I have posted this in another forum as well, but would like get some more input.
I have only seen parallel flow loops in multi-GPU configs, but can this be done in a single CPU and GPU setup?
This is the idea
According to what I have read, some say the restriction in GPU bock is lower than CPU block and this will cause majority of the coolant to go through the GPU block while starving the CPU block!
Also, serial is the easiest way to go, I know that, but I think the above way will give the neatest tube routing.
Any thought on this?
P.S
This is how my loop is right now, so tubing is minimal
I don't like the tube from CPU-out to RES-in, that is why I wanted to go for an alternative loop.
