1200
    ::: Basement DataCenter :::
    [*] Fibreoptic connection from operators core network
    [*] Dell PowerConnect 2848 Ethernet Switch [*] Network Security Devices by Cisco
    [*] Dell EqualLogic PS6500E 96Tb iSCSI SAN (40 2Tb Drives + 8 Spare Drives, Raid10+Spare Configuration, 40Tb fail safe storage)
    [*] Additional SAN machines with FusionIO ioDrive Octal's (4 total Octals).
    [*] 10 x Dual Xeon X5680, 12Gb DDR3, 2x100Gb Vertex 2 Pro Raid1 [*] 4 x Quad Xeon E7-4870, 96Gb DDR3, 2x100Gb Vertex 2 Pro Raid1
    [*] Monster UPS unit incase power grid failure backed up by diesel powered generator.
    Xtreme Member Calathea's Avatar
    Feb 2010
    Sweden
    14
    No, you'd simply dump even more heat in to your room.
    Overclocking, it's a lifestyle
    Xtreme Addict Circaflex's Avatar
    Dec 2004
    Southern California
    2
    with a TEC you still need to cool a hot side, so your not going to eliminate the heat from your room just add to it. I guess really only thing you could do, but would require modding is watercool your phase unit and have the radiator outside but that is extreme.
    Pentium 4 3.2E (SL7PN E0) @ 4246.46 MHz (265.4 * 16) 1.48cvore
    Intel Core i7 3930k@ Stock (Still testing) - ASUS Rampage IV Extreme - 16GB (4 x 4gb) GSkill TridentX@ Stock - 2x eVGA GTX 670 FTW - Creative Titanium HD - 2 x Cruicial m4 256GB SSD (RAID0) - 4 x 74GB Raptors (RAID0) - Antec TPQ-1200
    Phase unit by runmc @ full load -33
    H2O Loop - MCP35X+Heatsink w/RES>MCR320-XP>MCR320-XP>HeatKiller GTX680HoleEdition>HeatKiller GTX680HoleEdition
    I am Xtreme BeepBeep2's Avatar
    Jan 2009
    Ohio
    361
    I don't think he was talking about the heat in his room guys, I think he was talking about the temperature the SS can hold when in a hot ambient temperature, and that he doesn't want to ramp the fans up to keep temp.
    -150c Club Member mytekcontrols's Avatar
    Dec 2006
    Santa Rosa, California
    5
    Quote Originally Posted by BeepBeep2 View Post
    The problem I see is that the TEC also requires a fan to cool it's hot side. Also TEC's are very inefficient, so it would take a rather large array to do any appreciable cooling. At any rate, I don't think this will accomplish what he is after, which is less fan noise.
    Perhaps a better solution would be to water cool it, thereby placing your fan and evaporative cooling tower outside or in another room. These are quite easy to DIY.
    Michael St. Pierre
    • Worked 15 years for Polycold Systems
    • Now Self-Employed
    • Manufacture Heat Load Controllers
    • Also do contract service work on Polycold units
    Side note: I usually don't respond to PM's or emails regarding the projects that I post in the forums. I feel it's much more fair to all, to answer questions within the forum topics themselves.
    -150c Club Member n00b 0f l337's Avatar
    May 2005
    NJ
    11
    We have a winner!
    But I don't think he has the tools or refrigerant to rebuild with a water condenser sadly.
    Quote Originally Posted by Movieman
    Thanks for the compliment but unlike that bartender you mentioned I'm not sleeping with you no matter what you say!
    Jun 2007
    Finland
    3
    I was considering putting one or two 20-30watt Tec's to top of the Condenser, i dont really care if my room temp gets higer long as Phase Change runs litlebit lower temps doring summer.
    20-30watt's should be easy enough to cool but do they provide sufficient cooling power to lower temps of Condenser enough, i got several old copper and aluminium heatsinks here that are good size for this use.
    Another way to cool the tecs would be get two single tec waterblocks and cool the tecs with same EK 480 rad that cools graphics cards, just add few blocks to the loop.
    Quote Originally Posted by n00b 0f l337 View Post
    We have a winner!
    Yeah i dont have the tools or refirigerant to rebuild and refill the unit, if i had then it would be allready done.
    Caselabs TX10-D
    4 x Corsair AX1200
+ Reply to Thread
