False,2660 CL10 is total beast,2600 9-11-11,2400 8-10-10 is totally doable for 32M.2800 9-12-12 as well,but you need good imc.2666 CL11 is hynix,high latency.
You have ivy bridge to test with?They should perform well,i guess they are little lower binned that 2666C10
I didn't have much time today...tried ES 3770K how good IMC it has aaand it's bad maybe a little worse than in my 3570K...max boot about 2680 MHz and maximum overclocking about 2700 MHz and not stable...will try with 3570K...I tested especially 2400 CL9 kit and it can do 2666 CL11 1T with 1,65 V SPI 16M stable...didn't tried SPI 32M or something like HCI MemTest because I didn't have time for that...before results some photos
i7 4930K
32GB Corsair Vengeance Pro DDR3-2400C10
Asus Rampage IV Black Edition
2x GeForce GTX 780
Corsair AX1200
Cooler Master HAF-X
Dell U3011
Like Shiranui wrote I didn't have time to do much testing. I tried it in the evening and found that 3570K isn't able to run 2666 multiplier on UP7 and don't know why. On UD5H 2666 multiplier works fine with the same 3570K. And MPower behaves a little weird. I will try different settings on UP7. I am also awaiting Maximus V Extreme so I will able to try it on that later.
He only used 1.65Vdimm and maybe he get's IMC limited. Or maybe he doesn't want to loosen timings... Anyway anything above 2800 is totally inefficient as tertiary timings are too loose. There's more to life then max MHz... someone told in another thread to wait till next generation and be prepped to be blown away :p
Seems his sticks are on par with mine... 2800C10-12-12 does not pas HCI memtest 200% but is benchstable... one is looking for daily stab, the other just wants to bench...
Corsair doesn't have to warrant extreme overclocks either, it can be that your cheap 2400C9 kit contains the same ICs as these 2666C10 kits. If you want OC performance, rumour is that Corsair is prepping a new GTX monstaaa...
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
Next generation of what?Memory IC,e.g 20nm die or next generation IMC,e.g haswell ?
Nice work Michael! Is this the replacement kit?
You should also post your scores in the corresponding thread!
Awesome runs CoolBits
3D C10
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
