Results 1 to 10 of 10
Thread: Asus Z9PE-D8 WS and Intel Xeon E5-2620
    Jul 2006
    Finland
    Hi , in thinking of getting of Asus Z9PE-D8 WS and 2xIntel Xeon E5-2620 for photoshop . Is it possible to overclock those xeons ? And not is it better to get i7 3930K and overclock it as far it goes?
    Oct 2005
    i think theyre all locked. and i dont see the dual xeon setup performing any better than a 3930k in photoshop
    Aug 2010
    perth, west oz
    you can't overclock the Asus !!! look at the EVGA SR-2 if you want to overclock Xeon's
    Henrik
    Henrik
    A Dane Down Under
    Current systems:
    EVGA Classified SR-2
    Lian Li PC-V2120 Black, Antec 1200 PSU,
    2x X5650 (20x 190 APPROX 4.2GHZ), CPU Cooling: Noctua NH-D14
    (48gb) 6x 8Gb Kingston ECC 1333 KVR1333D3D4R9S/8GI, Boot: 8R0 SAMSUNG 830 129GB ARECA 1882IX-4GB CACHE - Scratch disk: 2x6R0 INTEL 520 120GB's, 2x IBM M1015/LSI 9240-8i, Asus GTX-580
    ASUS P5W64 WS PRO, QX-6700 (Extreme Quadcore) 2.66Ghz, 4x2GB HyberX, various hard drives and GT-7600
    Tyan S2895 K8WE 2x 285 Opteron's 8x 2gb DDR400 1x nVidia GT-8800 2x 1 TB Samsung F1 (not very nice) Chenbro SR-107 case
    Monitors: NEC 2690v2 & Dell 2405 & 2x ASUS VE246H
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Quote Originally Posted by tived View Post
    Henrik
    Yes you can, the Asus has a OC bios..
    The issue on any dual 2011 board is you can only OC a small amount.
    104-105BCLK is just about it right now.
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Cyras
    Guest
    I found a new Xeon on Ebay, 2490X ES2 2-way? Link
    Nov 2005
    New Hampshire
    Quote Originally Posted by Cyras View Post
    I wouldn't want those..Very low end..
    Aug 2007
    Toon
    Holy thread resurrection:
    I've been given a system with dual Xeons (2620) and this board (Z9PED8 WS) and asked to Overclock it with 2133MHz RAM.
    First instinct was 160x19 for 2133MHz ish and ~3GHz on the CPUs but this wont POST. Reigned it in to a 120MHz fsb but still it wont POST. Any ideas where to go from here or should I give in and tell the client it's not going to play?
    Intel i7 920 C0 @ 3.67GHz
    ASUS 6T Deluxe
    Powercolor 7970 @ 1050/1475
    12GB GSkill Ripjaws
    Antec 850W TruePower Quattro
    50" Full HD PDP
    Red Cosmos 1000
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Want to get one of these boards so I have been reading up some. There are only one or two types of ram that have passed testing at 2133.
    See which ones at: http://dlcdnet.asus.com/pub/ASUS/ser...IMM_120607.pdf
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
    Nov 2005
    New Hampshire
    Quote Originally Posted by initialised View Post
    Ok, where to start: First, the E5-26xx xeons are BCLK locked so you can't OC them like you could a i7-920 or even the previous gen like we did with the EVGA SR2 board.
    On that Asus board you can increase the BCLK to 103 and thats about it..maybe 104 if your lucky.
    Now to get 3GHz in that system you need to toss out those 2620's, peel open your wallet and remove $3000.00+ and buy a pair of E5-2690's or remove almost $4000,00 and buy a pair of the top E5-2687W's..Now, have I totally rained on your parade?
    Aug 2007
    Toon
    Quote Originally Posted by Movieman View Post
    OK, got that, can't OC on that board at all.
    Now trying to run 8X8GB 2133MHz Kingston Predators (KHX21C11T2K216X), can't get POST higher than 1866MHz 12-12-12-30-2 1.65V a very similar module is listed in the QVL
    Any advice on settings that'll work?
    ASUS 6T Deluxe
    12GB GSkill Ripjaws
    50" Full HD PDP
    Red Cosmos 1000
