hello everyone, hope this is the right place for my questions. need some help with voltages and GTL's haha
my system
Q8200 revision RO
GA-EP45-EXTREME
Corsair CM2X2048-8500C5C (2x2gb)
ATI 6870
Water cooling on CPU and NB
i am currently OC at 500x7 stable, this is after
in prime95;
12 hour small ftt
9 hour large ftt
9 hour blend
150 pass maximum setting in IBT
what i need help with now is bringing the voltages down as much as i can but this easier said than done. the settings i post below are my current settings. i have lower Vcore as much as i can and still be stable. i would like to lower the VTT but below 1.4 will eventually freeze the PC. i have not tried lowering the MCH/NB yet.
and just some general questions before i post my setting, is it true Vcore should be more than VTT and VTT more than MCH in voltage settings?
Can i realy lower my VTT, CPU and NB voltages by tweaking the GTL references?
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: auto
CPU Clock Ratio ..........................: x7
CPU Frequency ...........................: 3.50Ghz (500x7)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 500Mhz
PCI Express Frequency (Mhz) .........:103
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: <<< 800mv (Default)
PCI Express Clock Drive.................: <<< 900mv (Default)
CPU Clock Skew (ps)....................: <<< 0ps
MCH Clock Skew (ps)...................: <<< 0ps
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 400mhz
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 1000mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................Auto
tRCD .........................................Auto
tRP'...........................................Auto
tRAS..........................................Auto
Advanced Timing Control
tRRD...........................................Auto
tWTR..........................................Auto
tWR............................................Auto
tRFC...........................................Auto
tRTP...........................................Auto
Command Rate (CMD) ....................:Auto
Motherboard Voltage Control
Voltage Type.………... Manual
CPU
CPU Vcore….……….........................:1.4250v  <idle: 1.3920v>  <load: 1.3440v>
CPU Termination…..... 1.200V*.......: 1.4000v
CPU PLL…………………....1.500V*.......: 1.5600v
CPU Referen.…………....0.760V*.......: Auto <<< .64% Of Vtt (Termination above)
CPU Reference2………,,0.800V*.......:Auto <<< .67% Of Vtt (Termination above)
MCH/ICH
MCH Core…………….....1.100V...........: 1.3800v
MCH Reference….…….0.760V...........; Auto <<< .64% Of Vtt (Termination
MCH/DRAM Ref.…......0.900V...........: Normal
ICH I/O……………….....1.500V............: Normal
ICH Core…………...……1.100V............: Normal
DRAM
DRAM Voltage ……....1.800V............: 2.1000v
DRAM Termination .…0.900V............: Normal
Channel A Reference 0.900V............: Normal
Channel B Reference 0.900V............: Normal
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled] Enabled if you use Vmware/Virtual PC
Integrated Peripherals
Legacy USB Storage Detect ..............[Enabled] *Note* Must be enabled to flash from USB
