Well, I've been messing around with Virtu MVP on my i7-3770K with a P8Z77 - V Pro mobo (BIOS 1206) with 16 GB of G.Skill with an EVGA SC GTX 680.
I know in BIOS, when you enable the iGPU for Virtu MVP it states that it will be fixed at a 64MB rate. I know in BIOS you can set the iGPU up to 1024 mbs. I was wondering if there is a way to increase the iGPU memory from 64mb to more in the CPU with Virtu MVP Enabled? Would changing the iGPU memory actually increase the memory even if the mobo states that its at a fixed rate?
I ask because I find myself getting errors with BF3 DirectX running out of memory error with Virtu MVP enabled. I have been able to narrow it down to the iGPU memory that is causing the game to crash. I don't want to disable Virtu MVP (unless there I really have too) since I love the feel of Virtual V-Sync with frames over 60+ FPS with no tears, no stuttering and/or huge performance loss when the FPS drops below 60+ (unlike natural V-Sync).
