Results 1 to 2 of 2
Thread: JBOD array
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    JBOD array
    I know this isn't extreme, but does anyone know how to go about setting up a JBOD array on an MSI 785GM-P45 board (785G/SB710 chipset)?
    I've never settup one of these arrays, but I have 2 Seagate 1.5tb (matching drives) and I'd rather have the system see them as a single 3Tb drive...
    If I could save the data currently on one of the drives that would be awesome, but not necessary.
    I know I sound like a noob, but any info would be appreciated!
    Thanks,
    Dave
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
    Xtreme Cruncher
    Jan 2009
    The Hague, Netherlands
    I never used the JBOD setting, but maybe this will give you some more info: http://www.pcguide.com/ref/hdd/perf/...ls/jbod-c.html
    I don't know if you can still see your data after setting up the JBOD, but I would back up the data before you try.
    3770K 4.7Ghz 1.32v / ASUS P8Z77-V PRO / 8GB DDR3 1866 9-9-9-27 /ASUS HD7970 1025MHz / Antec NeoHE 550 / Samsung 830 256GB Crunching
    Cooled by PA120.3, EK-HF, D-tek Fuzion GFX, DDC3.1 XSPC res/top
    i5 2400 Stock / ASUS P8P67 LE / 4GB DDR3 1600 / Seasonic S12II 430W / Intel G2 40GB Crunching
    2600K 4.6Ghz 1.34v / ASUS P8Z68-V PRO / 8GB DDR3 1600 8-8-8-24 / Antec 430W / Intel G2 80GB Crunching
    W3520 4.0Ghz 1.19v / Rampage II Gene / 6GB Kinston Value 1333 / 9800GT / Corsair TX650 / Antec mini P180 / Intel G2 160GB Crunching
    Intel G860 Stock / Gigabyte H67MA-UD2H-B3 / 4GB DDR3 1333 / Antec Earthwatts green 380W / Crucial M4 64GB Crunching
    E6600 3.2Ghz 1.36v - P5B Deluxe / i7 930 4.0Ghz 1.29v - ASUS P6X58D-E / Q9450 3.6Ghz 1.28v - Rampage Formula Retired
